Old 03-20-2007, 12:30 AM   #1
motor has a little shameless behaviour in the past
Exclamation Emergency!!!
So I Filled Up My Rt Tonight And Left The Station All Happy And I Noticed That The abs Light And The esp Bas Is On...god Knows Why...i Hit The Brakes And Yup Abs Is Out And I Gunned The Gas And Esp Is Done As Well...both Not Working...i've Turned The Car Off And Waited Nada...disconnected The Battery...nada...removed The Fuses...nada....i'm Totally Pissed Off Now...i'm Gonna Have To Take Off From Work And Go To The Dealership And See If They Can Fix The Damn Thing...i Still Have Over 20k's On The Warranty....if You Guys Have Any Ideas Please Let Me Know....maybe Theres Something I Can Check...waiting 4 A Response Asap...thx!!
i ran the diagnostic and still nothing....
motor is offline   Reply With Quote
Old 03-20-2007, 05:51 AM   #2
jayalbertcars's Avatar
hello i had the bas light on once the car had blown a fuse in the rear next to the battery it only happened once i changed the fuse and have had no more problem
Old 03-20-2007, 08:52 PM   #3
tiggs11's Avatar
tiggs11 is an unknown quantity at this point
hey i had the problem.i took it to the dealer and it was a ( brake pressure switch ), there is tsb on it i was told by the dealer here. the esp and bas or abs light was on and i slight fade in the brake peddal at a stop light, you might be able to get some info and the real dodge site, good luck.... jim
tiggs11 is offline   Reply With Quote
Old 03-20-2007, 09:32 PM   #4
4rwheeler's Avatar
4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!
It's sabotage I tell ya! Some disgrunteled gas station worker climbed under and tinkered with it. O.K., probaly not. Haven't had that happen , sorry I can't be of any "real" help. Good luck.
Old 03-20-2007, 11:30 PM   #5
hehehe...best post ever...hehe.....after screwing roung with all the diags n stuff and reseting it worked this morning...i stopped by the dodge dealership n the guys said that the "pay as you go" gas stations have somew kind of transmitters that can f$%k with the ecu....now im all good and fast rawrr...i just need that governor off somehow....grrr:/.....
thx 4 the help tough guys...appreciate it...
Old 03-21-2007, 11:25 AM   #6
Cappadocious is making a name for themself!Cappadocious is making a name for themself!
Man, as if gas prices werent enough to screw with us these days.
Cappadocious is offline   Reply With Quote
Old 01-12-2008, 09:42 PM   #7
MAGGIE BLUE is making a name for themself!
What is a "pay as you go" gas station?
MAGGIE BLUE is offline   Reply With Quote
Old 01-12-2008, 11:05 PM   #8
customcompacts's Avatar
customcompacts is an unknown quantity at this point
I'm not sure if any of you guys have ran into this problem but when i use my remote car starter some times these lights turn on for me. Some times they don't, but when they do i hate driving with it like that so i turn it off and then start it regularly and everything is fine.
customcompacts is offline   Reply With Quote
Old 01-13-2008, 01:21 AM   #9
Mag Enthusiast
drew06sxt's Avatar
drew06sxt is an unknown quantity at this point
Could be the steering angle sensor going bad...I had the same thing happen to mine and thats what it was.
drew06sxt is offline   Reply With Quote
Old 01-13-2008, 10:42 AM   #10
Lou
Lou's Avatar
Lou is making a name for themself!Lou is making a name for themself!
Send a message via AIM to Lou
Glad to know its fixed! but...
Like MAGGIE BLUE asked...
Lou's Sig:
Lou is offline   Reply With Quote
