Old 09-11-2008, 09:55 AM   #1
TheFOSS's Avatar
TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!
Bags & Horns ??
I didn't want to thread jack so...
Just wondering who has bags and horns?
Do you hook them to the same air tank?
How does the pressure hold up with supporting bags and horns?
just curious..
TheFOSS's Sig:
2005 InfernoRed R/T
Mods:
Engine: Mopar CAI , JBA Shorty Headers , Diablo Predator , Custom painted engine cover and pillers, BT oilcap, fuse box cover, power steeriing, and washer fluid cap
Exterior: Shaved Side Moldings and Badges , Tinted Tails
Interior: Red C/F Dash Kit , BT shiftknob , Modified Shifter
TheFOSS is offline   Reply With Quote
Old 09-11-2008, 10:35 AM   #2
jayalbertcars's Avatar
hello thefoss that is a good question i dont see why it could not be done
Old 09-11-2008, 11:05 AM   #3
krewkut125's Avatar
You do/can hook it all up to the same tank. train horns usually ask for 150psi where air ride I believe calls for 175psi so your horns will just be that much louder... I know lowriderman has bags with like 9 horns hooked up to his setup. I plan on doing this in the near future.
Old 09-11-2008, 11:10 AM   #4
fam0516's Avatar
fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!
Send a message via AIM to fam0516
^^^ he hit it in the spot! My friend had one on a truck s10 and he has a splitter with his tank! So u just gotta make sure if you're driving to have ur bags up befre you honk! And his hot. Is really loud!!
fam0516's Sig:
Keep callin it a hearse..N..Youll be in the back!
fam0516 is online now   Reply With Quote
Old 09-11-2008, 12:38 PM   #5
TheFOSS's Avatar
that was also a question of mine.. once the bags are inflated.. do they still rely on pressure from the air tank? or are the sealed off.. meaning if you pump the bags up could you unhook the tank and the bags still be inflated?(not that i would want to, just helps me see what is going on)
TheFOSS's Sig:
2005 InfernoRed R/T
Mods:
Old 09-11-2008, 01:28 PM   #6
krewkut125's Avatar
I am not sure about unhooking the tank but honking the horns should not affect the bags in the up position. Like Fam was saying in the down position your bags are deflated and then you honk the horns so you inturn let the pressure out of the tank. So you will need to wait for the compressor to fill the tank again before you can lift the car. How they work is you have a tank -> airline -> a pressure solenoid -> the bags and/or the horns. The pressure solenoid is what keeps the air from entering/exiting the bags/horn. So when you push the button say for the horns it opens the solenoid letting air through the lines and out your horns. Once you let off the button the solenoid closes and the horns stop. Air ride I believe works the same way you just have 4 pressure solenoids (one for each wheel) instead of 1 for your horn. That is why air ride comes with a switch box already made for you.
Old 09-11-2008, 01:36 PM   #7
krewkut125's Avatar
Here is a quick drawing I made in paint. With bags you will just need to duplicat the horn route 4 more times...
There is also some wiring of course but I just wanted to show the big stuff.
Old 09-11-2008, 01:49 PM   #8
06 Dodge Van Magnum
gomojo31's Avatar
gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!gomojo31 is a Magnum Genious!
bags on all corners are sealed from tank pressure. You can run off an airline to the horns from the same tank as the bags, the only thing that will affected is tank pressure, that's it BUT less air in tank does mean less playin with the bags. To correct that issue, install 1-2 more compressors for quicker fill-ups.Cheers
gomojo31's Sig:
Donations Now being accepted for Kids Beating Cancer send paypal to moparshowoff@yahoo.com
gomojo31 is offline   Reply With Quote
Old 09-11-2008, 02:24 PM   #9
From Silver 2 Sexy Bullet
gstr6800's Avatar
gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!
I have both, but on separate tanks. I thought about using an individual tank, but the air horns will usually require a higher grade of hose. If you plan to do this, make sure you locate your actuators close to the tank so line leaks will only be detected when the solenoids are activated. That way, your pump does not constantly run, increasing your chances of overheating. If you plan to do this, run two pumps instead of one.
gstr6800's Sig:
-Obama Sponsor and Proud American-
SSCLX Club - www.southernstylecruiserslx.com
My Car Domain - http://cardomain.com/ride/2527110
Street Dreams Photos - http://www.streetdreams.org/photo/sh...o=2898&cat=509
Train Horn Test - http://www.youtube.com/watch?v=VgGLn01G7ok
gstr6800 is offline   Reply With Quote
Old 09-11-2008, 05:14 PM   #10
06 Dodge Van Magnum
gomojo31's Avatar
^ good info. But just for the bags I'm runnin 2 compressors, not neccessary but nice to have. If I was to run horns on the same air supply, i'd add 2 more compressors. Not necessary...but nice to have
gomojo31's Sig:
