Complete list of trouble codes
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
    U.S.A.
    18,841
    This is a very long list. Thought I'd bring them over. Sorry if they're already here somewhere. I've never seen them posted. Maybe they can be put in the Ultimate guide.
    Diagnostic Trouble Codes
    Here is the list of DTC's. This is a HUGE file so it's probably easiest to
    use your scroll function to locate the code you're looking for.
    The P0000 to P1000 are all EOBD Codes.
    First digit structure is as follows:
    • Pxxxx for powertrain
    • Bxxxx for body
    • Cxxxx for chassis
    • Uxxxx for future systems
    Second digit structure is:
    • P0xxx Government required codes
    • P1xxx Manufacturer codes for additional emission system function; not
    required but reported to the government
    Third digit structure is:
    • Px1xx measurement of air and fuel
    • Px2xx measurement of air and fuel
    • Px3xx ignition system
    • Px4xx additional emission control
    • Px5xx speed and idle regulation
    • Px6xx computer and output signals
    • Px7xx transmission
    • Px8xx transmission
    • Px9xx control modules, input and output signals
    The fourth and fifth digits designate the individual components and systems.
    P0000 No Code Stored - No Failures
    P0001 Fuel Volume Regulator Ctrl Circ/Open
    P0002 Fuel Volume Regulator Ctrl Circ Range/Perf
    P0003 Fuel Volume Regulator Ctrl Circ Low
    P0004 Fuel Volume Regulator Ctrl Circ Hi
    P0005 Fuel Shutoff Valve A Ctrl Circ/Open
    P0006 Fuel Shutoff Valve A Ctrl Circ Low
    P0007 Fuel Shutoff Valve A Ctrl Circ Hi
    P0008 Engine Pos Sys Perf Bank1
    P0009 Engine Pos Sys Perf Bank2
    P0010 A Camshaft Pos Actuator Circ Bank1
    P0011 A Camshaft Pos-Timing Over-Advanced or Sys Perf Bank1
    P0012 A Camshaft Pos-Timing Over-Retarded Bank1
    P0013 B Camshaft Pos-Actuator Circ Bank1
    P0014 B Camshaft Pos-Timing Over-Advanced or Sys Perf Bank1
    P0015 B Camshaft Pos-Timing Over-Retarded Bank1
    P0016 Crank/Camshaft Mis-align/sync
    P0017 Crank Pos-Camshaft Pos Correlation Bank1 Sens B
    P0018 Crank Pos-Camshaft Pos Correlation Bank2 Sens A
    P0019 Crank Pos-Camshaft Pos Correlation Bank2 Sens B
    P0020 A Camshaft Pos Actuator Circ Bank2
    P0021 A Camshaft Pos-Timing Over-Advanced or Sys Perf Bank2
    P0022 A Camshaft Pos-Timing Over-Retarded Bank2
    P0023 B Camshaft Pos-Actuator Circ Bank2
    P0024 B Camshaft Pos-Timing Over-Advanced or Sys Perf Bank2
    P0025 B Camshaft Pos-Timing Over-Retarded Bank2
    P0026 Intake Valve Ctrl Solenoid Circ Range/Perf Bank1
    P0027 Exhaust Valve Ctrl Solenoid Circ Range/Perf Bank1
    P0028 Intake Valve Ctrl Solenoid Circ Range/Perf Bank2
    P0029 Exhaust Valve Ctrl Solenoid Circ Range/Perf Bank2
    P0030 1/1 02 Sens Heater Relay Malfunction
    P0031 HO2S Heater Ctrl Circ Low Bank1 Sens1
    P0032 HO2S Heater Ctrl Circ Hi Bank1 Sens1
    P0033 Turbo Charger Bypass Valve Ctrl Circ
    P0034 Turbo Charger Bypass Valve Ctrl Circ Low
    P0035 Turbo Charger Bypass Valve Ctrl Circ Hi
    P0036 1/2 02 Sens Heater Relay Malfunction
    P0037 HO2S Heater Ctrl Circ Low Bank1 Sens2
    P0038 HO2S Heater Ctrl Circ Hi Bank1 Sens2
    P0039 T/Super Charger Bypass Valve Ctrl Circ Range/Perf
    P0040 O2 Sens Signals Swapped Bank1 Sens1/ Bank2 Sens1
    P0041 O2 Sens Signals Swapped Bank1 Sens2/ Bank2 Sens2
    P0042 HO2S Heater Ctrl Circ Bank1 Sens3
    P0043 HO2S Heater Ctrl Circ Low Bank1 Sens3
    P0044 HO2S Heater Ctrl Circ Hi Bank1 Sens3
    P0045 T/Super Charger Boost Ctrl Solenoid Circ/Open
    P0046 T/Super Charger Boost Ctrl Solenoid Circ Range/Perf
    P0047 T/Super Charger Boost Ctrl Solenoid Circ Low
    P0048 T/Super Charger Boost Ctrl Solenoid Circ Hi
    P0049 T/Super Charger Turbine Overspeed
    P0050 HO2S Heater Ctrl Circ Bank2 Sens1
    P0051 HO2S Heater Ctrl Circ Low Bank2 Sens1
    P0052 HO2S Heater Ctrl Circ Hi Bank2 Sens1
    P0053 HO2S Heater Resistance Bank1 Sens1
    P0054 HO2S Heater Resistance Bank1 Sens2
    P0055 HO2S Heater Resistance Bank1 Sens3
    P0056 HO2S Heater Ctrl Circ Bank2 Sens2
    P0057 HO2S Heater Ctrl Circ Low Bank2 Sens2
    P0058 HO2S Heater Ctrl Circ Hi Bank2 Sens2
    P0059 HO2S Heater Resistance Bank2 Sens1
    P0060 HO2S Heater Resistance Bank2 Sens2
    P0061 HO2S Heater Resistance Bank2 Sens3
    P0062 HO2S Heater Ctrl Circ Bank2 Sens3
    P0063 HO2S Heater Ctrl Circ Low Bank2 Sens3
    P0064 HO2S Heater Ctrl Circ Hi Bank2 Sens3
    P0065 Air Assisted Injector Ctrl Range/Perf
    P0066 Air Assisted Injector Ctrl Circ or Circ Low
    P0067 Air Assisted Injector Ctrl Circ Hi
    P0068 MAP/MAF-Throttle Pos Correlation
    P0069 MAP-Barometric Press Correlation
    P0070 Ambient Air Temp Sens Circ
    P0071 Ambient Temp Sens Perf
    P0072 Ambient Temp Sens Low
    P0073 Ambient Temp Sens Hi
    P0074 Ambient Air Temp Sens Circ Interm
    P0075 Intake Valve Ctrl Solenoid Circ Bank1
    P0076 Intake Valve Ctrl Solenoid Circ Low Bank1
    P0077 Intake Valve Ctrl Solenoid Circ Hi Bank1
    P0078 Exhaust Valve Ctrl Solenoid Circ Bank1
    P0079 Exhaust Valve Ctrl Solenoid Circ Low Bank1
    P0080 Exhaust Valve Ctrl Solenoid Circ Hi Bank1
    P0081 Intake Valve Ctrl Solenoid Circ Bank2
    P0082 Intake Valve Ctrl Solenoid Circ Low Bank2
    P0083 Intake Valve Ctrl Solenoid Circ Hi Bank2
    P0084 Exhaust Valve Ctrl Solenoid Circ Bank2
    P0085 Exhaust Valve Ctrl Solenoid Circ Low Bank2
    P0086 Exhaust Valve Ctrl Solenoid Circ Hi Bank2
    P0087 Fuel Rail/Sys Press-Too Low
    P0088 Fuel Rail Press Hi
    P0089 Fuel Press Regulator 1 Perf
    P0090 Fuel Press Regulator 1 Ctrl Circ
    P0091 Fuel Press Regulator 1 Ctrl Circ Low
    P0092 Fuel Press Regulator 1 Ctrl Circ Hi
    P0093 Fuel Sys Leak Detected-Large Leak
    P0094 Fuel Sys Leak Detected-Small Leak
    P0095 Intake Air Temp Sens2 Circ
    P0096 Intake Air Temp Sens2 Circ Range/Perf
    P0097 Intake Air Temp Sens2 Circ Low
    P0098 Intake Air Temp Sens2 Circ Hi
    P0099 Intake Air Temp Sens2 Circ Interm/Erratic
    P0100 Mass or Volume Air Flow Circ
    P0101 MAF Sens Perf
    P0102 MAF Sens Low frequency
    P0103 MAF Sens Hi frequency
    P0104 Mass or Volume Air Flow Circ Interm
    P0105 MAP/Barometric Press Circ
    P0106 Barometric Press Out of Range
    P0107 Map Sens Voltage Too Low
    P0108 Map Sens Voltage Too Hi
    P0109 MAP/Barometric Press Circ Interm
    P0110 Intake Air Temp Sens1 Circ
    P0111 Intake Air Temp Sens Perf
    P0112 Intake Air Temp Sens Voltage Low
    P0113 Intake Air Temp Sens Voltage Hi
    P0114 Intake Air Temp Sens1 Circ Interm
    P0115 Engine Coolant Temp Circ
    P0116 Coolant Temp Sens Perf
    P0117 ECT Sens Voltage Too Low
    P0118 ECT Sens Voltage Too Hi
    P0119 Engine Coolant Temp Circ Interm
    P0120 Throttle/Pedal Pos Sens/Switch A Circ
    P0121 TPS Voltage Does Not Agree with MAP
    P0122 Throttle Pos Sens Voltage Low
    P0123 Throttle Pos Sens Voltage Hi
    P0124 Throttle/Pedal Pos Sens/Switch A Circ Interm
    P0125 Closed Loop Temp Not Reached
    P0126 Insufficient ECT for Stable Operation
    P0127 Intake Air Temp Too Hi
    P0128 Cooling Sys Error / Thermostat Perf
    P0129 Barometric Press Too Low
    P0130 1/1 02 Sens Heater Relay Malfunction
    P0131 1/1 02 Sens Shorted To Ground
    P0132 1/1 O2S Shorted To Voltage
    P0133 1/1 O2S Slow Response
    P0134 1/1 O2S Stays At Center
    P0135 1/1 O2S Heater Failure
    P0136 1/2 02 Sens Heater Relay Malfunction
    P0137 1/2 O2S Shorted To Ground
    P0138 1/2 O2S Shorted To Voltage
    P0139 1/2 O2S Slow Response
    P0140 1/2 O2S Stays At Center
    P0141 1/2 02 Sens Relay
    P0142 O2 Sens Circ Bank1 Sens3
    P0143 1/3 O2S Shorted To Ground
    P0144 1/3 O2S Shorted To Voltage
    P0145 1/3 O2S Slow Response
    P0146 1/3 O2S Stays At Center
    P0147 1/3 02 Sens Heater Failure
    P0148 Fuel Delivery Error
    P0149 Fuel Timing Error
    P0150 O2 Sens Circ Bank2 Sens1
    P0151 2/1 02 Sens Shorted To Ground
    P0152 2/1 02 Sens Shorted To Voltage
    P0153 2/1 02 Sens Slow Response
    P0154 2/1 02 Sens Stays at Center
    P0155 2/1 02 Sens Heater Failure
    P0156 O2 Sens Circ Bank2 Sens2
    P0157 2/2 02 Sens Shorted To Ground
    P0158 2/2 02 Sens Shorted To Voltage
    P0159 2/2 02 Sens Slow Response
    P0160 2/2 02 Sens Stays at Center
    P0161 2/2 02 Sens Heater Failure
    P0162 O2 Sens Circ Bank2 Sens3
    P0163 O2 Sens Circ Low Voltage Bank2 Sens3
    P0164 O2 Sens Circ Hi Voltage Bank2 Sens3
    P0165 Starter Relay Ctrl Circ
    P0166 O2 Sens Circ No Activity Detected Bank2 Sens3
    P0167 O2 Sens Heater Circ Bank2 Sens3
    P0168 Decreased Engine Perf Due to Hi Inj Pump Fuel Temp
    P0169 Water-in-fuel detected for too long
    P0170 Fuel Trim Bank1
    P0171 1/1 Fuel Sys Lean
    P0172 1/1 Fuel Sys Rich
    P0173 Fuel Trim Bank2
    P0174 2/1 Fuel Sys Lean
    P0175 2/1 Fuel Sys Rich
    P0176 Loss of Flex Fuel Calibration Signal
    P0177 Water In Fuel
    P0178 Flex Fuel Sens Volts Too Low
    P0178 Water in Fuel Sens Volts Too Low or
    P0179 Flex Fuel Sens Volts Too Hi
    P0180 CNG Temp Sens Voltage Fail
    P0181 Fuel Inj Pump Failure
    P0182 CNG Temp Sens Voltage Too Low
    P0183 CNG Temp Sens Voltage Too Hi
    P0184 Fuel Temp Sens A Circ Interm
    P0185 Fuel Temp Sens B Circ
    P0186 Fuel Temp Sens B Circ Range/Perf
    P0187 Fuel Temp Sens B Circ Low
    P0188 Fuel Temp Sens B Circ Hi
    P0189 Fuel Temp Sens B Circ Interm
    P0190 Fuel Rail Press Sens Circ
    P0191 Fuel Rail Press Sens Circ Range/Perf
    P0192 Fuel Rail Press Sens Low
    P0193 Fuel Rail Press Sens Hi
    P0194 Fuel Rail Press Sens Circ Interm
    P0195 Engine Oil Temp Sens
    P0196 Engine Oil Temp Sens Range/Perf
    P0197 Engine Oil Temp Sens Low
    P0198 Engine Oil Temp Sens Hi
    P0199 Engine Oil Temp Sens Interm
    P0200 Injector Circ/Open
    P0201 Injector #1 Ctrl Circ
    P0202 Injector #2 Ctrl Circ
    P0203 Injector #3 Ctrl Circ
    P0204 Injector #4 Ctrl Circ
    P0205 Injector #5 Ctrl Circ
    P0206 Injector #6 Ctrl Circ
    P0207 Injector #7 Ctrl Circ
    P0208 Injector #8 Ctrl Circ
    P0209 Injector #9 Ctrl Circ
    P0210 Injector #10 Ctrl Circ
    P0211 Injector Circ/Open-Cylinder 11
    P0212 Injector Circ/Open-Cylinder 12
    P0213 Cold Start Injector 1
    P0214 Cold Start Injector 2
    P0215 Fuel Inj Pump Ctrl Circ
    P0216 Fuel Inj Pump Timing Failure
    P0217 Decreased Eng Perf due to Eng Overheat Condition
    P0218 Trans Fluid Over Temp Condition
    P0219 CKP Sens Overspeed Condition
    P0220 APP Sens2 Circ
    P0221 APP Sens2 Circ Perf
    P0222 Idle Validation Signals Both Low
    P0222 APP Sens2 Circ Low Voltage or
    P0223 Idle Validation Signals Both Hi (Above 5Vs)
    P0223 Inj Pulse Width Error (Rise Time Long) or
    P0224 Throttle/Pedal Pos Sens/Switch B Circ Interm
    P0225 APP Sens3 Circ
    P0226 APP Sens3 Circ Perf
    P0227 APP Sens2 Circ Low Voltage
    P0228 APP Sens2 Circ Hi Voltage
    P0229 Throttle/Pedal Pos Sens/Switch C Circ Interm
    P0230 Transfer Pump (Lift Pump) Circ Out Of Range
    P0231 Fuel Pump Feedback Circ Low Voltage
    P0232 Fuel Shut-Off Signal Voltage Too Hi
    P0233 Fuel Pump Sec Circ Interm
    P0234 Turbo Boost Limit Exceeded
    P0235 T/Super Charger Boost Sens A Circ
    P0236 MAP Sens Too Hi Too Long
    P0237 MAP Sens Voltage Too Low
    P0238 MAP Sens Voltage Too Hi
    P0239 T/Super Charger Boost Sens B Circ
    P0240 T/Super Charger Boost Sens B Circ Range/Perf
    P0241 T/Super Charger Boost Sens B Circ Low
    P0242 T/Super Charger Boost Sens B Circ Hi
    P0243 Open or shorted condition detected in the turbocharger Wastegate solenoid Ctrl
    P0244 T/Super Charger Wastegate Solenoid A Range/Perf
    P0245 T/Super Charger Wastegate Solenoid A Low
    P0246 T/Super Charger Wastegate Solenoid A Hi
    P0247 T/Super Charger Wastegate Solenoid B
    P0248 T/Super Charger Wastegate Solenoid B Range/Perf
    P0249 T/Super Charger Wastegate Solenoid B Low
    P0250 T/Super Charger Wastegate Solenoid B Hi
    P0251 Fuel Inj Pump Fuel valve Feedback Circ
    P0252 Fuel Inj Pump Fuel Valve Stuck
    P0253 Fuel Inj Pump Fuel Valve Open Circ
    P0254 Fuel Inj Pump Fuel Valve Current Too Hi
    P0255 Inj Pump Fuel Metering Ctrl A Interm (Cam/Rotor/Injector)
    P0256 Inj Pump Fuel Metering Ctrl B (Cam/Rotor/Injector)
    P0257 Inj Pump Fuel Metering Ctrl B Range/Perf (Cam/Rotor/Injector)
    P0258 Inj Pump Fuel Metering Ctrl B Low (Cam/Rotor/Injector)
    P0259 Inj Pump Fuel Metering Ctrl B Hi (Cam/Rotor/Injector)
    P0260 Inj Pump Fuel Metering Ctrl B Interm (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circ Low
    P0262 Cylinder 1 Injector Circ Hi
    P0263 Cylinder 1 Balance Sys
    P0264 Cylinder 2 Injector Circ Low
    P0265 Cylinder 2 Injector Circ Hi
    P0266 Cylinder 2 Balance Sys
    P0267 Cylinder 3 Injector Circ Low
    P0268 Cylinder 3 Injector Circ Hi
    P0269 Cylinder 3 Balance Sys
    P0270 Cylinder 4 Injector Circ Low
    P0271 Cylinder 4 Injector Circ Hi
    P0272 Cylinder 4 Balance Sys
    P0273 Cylinder 5 Injector Circ Low
    P0274 Cylinder 5 Injector Circ Hi
    P0275 Cylinder 5 Balance Sys
    P0276 Cylinder 6 Injector Circ Low
    P0277 Cylinder 6 Injector Circ Hi
    P0278 Cylinder 6 Balance Sys
    P0279 Cylinder 7 Injector Circ Low
    P0280 Cylinder 7 Injector Circ Hi
    P0281 Cylinder 7 Balance Sys
    P0282 Cylinder 8 Injector Circ Low
    P0283 Cylinder 8 Injector Circ Hi
    P0284 Cylinder 8 Balance Sys
    P0285 Cylinder 9 Injector Circ Low
    P0286 Cylinder 9 Injector Circ Hi
    P0287 Cylinder 9 Contribution/Balance
    P0288 Cylinder 10 Injector Circ Low
    P0289 Cylinder 10 Injector Circ Hi
    P0290 Cylinder 10 Contribution/Balance
    P0291 Cylinder 11 Injector Circ Low
    P0292 Cylinder 11 Injector Circ Hi
    P0293 Cylinder 11 Contribution/Balance
    P0294 Cylinder 12 Injector Circ Low
    P0295 Cylinder 12 Injector Circ Hi
    P0296 Cylinder 12 Contribution/Balance
    P0297 Vehicle Overspeed Condition
    P0298 Engine Oil Over Temp
    P0299 T/Super Charger Underboost
    P0300 Multiple Cylinder Misfire
    P0301 Cylinder #1 Misfire
    P0302 Cylinder #2 Misfire
    P0303 Cylinder #3 Misfire
    P0304 Cylinder #4 Misfire
    P0305 Cylinder #5 Misfire
    P0306 Cylinder #6 Misfire
    P0307 Cylinder #7 Misfire
    P0308 Cylinder #8 Misfire
    P0309 Cylinder #9 Misfire
    P0310 Cylinder #10 Misfire
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0313 Misfire Detected with Low Fuel
    P0314 Single Cylinder Misfire (Cylinder not Specified)
    P0315 Crank Pos Sys Variation Not Learned
    P0316 Engine Misfire Detected on Startup (First 1000 Revs)
    P0317 Rough Road Hardware Not Present
    P0318 Rough Road Sens A Signal Circ
    P0319 Rough Road Sens B
    P0320 No Crank Ref Signal at PCM
    P0321 Ignition/Distributor Engine Speed Input Circ Range/Perf
    P0322 Ignition/Distributor Engine Speed Input Circ No Signal
    P0323 Ignition/Distributor Engine Speed Input Circ Interm
    P0324 Knock Ctrl Sys Error
    P0325 Knock Sens #1 Circ
    P0326 Knock Sens1 Circ Range/Perf Bank1 or Single Sens
    P0327 Knock Sens Noise Channel Low Voltage
    P0328 Knock Sens1 Circ Hi Bank1 or Single Sens
    P0329 Knock Sens1 Circ Input Interm Bank1 or Single Sens
    P0330 Knock Sens #2 Circ
    P0331 Knock Sens2 Circ Range/Perf Bank2
    P0332 Knock Sens2 Circ Low Bank2
    P0333 Knock Sens2 Circ Hi Bank2
    P0334 Knock Sens2 Circ Input Interm Bank2
    P0335 Crank Pos Sens Circ
    P0336 Crank Pos Sens Perf
    P0337 Crank Pos Sens Circ Low
    P0338 Crank Pos Sens Circ Hi
    P0339 Crank Pos Sens Circ Interm
    P0340 No Cam Signal At PCM
    P0341 CMP Sens Signal
    P0342 ESS Voltage Supply Low
    P0343 ESS Voltage Supply Hi
    P0344 Camshaft Pos Sens A Circ Interm Bank1 or Single Sens
    P0345 Camshaft Pos Sens A Circ Bank2
    P0346 Camshaft Pos Sens A Circ Range/Perf Bank2
    P0347 Camshaft Pos Sens A Circ Low Bank2
    P0348 Camshaft Pos Sens A Circ Hi Bank2
    P0349 Camshaft Pos Sens A Circ Interm Bank2
    P0350 Ignition Coil Draws Too Much Current
    P0351 Ignition Coil # 1 Primary Circ
    P0352 Ignition Coil # 2 Primary Circ
    P0353 Ignition Coil # 3 Primary Circ
    P0354 Ignition Coil # 4 Primary Circ
    P0355 Ignition Coil # 5 Primary Circ
    P0356 Ignition Coil # 6 Primary Circ
    P0357 Ignition Coil # 7 Primary Circ
    P0358 Ignition Coil # 8 Primary Circ
    P0359 Ignition Coil I Primary/Sec Circ
    P0360 Ignition Coil J Primary/Sec Circ
    P0361 Ignition Coil K Primary/Sec Circ
    P0362 Ignition Coil L Primary/Sec Circ
    P0363 Misfire Detected-Fueling Disabled
    P0365 Camshaft Pos Sens B Circ Bank1
    P0366 Camshaft Pos Sens B Circ Range/Perf Bank1
    P0367 Camshaft Pos Sens B Circ Low Bank1
    P0368 Camshaft Pos Sens B Circ Hi Bank1
    P0369 Camshaft Pos Sens B Circ Interm Bank1
    P0370 Fuel Inj Pump Speed/Pos Sens Signal Lost
    P0371 Timing Ref Hi Res Signal A Too Many Pulses
    P0372 Timing Ref Hi Res Signal A Too Few Pulses
    P0373 Timing Ref Hi Res Signal A Interm/Erratic Pulses
    P0374 Timing Ref Hi Res Signal A No Pulse
    P0375 Timing Ref Hi Res Signal B
    P0376 Timing Ref Hi Res Signal B Too Many Pulses
    P0377 Timing Ref Hi Res Signal B Too Few Pulses
    P0378 Timing Ref Hi Res Signal B Interm/Erratic Pulses
    P0379 Timing Ref Hi Res Signal B No Pulses
    P0380 Glow Plug Circ Perf
    P0380 Intake Air Heater Relay No. 1 Ctrl Circ or
    P0381 Wait To Start Lamp Inoperative
    P0382 Intake Air Heater Relay No. 2 Ctrl Circ
    P0383 P0384 Reserved by document
    P0385 Crank Pos Sens B Circ
    P0386 Crank Pos Sens B Circ Range/Perf
    P0387 CKP Sens Supply Voltage Too Low
    P0388 CKP Sens Supply Voltage Too Hi
    P0389 Crank Pos Sens B Circ Interm
    P0390 Camshaft Pos Sens B Circ Bank2
    P0391 Camshaft Pos Sens B Circ Range/Perf Bank2
    P0392 Camshaft Pos Sens B Circ Low Bank2
    P0393 Camshaft Pos Sens B Circ Hi Bank2
    P0394 Camshaft Pos Sens B Circ Interm Bank2
    P0400 Exhaust Gas Recirculation (EGR) Flow Malfunction
    P0401 EGR Sys Failure
    P0402 EGR Flow Excessive Detected
    P0403 EGR Solenoid Circ
    P0404 EGR Pos Sens Rationality
    P0405 EGR Pos Sens Volts Too Low
    P0406 EGR Pos Sens Volts Too Hi
    P0407 Exhaust Gas Recirculation Sens B Circ Low
    P0408 Exhaust Gas Recirculation Sens B Circ Hi
    P0409 Exhaust Gas Recirculation Sens A Circ
    P0410 AIR Sys
    P0411 Sec Air Inj Sys Incorrect Flow Detected
    P0412 Sec Air Solenoid Circ
    P0413 Sec Air Inj Sys Switching Valve A Circ Open
    P0414 Sec Air Inj Sys Switching Valve A Circ Shorted
    P0415 Sec Air Inj Sys Switching Valve B Circ
    P0416 Sec Air Inj Sys Switching Valve B Circ Open
    P0417 Sec Air Inj Sys Switching Valve B Circ Shorted
    P0418 Sec Air Inj Sys Ctrl A Circ
    P0419 Sec Air Inj Sys Ctrl B Circ
    P0420 1/1 Catalytic Conv Eff
    P0421 Warm Up Catalyst Eff Below Threshold Bank1
    P0422 Main Catalyst Eff Below Threshold Bank1
    P0423 Heated Catalyst Eff Below Threshold Bank1
    P0424 Heated Catalyst Temp Below Threshold Bank1
    P0425 Catalyst Temp Sens Bank1
    P0426 Catalyst Temp Sens Range/Perf Bank1
    P0427 Catalyst Temp Sens Low Bank1
    P0428 Catalyst Temp Sens Hi Bank1
    P0429 Catalyst Heater Ctrl Circ Bank1
    P0430 1/2 Catalytic Conv Eff
    P0431 Warm Up Catalyst Eff Below Threshold Bank2
    P0432 1/2 Catalytic Conv Eff
    P0433 Heated Catalyst Eff Below Threshold Bank2
    P0434 Heated Catalyst Temp Below Threshold Bank2
    P0435 Catalyst Temp Sens Bank2
    P0436 Catalyst Temp Sens Range/Perf Bank2
    P0437 Catalyst Temp Sens Low Bank2
    P0438 Catalyst Temp Sens Hi Bank2
    P0439 Catalyst Heater Ctrl Circ Bank2
    P0440 Evap Sys Perf
    P0441 Evap Purge Flow Monitor
    P0442 Evap Leak Monitor Medium Leak Detected
    P0443 Evap Purge Solenoid Circ
    P0444 Evap Emission Sys Purge Ctrl Valve Circ Open
    P0445 Evap Emission Sys Purge Ctrl Valve Circ Shorted
    P0446 Evap Emissions Vent Valve Perf
    P0447 Evap Emission Sys Vent Ctrl Circ Open
    P0448 Evap Emission Sys Vent Ctrl Circ Shorted
    P0449 Evap Emission Sys Vent Valve/Solenoid Circ
    P0450 Evap Emission Sys Press Sens/Switch
    P0451 Evap Emission Sys Press Sens/Switch Range/Perf
    P0452 Evap Emissions Press Sens Circ Low Volts
    P0453 Evap Emissions Press Sens Circ Hi Volts
    P0454 Evap Emission Sys Press Sens/Switch Interm
    P0455 Evap Leak Monitor Large Leak Detected
    P0456 Evap Leak Monitor Small (0.020) Leak Detected
    P0457 EVAP Emission Sys Leak Detected (fuel cap loose/off)
    P0458 EVAP Emission Sys Purge Ctrl Valve Circ Low
    P0459 EVAP Emission Sys Purge Ctrl Valve Circ Hi
    P0460 Fuel Level Unit No Change Over Miles
    P0461 Fuel Level Unit No Changeover Time
    P0462 Fuel Level Sending Unit Volts Too Low
    P0463 Fuel Level Sending Unit Volts Too Hi
    P0464 Fuel Level Sens A Circ Interm
    P0465 EVAP Purge Flow Sens Circ
    P0466 EVAP Purge Flow Sens Circ Range/Perf
    P0467 EVAP Purge Flow Sens Circ Low
    P0468 EVAP Purge Flow Sens Circ Hi
    P0469 EVAP Purge Flow Sens Circ Interm
    P0470 Exhaust Press Sens
    P0471 Exhaust Press Sens Range/Perf
    P0472 Exhaust Press Sens Low
    P0473 Exhaust Press Sens Hi
    P0474 Exhaust Press Sens Interm
    P0475 EPR Solenoid Circ
    P0476 Exhaust Press Ctrl Valve Range/Perf
    P0477 Exhaust Press Ctrl Relay Low
    P0478 Exhaust Press Ctrl Relay Hi
    P0479 Exhaust Press Ctrl Valve Interm
    P0480 Cooling Fan1 Ctrl Circ Open(Low speed fan)
    P0481 Fan 2 Ctrl Circ
    P0482 Fan 3 Ctrl Circ
    P0483 Cooling Fan Speed
    P0484 Fan Circ Over Current
    P0485 Fan Power/Ground Circ
    P0486 Exhaust Gas Recirculation Sens B Circ
    P0487 Exhaust Gas Recirculation Throttle Pos Ctrl Circ
    P0488 Exhaust Gas Recirculation Throttle Pos Ctrl Range/Perf
    P0489 Exhaust Gas Recirculation Ctrl Circ Low
    P0490 Exhaust Gas Recirculation Ctrl Circ Hi
    P0491 Sec Air Inj Sys Insufficient Flow Bank1
    P0492 Sec Air Inj Sys Insufficient Flow Bank2
    P0493 Fan Overspeed
    P0494 Fan Speed Low
    P0495 Fan Speed Hi
    P0496 EVAP Emission Sys Hi Purge Flow
    P0497 EVAP Emission Sys Low Purge Flow
    P0500 No Vehicle Speed Sens Signal
    P0501 Vehicle Speed Sens Perf
    P0502 Vehicle Speed Sens A Circ Low Input
    P0503 Vehicle Speed Sens A Interm/Erratic/Hi
    P0504 Brake Switch A/B Correlation
    P0505_Idle Air Ctrl Motor Circs
    P0506 Idle Ctrl Sys Low RPM
    P0507 Idle Ctrl Sys Hi RPM
    P0508 Undercurrent condition detected in linear idle air Ctrl motor feedback sense Circ
    P0509 Over current condition detected in linear idle air Ctrl motor feedback sense Circ
    P0510 Closed Throttle Pos Switch
    P0511 Idle Air Ctrl Circ
    P0512 Starter Request Circ
    P0513 Incorrect Immobilizer Key
    P0514 Battery Temp Sens Perf
    P0515 Battery Temp Sens Circ
    P0516 Battery Temp Sens Low
    P0517 Battery Temp Sens Hi
    P0518 Idle Air Ctrl Circ Interm
    P0519 Idle Air Ctrl Sys Perf
    P0520 Engine Oil Press Sens/Switch Circ
    P0521 Oil Press Sens Perf
    P0522 Oil Press Sens Low
    P0523 Oil Press Sens Hi
    P0524 Oil Press Too Low
    P0525 Cruise Ctrl Servo Ctrl Circ Range/Perf
    P0526 Fan Speed Sens Circ
    P0527 Fan Speed Sens Circ Range/Perf
    P0528 Fan Speed Sens Circ No Signal
    P0529 Fan Speed Sens Circ Interm
    P0530 A/C Refrigerant Press Sens A Circ
    P0531 A/C Refrigerant Press Sens A Circ Range/Perf
    P0532 A/C Press Sens Low
    P0533 A/C Press Sens Hi
    P0534 Air Conditioner Refrigerant Charge Loss
    P0535 A/C Evaporator Temp Sens Circ
    P0536 A/C Evaporator Temp Sens Circ Range/Perf
    P0537 A/C Evaporator Temp Sens Circ Low
    P0538 A/C Evaporator Temp Sens Circ Hi
    P0539 A/C Evaporator Temp Sens Circ Interm
    P0540 Intake Air Heater A Circ
    P0541 Intake Air Relay 1 Low
    P0542 Intake Air Relay 1 Hi
    P0543 Intake Air Heater A Circ Open
    P0544 Exhaust Gas Temp Sens Circ Bank1 Sens1
    P0545 A/C Clutch Relay Circ
    P0546 Exhaust Gas Temp Sens Circ Hi Bank1 Sens1
    P0547 Exhaust Gas Temp Sens Circ Bank2 Sens1
    P0548 Exhaust Gas Temp Sens Circ Low Bank2 Sens1
    P0549 Exhaust Gas Temp Sens Circ Hi Bank2 Sens1
    P0550 Power Steering Press Sens/Switch Circ
    P0551 Power Steering Switch Failure
    P0552 Power Steering Press Sens/Switch Circ Low Input
    P0553 Power Steering Press Sens/Switch Circ Hi Input
    P0554 Power Steering Press Sens/Switch Circ Interm
    P0555 Brake Booster Press Sens Circ
    P0556 Brake Booster Press Sens Circ Range/Perf
    P0557 Brake Booster Press Sens Circ Low Input
    P0558 Brake Booster Press Sens Circ Hi Input
    P0559 Brake Booster Press Sens Circ Interm
    P0560 Sys Voltage
    P0561 Sys Voltage Unstable
    P0562 Charging Sys Voltage Too Low
    P0563 Charging Sys Voltage Too Hi
    P0564 Cruise Ctrl Multi-Function Input A Circ
    P0565 Cruise Ctrl On Signal
    P0566 Cruise Ctrl Off Signal
    P0567 Cruise Resume Circ
    P0568 Cruise Set Circ
    P0569 Cruise Ctrl Coast Signal
    P0570 Cruise Ctrl Accelerate Signal
    P0571 Cruise Brake Switch Circ
    P0572 Brake Switch 1 Low
    P0573 Brake Switch 1 Hi
    P0574 Cruise Ctrl Sys-Vehicle Speed Too Hi
    P0575 Cruise Switch Failure (Shorted)
    P0576 Cruise Ctrl Input Circ Low
    P0577 Cruise Switch Failure (Open)
    P0578 Cruise Ctrl Multi-Function Input A Circ Stuck
    P0579 Cruise Ctrl Multi-Function Input A Circ Range/Perf
    P0580 Speed Ctrl Multiplexed Switch 1 Low
    P0581 Speed Ctrl Multiplexed Switch 1 Hi
    P0582 Cruise Ctrl Vacuum Ctrl Circ/Open
    P0583 Cruise Ctrl Vacuum Ctrl Circ Low
    P0584 Cruise Ctrl Vacuum Ctrl Circ Hi
    P0585 Cruise Ctrl Multi-Function Input A/B Correlation
    P0586 Cruise Ctrl Vent Ctrl Circ/Open
    P0587 Cruise Ctrl Vent Ctrl Circ Low
    P0588 Cruise Ctrl Vent Ctrl Circ Hi
    P0589 Cruise Ctrl Multi-Function Input B Circ
    P0590 Cruise Ctrl Multi-Function Input B Circ Stuck
    P0591 Cruise Ctrl Multi-Function Input B Circ Range/Perf
    P0592 Cruise Ctrl Multi-Function Input B Circ Low
    P0593 Cruise Ctrl Multi-Function Input B Circ Hi
    P0594 Cruise Ctrl Servo Ctrl Circ/Open
    P0595 Cruise Ctrl Servo Ctrl Circ Low
    P0596 Cruise Ctrl Servo Ctrl Circ Hi
    P0597 Thermostat Heater Ctrl Circ/Open
    P0598 Thermostat Heater Ctrl Circ Low
    P0599 Thermostat Heater Ctrl Circ Hi
    P0600 PCM Failure SPI Comms
    P0601 PCM Internal Ctrller Failure
    P0602 ECM Fueling Calibration Error
    P0603 VCM Memory Reset
    P0604 RAM Check Failure
    P0605 ROM Check Failure
    P0606 ECM Failure
    P0607 ECU Internal Perf
    P0608 Ctrl Mod VSS Output A
    P0609 Ctrl Mod VSS Output B
    P0610 Ctrl Mod Vehicle Options Error
    P0611 Fuel Injector Ctrl Mod Perf
    P0612 Fuel Injector Ctrl Mod Relay Ctrl
    P0613 TCM Processor
    P0614 ECM / TCM Incompatible
    P0615 Starter Relay Ctrl Circ
    P0616 Starter Relay Circ Low
    P0617 Starter Relay Circ Hi
    P0618 Alternative Fuel Ctrl Mod KAM Error
    P0619 Alternative Fuel Ctrl Mod RAM/ROM Error
    P0620 Generator Ctrl Circ
    P0621 Alternator L Terminal Circ
    P0622 Alternator Field Not Switching Properly
    P0623 Generator Lamp Ctrl Circ
    P0624 Fuel Cap Lamp Ctrl Circ
    P0625 Generator Field/F Terminal Circ Low
    P0626 Generator Field/F Terminal Circ Hi
    P0627 Fuel Pump A Ctrl Circ /Open
    P0628 Fuel Pump Relay Circ Low (or)
    P0628 Fuel Lift Pump Ctrl Circ Low
    P0629 Fuel Pump Relay Circ Hi (or)
    P0629 Fuel Lift Pump Ctrl Circ Hi
    P0630 VIN Not Programmed in PCM
    P0631 VIN Not Programmed or Incompatible-TCM
    P0632 Odometer Not Programmed-ECM/PCM
    P0633 SKIM Key Not Programmed in PCM
    P0634 PCM/ECM/TCM Internal Temp Too Hi
    P0635 Power Steering Ctrl Circ
    P0636 Power Steering Ctrl Circ Low
    P0637 Power Steering Ctrl Circ Hi
    P0638 Throttle Actuator Ctrl Range/Perf Bank1
    P0639 Throttle Actuator Ctrl Range/Perf Bank2
    P0640 Intake Air Heater Ctrl Circ
    P0641 Sens Ref Voltage A Circ/Open
    P0642 Sens Ref Voltage 1 Circ Low
    P0643 Sens Ref Voltage 1 Circ Hi
    P0644 Driver Display Serial Comm Circ
    P0645 A/C Clutch Relay Circ Perf
    P0646 A/C Clutch Relay Circ Low
    P0647 A/C Clutch Relay Circ Hi
    P0648 Immobilizer Lamp Ctrl Circ
    P0649 Speed Ctrl Lamp Ctrl Circ
    P0650 Malfunction Indicator Lamp (MIL) Circ
    P0651 Sens Ref Voltage B Circ/Open
    P0652 Sens Ref Voltage 2 Circ Low
    P0653 Sens Ref Voltage 2 Circ Hi
    P0654 Engine Speed Output Circ
    P0655 Engine Hot Lamp Output Ctrl Circ
    P0656 Fuel Level Output Circ
    P0657 Actuator Supply Voltage A Circ/Open
    P0658 Actuator Supply Voltage A Circ Low
    P0659 Actuator Supply Voltage A Circ Hi
    P0660 Intake Manif Tuning Valve Ctrl Circ/Open Bank1
    P0661 Intake Manif Tuning Valve Ctrl Circ Low Bank1
    P0662 Intake Manif Tuning Valve Ctrl Circ Hi Bank1
    P0663 Intake Manif Tuning Valve Ctrl Circ/Open Bank2
    P0664 Intake Manif Tuning Valve Ctrl Circ Low Bank2
    P0665 Intake Manif Tuning Valve Ctrl Circ Hi Bank2
    P0666 PCM/ECM/TCM Internal Temp Sens Circ
    P0667 PCM/ECM/TCM Internal Temp Sens Range/Perf
    P0668 PCM/ECM/TCM Internal Temp Sens Circ Low
    P0669 PCM/ECM/TCM Internal Temp Sens Circ Hi
    P0670 Glow Plug Mod Ctrl Circ
    P0671 Cylinder 1 Glow Plug Circ
    P0672 Cylinder 2 Glow Plug Circ
    P0673 Cylinder 3 Glow Plug Circ
    P0674 Cylinder 4 Glow Plug Circ
    P0675 Cylinder 5 Glow Plug Circ
    P0676 Cylinder 6 Glow Plug Circ
    P0677 Cylinder 7 Glow Plug Circ
    P0678 Cylinder 8 Glow Plug Circ
    P0679 Cylinder 9 Glow Plug Circ
    P0680 Cylinder 10 Glow Plug Circ
    P0681 Cylinder 11 Glow Plug Circ
    P0682 Cylinder 12 Glow Plug Circ
    P0683 Glow Plug Ctrl Mod to PCM Comm Circ
    P0684 Glow Plug Ctrl Mod to PCM Comm Circ Range/Perf
    P0685 ECM/PCM Power Relay Ctrl Circ /Open
    P0686 ECM/PCM Power Relay Ctrl Circ Low
    P0687 ECM/PCM Power Relay Ctrl Circ Hi
    P0688 ECM/PCM Power Relay Sense Circ /Open
    P0689 ECM/PCM Power Relay Sense Circ Low
    P0690 ECM/PCM Power Relay Sense Circ Hi
    P0691 Fan 1 Ctrl Circ Low
    P0692 Fan 1 Ctrl Circ Hi
    P0693 Fan 2 Ctrl Circ Low
    P0694 Fan 2 Ctrl Circ Hi
    P0695 Fan 3 Ctrl Circ Low
    P0696 Fan 3 Ctrl Circ Hi
    P0697 Sens Ref Voltage C Circ/Open
    P0698 Sens Ref Voltage 3 Circ Low
    P0699 Sens Ref Voltage 3 Circ Hi
    P0700 EATX Ctrller DTC Present
    P0701 Trans Ctrl Sys Range/Perf
    P0702 Trans Ctrl Sys Electrical
    P0703 Brake Switch Sense Circ
    P0704 Clutch Switch Circ (M/T)
    P0705 Trans Range Sens Circ Malfunction (PRNDL Input)
    P0706 Trans Range Sens Circ Range/Perf
    P0707 Trans Range Sens Circ Low
    P0708 Trans Range Sens Circ Hi
    P0709 Trans Range Sens Circ Interm
    P0710 Trans Fluid Temp Sens A Circ
    P0711 Trans Temp Sens, No Temp Rise After Start
    P0712 Trans Temp Sens Voltage Too Low
    P0713 Trans Temp Sens Voltage Too Hi
    P0714 Trans Fluid Temp Sens A Circ Interm
    P0715 Input/Turbine Speed Sens A Circ
    P0716 Input/Turbine Speed Sens A Circ Range/Perf
    P0717 Input/Turbine Speed Sens A Circ No Signal
    P0718 Input/Turbine Speed Sens A Circ Interm
    P0719 Brake Switch B Circ Low
    P0720 Low Output SPEED Sens RPM, Above 15 MPH
    P0721 Output Speed Sens Circ Range/Perf
    P0722 Output Speed Sens Circ No Signal
    P0723 Output Speed Sens Circ Interm
    P0724 Brake Switch B Circ Hi
    P0725 Engine Speed Input Circ
    P0726 Engine Speed Input Circ Range/Perf
    P0727 Engine Speed Input Circ No Signal
    P0728 Engine Speed Input Circ Interm
    P0729 Gear 6 Incorrect Ratio
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect Ratio
    P0732 Gear 2 Incorrect Ratio
    P0733 Gear 3 Incorrect Ratio
    P0734 Gear 4 Incorrect Ratio
    P0735 Gear 5 Incorrect Ratio
    P0736 Reverse Incorrect Ratio
    P0737 TCM Engine Speed Output Circ
    P0738 TCM Engine Speed Output Circ Low
    P0739 TCM Engine Speed Output Circ Hi
    P0740 Torque Conv Clutch, No RPM Drop at Lockup
    P0741 Torque Conv Clutch Circ Perf or Stuck Off
    P0742 Torque Conv Clutch Circ Stuck On
    P0743 Torque Conv Clutch Solenoid/Trans Relay Circs
    P0744 Torque Conv Clutch Circ Interm
    P0745 Press Ctrl Solenoid A
    P0746 Press Ctrl Solenoid A Perf or Stuck Off
    P0747 Press Ctrl Solenoid A Stuck On
    P0748 Governor Press Sol Ctrl/Trans Relay Circs
    P0749 Press Ctrl Solenoid A Interm
    P0750 Shift Solenoid A
    P0751 O/D Switch Pressed (Low) More Than 5 Minutes
    P0752 Shift Solenoid A Stuck On
    P0753 Trans 3-4 Shift Sol/Trans Relay Circs
    P0754 Shift Solenoid A Interm
    P0755 Shift Solenoid B
    P0756 AW4 Shift Sol B (2-3) Functional Failure
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Interm
    P0760 Shift Solenoid C
    P0761 Shift Solenoid C Perf or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Interm
    P0765 Shift Solenoid D
    P0766 Shift Solenoid D Perf or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Interm
    P0770 Shift Solenoid E
    P0771 Shift Solenoid E Perf or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Interm
    P0775 Press Ctrl Solenoid B
    P0776 Press Ctrl Solenoid B Perf or Stuck off
    P0777 Press Ctrl Solenoid B Stuck On
    P0778 Press Ctrl Solenoid B Electrical
    P0779 Press Ctrl Solenoid B Interm
    P0780 Shift Error
    P0781 1-2 Shift
    P0782 2-3 Shift
    P0783 3-4 Shift Sol, No RPM Drop at Lockup
    P0784 4-5 Shift
    P0785 Shift/Timing Solenoid
    P0786 Shift/Timing Solenoid Range/Perf
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid Hi
    P0789 Shift/Timing Solenoid Interm
    P0790 Normal/Perf Switch Circ
    P0791 Intermediate Shaft Speed Sens A Circ
    P0792 Intermediate Shaft Speed Sens A Circ Range/Perf
    P0793 Intermediate Shaft Speed Sens A Circ No Signal
    P0794 Intermediate Shaft Speed Sens A Circ Interm
    P0795 Press Ctrl Solenoid C
    P0796 Press Ctrl Solenoid C Perf or Stuck off
    P0797 Press Ctrl Solenoid C Stuck On
    P0798 Press Ctrl Solenoid C Electrical
    P0799 Press Ctrl Solenoid C Interm
    P0800 Transfer Case Ctrl Sys (MIL Request)
    P0801 Reverse Gear Lockout Circ Open or Short
    P0802 Trans Ctrl Sys MIL Request Circ/Open
    P0803 1-4 Upshift (Skip Shift) Solenoid Ctrl Circ
    P0804 1-4 Upshift (Skip Shift) Lamp Ctrl Circ
    P0805 Clutch Pos Sens Circ
    P0806 Clutch Pos Sens Circ Range/Perf
    P0807 Clutch Pos Sens Circ Low
    P0808 Clutch Pos Sens Circ Hi
    P0809 Clutch Pos Sens Circ Interm
    P0810 Clutch Pos Ctrl Error
    P0811 Excessive Clutch Slippage
    P0812 Reverse Input Circ
    P0813 Reverse Output Circ
    P0814 Trans Range Display Circ
    P0815 Upshift Switch Circ
    P0816 Downshift Switch Circ
    P0817 Starter Disable Circ
    P0818 Driveline Disconnect Switch Input Circ
    P0819 Up and Down Shift Switch to Trans Range Correlation
    P0820 Gear Lever X-Y Pos Sens Circ
    P0821 Gear Lever X Pos Circ
    P0822 Gear Lever Y Pos Circ
    P0823 Gear Lever X Pos Circ Interm
    P0824 Gear Lever Y Pos Circ Interm
    P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
    P0826 Up and Down Shift Switch Circ
    P0827 Up and Down Shift Switch Circ Low
    P0828 Up and Down Shift Switch Circ Hi
    P0829 5-6 Shift
    P0830 Clutch Depressed Switch Circ
    P0831 Clutch Pedal Switch A Circ Low
    P0832 Clutch Pedal Switch A Circ Hi
    P0833 Clutch Released Switch Circ
    P0834 Clutch Pedal Switch B Circ Low
    P0835 Clutch Pedal Switch B Circ Hi
    P0836 Four Wheel Drive (4WD) Switch Circ
    P0837 4WD Switch Perf
    P0838 4WD Switch Circ Low
    P0839 4WD Switch Circ Hi
    P0840 Trans Fluid Press Sens/Switch A Circ
    P0841 Trans Fluid Press Sens/Switch A Circ Range/Perf
    P0842 Trans Fluid Press Sens/Switch A Circ Low
    P0843 Trans Fluid Press Sens/Switch A Circ Hi
    P0844 Trans Fluid Press Sens/Switch A Circ Interm
    P0845 Trans Fluid Press Sens/Switch B Circ
    P0846 Trans Fluid Press Sens/Switch B Circ Range/Perf
    P0847 Trans Fluid Press Sens/Switch B Circ Low
    P0848 Trans Fluid Press Sens/Switch B Circ Hi
    P0849 Trans Fluid Press Sens/Switch B Circ Interm
    P0850 Park/Neutral Switch Input Circ
    P0851 Park/Neutral Switch Input Circ Low
    P0852 Park/Neutral Switch Input Circ Hi
    P0853 Drive Switch Input Circ
    P0854 Drive Switch Input Circ Low
    P0855 Drive Switch Input Circ Hi
    P0856 Traction Ctrl Input Signal
    P0857 Traction Ctrl Input Signal Range/Perf
    P0858 Traction Ctrl Input Signal Low
    P0859 Traction Ctrl Input Signal Hi
    P0860 Gear Shift Mod Comm Circ
    P0861 Gear Shift Mod Comm Circ Low
    P0862 Gear Shift Mod Comm Circ Hi
    P0863 TCM Comm Circ
    P0864 TCM Comm Circ Range/Perf
    P0865 TCM Comm Circ Low
    P0866 TCM Comm Circ Hi
    P0867 Trans Fluid Press
    P0868 Trans Fluid Press Low
    P0869 Trans Fluid Press Hi
    P0870 Trans Fluid Press Sens/Switch C Circ
    P0871 Trans Fluid Press Sens/Switch C Circ Range/Perf
    P0872 Trans Fluid Press Sens/Switch C Circ Low
    P0873 Trans Fluid Press Sens/Switch C Circ Hi
    P0874 Trans Fluid Press Sens/Switch C Circ Interm
    P0875 Trans Fluid Press Sens/Switch D Circ
    P0876 Trans Fluid Press Sens/Switch D Circ Range/Perf
    P0877 Trans Fluid Press Sens/Switch D Circ Low
    P0878 Trans Fluid Press Sens/Switch D Circ Hi
    P0879 Trans Fluid Press Sens/Switch D Circ Interm
    P0880 TCM Power Input Signal
    P0881 TCM Power Input Signal Range/Perf
    P0882 TCM Power Input Signal Low
    P0883 TCM Power Input Signal Hi
    P0884 TCM Power Input Signal Interm
    P0885 TCM Power Relay Ctrl Circ/Open
    P0886 TCM Power Relay Ctrl Circ Low
    P0887 TCM Power Relay Ctrl Circ Hi
    P0888 TCM Power Relay Sense Circ
    P0889 TCM Power Relay Sense Circ Range/Perf
    P0890 TCM Power Relay Sense Circ Low
    P0891 TCM Power Relay Sense Circ Hi
    P0892 TCM Power Relay Sense Circ Interm
    P0893 Multiple Gears Engaged
    P0894 Trans Component Slipping
    P0895 Shift Time Too Short
    P0896 Shift Time Too Long
    P0897 Trans Fluid Deteriorated
    P0898 Trans Ctrl Sys MIL Request Circ Low
    P0900 Clutch Actuator Circ/Open
    P0901 Clutch Actuator Circ Range/Perf
    P0902 Clutch Actuator Circ Low
    P0903 Clutch Actuator Circ Hi
    P0904 Gate Select Pos Circ
    P0905 Gate Select Pos Circ Range/Perf
    P0906 Gate Select Pos Circ Low
    P0907 Gate Select Pos Circ Hi
    P0908 Gate Select Pos Circ Interm
    P0909 Gate Select Ctrl Error
    P0910 Gate Select Actuator Circ/Open
    P0911 Gate Select Actuator Circ Range/Perf
    P0912 Gate Select Actuator Circ Low
    P0913 Gate Select Actuator Circ Hi
    P0914 Gear Shift Pos Circ
    P0915 Gear Shift Pos Circ Range/Perf
    P0916 Gear Shift Pos Circ Low
    P0917 Gear Shift Pos Circ Hi
    P0918 Gear Shift Pos Circ Interm
    P0919 Gear Shift Pos Ctrl Error
    P0920 Gear Shift Forward Actuator Circ/Open
    P0921 Gear Shift Forward Actuator Circ Range/Perf
    P0922 Gear Shift Forward Actuator Circ Low
    P0923 Gear Shift Forward Actuator Circ Hi
    P0924 Gear Shift Reverse Actuator Circ/Open
    P0925 Gear Shift Reverse Actuator Circ Range/Perf
    P0926 Gear Shift Reverse Actuator Circ Low
    P0927 Gear Shift Reverse Actuator Circ Hi
    P0928 Gear Shift Lock Solenoid Ctrl Circ/Open
    P0929 Gear Shift Lock Solenoid Ctrl Circ Range/Perf
    P0930 Gear Shift Lock Solenoid Ctrl Circ Low
    P0931 Gear Shift Lock Solenoid Ctrl Circ Hi
    P0932 Hydraulic Press Sens Circ
    P0933 Hydraulic Press Sens Range/Perf
    P0934 Hydraulic Press Sens Circ Low
    P0935 Hydraulic Press Sens Circ Hi
    P0936 Hydraulic Press Sens Circ Interm
    P0937 Hydraulic Oil Temp Sens Circ
    P0938 Hydraulic Oil Temp Sens Range/Perf
    P0939 Hydraulic Oil Temp Sens Circ Low
    P0940 Hydraulic Oil Temp Sens Circ Hi
    P0941 Hydraulic Oil Temp Sens Circ Interm
    P0942 Hydraulic Press Unit
    P0943 Hydraulic Press Unit Cycling Period Too Short
    P0944 Hydraulic Press Unit Loss of Press
    P0945 Hydraulic Pump Relay Circ/Open
    P0946 Hydraulic Pump Relay Circ Range/Perf
    P0947 Hydraulic Pump Relay Circ Low
    P0948 Hydraulic Pump Relay Circ Hi
    P0949 Auto Shift Manual Adaptive Learning Not Complete
    P0950 Auto Shift Manual Ctrl Circ
    P0951 Auto Shift Manual Ctrl Circ Range/Perf
    P0952 Auto Shift Manual Ctrl Circ Low
    P0953 Auto Shift Manual Ctrl Circ Hi
    P0954 Auto Shift Manual Ctrl Circ Interm
    P0955 Auto Shift Manual Mode Circ
    P0956 Auto Shift Manual Mode Circ Range/Perf
    P0957 Auto Shift Manual Mode Circ Low
    P0958 Auto Shift Manual Mode Circ Hi
    P0959 Auto Shift Manual Mode Circ Interm
    P0960 Press Ctrl Solenoid A Ctrl Circ/Open
    P0961 Press Ctrl Solenoid A Ctrl Circ Range/Perf
    P0962 Press Ctrl Solenoid A Ctrl Circ Low
    P0963 Press Ctrl Solenoid A Ctrl Circ Hi
    P0964 Press Ctrl Solenoid B Ctrl Circ/Open
    P0965 Press Ctrl Solenoid B Ctrl Circ Range/Perf
    P0966 Press Ctrl Solenoid B Ctrl Circ Low
    P0967 Press Ctrl Solenoid B Ctrl Circ Hi
    P0968 Press Ctrl Solenoid C Ctrl Circ/Open
    P0969 Press Ctrl Solenoid C Ctrl Circ Range/Perf
    P0970 Press Ctrl Solenoid C Ctrl Circ Low
    P0971 Press Ctrl Solenoid C Ctrl Circ Hi
    P0972 Shift Solenoid A Ctrl Circ Range/Perf
    P0973 Shift Solenoid A Ctrl Circ Low
    P0974 Shift Solenoid A Ctrl Circ Hi
    P0975 Shift Solenoid B Ctrl Circ Range/Perf
    P0976 Shift Solenoid B Ctrl Circ Low
    P0977 Shift Solenoid B Ctrl Circ Hi
    P0978 Shift Solenoid C Ctrl Circ Range/Perf
    P0979 Shift Solenoid C Ctrl Circ Low
    P0980 Shift Solenoid C Ctrl Circ Hi
    P0981 Shift Solenoid D Ctrl Circ Range/Perf
    P0982 Shift Solenoid D Ctrl Circ Low
    P0983 Shift Solenoid D Ctrl Circ Hi
    P0984 Shift Solenoid E Ctrl Circ Range/Perf
    P0985 Shift Solenoid E Ctrl Circ Low
    P0986 Shift Solenoid E Ctrl Circ Hi
    P0987 Trans Fluid Press Sens/Switch E Circ
    P0988 Trans Fluid Press Sens/Switch E Circ Range/Perf
    P0989 Trans Fluid Press Sens/Switch E Circ Low
    P0990 Trans Fluid Press Sens/Switch E Circ Hi
    P0991 Trans Fluid Press Sens/Switch E Circ Interm
    P0992 Trans Fluid Press Sens/Switch F Circ
    P0993 Trans Fluid Press Sens/Switch F Circ Range/Perf
    P0994 Trans Fluid Press Sens/Switch F Circ Low
    P0995 Trans Fluid Press Sens/Switch F Circ Hi
    P0996 Trans Fluid Press Sens/Switch F Circ Interm
    P0997 Shift Solenoid F Ctrl Circ Range/Perf
    P0998 Shift Solenoid F Ctrl Circ Low
    P0999 Shift Solenoid F Ctrl Circ Hi
    P0A00 Motor Electronics Coolant Temp Sens Circ
    P0A01 Motor Electronics Coolant Temp Sens Circ Range/Perf
    P0A02 Motor Electronics Coolant Temp Sens Circ Low
    P0A03 Motor Electronics Coolant Temp Sens Circ Hi
    P0A04 Motor Electronics Coolant Temp Sens Circ Interm
    P0A05 Motor Electronics Coolant Pump Ctrl Circ/Open
    P0A06 Motor Electronics Coolant Pump Ctrl Circ Low
    P0A07 Motor Electronics Coolant Pump Ctrl Circ Hi
    P0A08 DC/DC Conv Status Circ
    P0A09 DC/DC Conv Status Circ Low Input
    P0A10 DC/DC Conv Status Circ Hi Input
    P0A11 DC/DC Conv Enable Circ/Open
    P0A12 DC/DC Conv Enable Circ Low
    P0A13 DC/DC Conv Enable Circ Hi
    P0A14 Engine Mount Ctrl Circ/Open
    P0A15 Engine Mount Ctrl Circ Low
    P0A16 Engine Mount Ctrl Circ Hi
    P0A17 Motor Torque Sens Circ
    P0A18 Motor Torque Sens Circ Range/Perf
    P0A19 Motor Torque Sens Circ Low
    P0A20 Motor Torque Sens Circ Hi
    P0A21 Motor Torque Sens Circ Interm
    P0A22 Generator Torque Sens Circ
    P0A23 Generator Torque Sens Circ Range/Perf
    P0A24 Generator Torque Sens Circ Low
    P0A25 Generator Torque Sens Circ Hi
    P0A26 Generator Torque Sens Circ Interm
    P0A27 Battery Power Off Circ
    P0A28 Battery Power Off Circ Low
    P0A29 Battery Power Off Circ Hi
    P1000 Ignition Circ Low
    P1001 Ignition Circ Hi
    P1004 ECU Battery Feed & Power Grounds
    P1005 Sys Ground Circ
    P1006 EGR/EVAP Solenoid Circ Low
    P1007 EGR/EVAP Solenoid Circ Hi
    P1008 Power Steering Circ Low
    P1009 Power Steering Circ Hi
    P1012 MPA Circ Low
    P1013 MPA Circ Hi
    P1014 Fuel Pump Circ Low
    P1015 Fuel Pump Circ Hi
    P1016 Charge Air Temp Circ Low
    P1017 Charge Air Temp Circ Hi
    P1018 Serial Data Circ
    P1019 Power Latch Not Set
    P1021 Engine Failed To Start Due To Mechanical, Fuel or Ignition Conditions
    P1022 Starter Relay Circ Low
    P1024 ECU Start Circ Low
    P1025 WOT Circ Low
    P1026 WOT Circ Hi
    P1027 ECU Sees Wide Open Throttle
    P1028 ECU Does Not See Wide Open Throttle
    P1029 ISA Closed Throttle Circ Low
    P1030 ISA Closed Throttle Circ Hi
    P1031 ECU Sees Closed Throttle
    P1032 ECU Does Not See Closed Throttle
    P1033 ISA Circs
    P1037 TP Sens Circ Reads Low
    P1038 Park/Neutral Line Hi
    P1039 Park/Neutral Line Low
    P1040 Latched B+ Line Low
    P1041 Latched B+ Line Hi
    P1042 No Latched B+ 1/2 Volt Drop
    P1043 Shift Lamp Circ Grounded
    P1044 D2–1 Circ Low (A/T) or
    P1044 Upshift Lamp Circ (M/T) or
    P1044 Shift Lamp Circ Hi
    P1045 Shift Lamp Circ Open
    P1047 Wrong ECU
    P1048 M/T Vehicle Configuration
    P1049 A/T Vehicle Configuration
    P1050 Idle RPM Low
    P1051 Idle RPM Hi
    P1052 MAP Sens Out Of Limits
    P1053 Change In MAP Reading Out Of Limits
    P1054 Coolant Sens & 5V Supply for TP Sens/MAP Circs Low
    P1055 Coolant Sens Circ Hi
    P1056 Inactive Coolant Temp Sens
    P1059 A/C Request Circ Low
    P1060 A/C Request Circ Hi
    P1061 A/C Select Circ Low
    P1062 A/C Select Circ Hi
    P1063 A/C Clutch Circ Low
    P1064 A/C Clutch Circ Hi & Power Steering Input
    P1068 Latch Relay Circ Hi
    P1069 No Tach
    P1074 ECU Does Not See Speed Sens
    P1106 MAP Sens Circ Interm Hi Voltage
    P1107 MAP Sens Circ Interm Low Voltage
    P1110 Decreased Engine Perf Due To Hi Intake Air Temp
    P1111 IAT Sens Circ Interm Hi Voltage
    P1112 IAT Sens Circ Interm Low Voltage
    P1114 ECT Sens Circ Interm Low Voltage
    P1115 ECT Sens Circ Interm Hi Voltage
    P1121 TPS Circ Interm Hi Voltage
    P1122 TPS Circ Interm Low Voltage
    P1125 Accelerator Pedal Pos Sys
    P1133 HO2S Insufficient Switching Bank1 Sens1
    P1134 HO2S Insufficient Transition Time Ratio Bank1 Sens1
    P1153 HO2S Insufficient Switching Bank2 Sens1
    P1154 HO2S Insufficient Transition Time Ratio Bank2 Sens1
    P1180 Decreased Engine Perf Due To Hi Inj Pump Fuel Temp
    P1191 Intake Air Duct Leak
    P1192 Inlet Air Temp Sens Voltage Low
    P1193 Inlet Air Temp Voltage Hi
    P1194 02 Heater Perf
    P1195_1/1 02 Sens Slow During Catalyst Monitor
    P1196_2/1 02 Sens Slow During Catalyst Monitor
    P1197 1/2 02 Sens Slow During Catalyst Monitor
    P1198 Radiator Temp Sens Volts Too Hi
    P1199 Radiator Temp Sens Volts Too Low
    P1214 Inj Pump Timing Offset
    P1216 Fuel Solenoid Response Time Too Short
    P1217 Fuel Solenoid Response Time Too Long
    P1218 Inj Pump Calibration Circ
    P1271 Accelerator Pedal Pos Sens1-2 Correlation
    P1272 Accelerator Pedal Pos Sens2-3 Correlation
    P1273 Accelerator Pedal Pos Sens1-3 Correlation
    P1275 Accelerator Pedal Pos Sens1 Circ
    P1277 Accelerator Pedal Pos Sens1 Low Voltage
    P1278 Accelerator Pedal Pos Sens1 Hi Voltage
    P1280 Accelerator Pedal Pos Sens2 Circ
    P1281 Engine is Cold Too Long
    P1282 Accelerator Pedal Pos Sens2 Low Voltage
    P1282 Fuel Pump Relay Ctrl Circ or
    P1283 Accelerator Pedal Pos Sens2 Hi Voltage
    P1283 Idle Select Signal Invalid or
    P1284 Fuel Inj Pump Battery Voltage Out Of Range
    P1285 Accelerator Pedal Pos Sens3 Circ
    P1285 Fuel Inj Pump Ctrller Always On or
    P1286 Accelerator Pos Sens Supply Voltage Too Hi
    P1287 Accelerator Pedal Pos Sens3 Low Voltage
    P1287 Fuel Inj Pump Ctrl Supply Voltage Low or
    P1288 Accelerator Pedal Pos Sens3 Hi Voltage
    P1288 Intake Manif Short Runner Solenoid Circ or
    P1289 Manif Tune Valve Solenoid Circ
    P1290 CNG Fuel Sys Press Too Hi
    P1291 No Temp Rise Seen From Intake Heaters
    P1292 CNG Press Sens Voltage Too Hi
    P1293 CNG Press Sens Voltage Too Low
    P1294_Target Idle Not Reached
    P1295 No 5Vs to Throttle Pos Sens
    P1296 No 5Vs to MAP Sens
    P1297_No Change in MAP from Start To Run
    P1298 Lean Operation at Wide Open Throttle
    P1299_Vacuum Leak Found (IAC Fully Seated)
    P1336 Crank Pos Sys Variation Not Learned
    P1345 Crank Pos/Camshaft Pos Correlation
    P1351 Ignition Ctrl Circ Hi Voltage
    P1361 Ignition Ctrl Circ Low Voltage
    P1380 Electronic Brake Ctrl Rough Road Data Unusable
    P1381 Misfire Detected-No Electronic Brake Ctrl Data
    P1388 Auto Shutdown Relay Ctrl Circ
    P1389 No ASD Relay Output Voltage at PCM
    P1390_Timing Belt Skipped 1 Tooth or More
    P1391_Interm Loss of CMP or CKP
    P1398_Misfire Adaptive Numerator at Limit
    P1399 Wait to Start Lamp Circ
    P1403 No 5Vs to EGR Sens
    P1404 EGR Valve Closed Pintle Pos
    P1406 EGR Valve Pos
    P1409 EGR Valve Sys leak
    P1415 AIR Sys Bank1
    P1416 AIR Sys Bank1
    P1441 Evap Emissions Flow During Non-Purge
    P1475 Auxiliary 5V Supply Voltage Hi
    P1476 Too Little Sec Air
    P1477 Too Much Sec Air
    P1478 Battery Temp Sens Volts Out of Limit
    P1479 Trans Fan Relay Circ
    P1480 PCV Solenoid Circ
    P1481 EATX Misfire RPM Signal out of Range
    P1482 Catalyst Temp Sens Circ Shorted Low
    P1483 Catalyst Temp Sens Circ Shorted Hi
    P1484 Catalytic Conv Overheat Detected
    P1485 Air Inj Solenoid Circ
    P1486 Eva Leak Monitor Pinched Hose Found
    P1487 Hi Speed Radiator Fan CTRL Relay Circ
    P1488 Auxiliary 5V Supply Output Too Low
    P1489 Hi Speed Fan CTRL Relay Circ
    P1490 Low Speed Fan CTRL Relay Circ
    P1491 Radiator Fan Ctrl Relay Circ
    P1492 Ambient/Battery Temp Sens Volts Too Hi
    P1493 Ambient/Battery Temp Sens Volts Too Low
    P1494 Leak Detection Pump Switch or Mechanical Fault
    P1495 Leak Detection Pump Solenoid Circ
    P1496 5V Supply, Output Too Low
    P1498 Hi Speed Radiator Fan Ground CTRL Relay Circ
    P1508 IAC Sys Low RPM
    P1509 IAC Sys Hi RPM
    P1594 Charging Sys Voltage Too Hi
    P1595 Speed Ctrl Solenoid Circs
    P1596 Speed Ctrl Switch Always Hi
    P1597 Speed Ctrl Switch Always Low
    P1598 A/C Press Sens Volts Too Hi
    P1599 A/C Press Sens Volts Too Low
    P1602 PCM Not Programmed
    P1621 PCM Memory Perf or Write
    P1626 Vehicle Theft Sys Ctrl Loss of Data
    P1627 A/D Perf
    P1630 Vehicle Theft Sys PCM in Learn Mode
    P1631 Vehicle Theft Sys Improper Password
    P1635 5V Ref ( Circ
    P1639 5V Ref ( Circ
    P1641 MIL Ctrl Circ
    P1643 Wait To Start Lamp Ctrl Circ
    P1646 5V Ref (C) Circ
    P1652 J1850 Comms Bus
    P1653 EGR Vent Solenoid Ctrl Circ
    P1654 Service Throttle Soon Lamp Ctrl Circ
    P1655 EGR Solenoid Ctrl Circ
    P1656 Wastegate Solenoid Ctrl Circ
    P1680 Clutch Released Switch Circ
    P1681 No I/P Cluster CCD/J1850 Messages Received
    P1682 Charging Sys Voltage Too Low
    P1683 Speed Ctrl Power Relay; or S/C 12v Driver CKT
    P1684 Battery Disconnected in the last 50 Starts
    P1685 Skim Invalid Key
    P1686 No SKIM BUS Messages Received
    P1687 No Cluster BUS Message
    P1688 Internal Fuel Inj Pump Ctrller Failure
    P1689 No Comm between ECM & Inj Pump Mod
    P1690 CKP Sens Does Not Agree with ECM CKP Sens
    P1691 Fuel Sys ESS RPM Error
    P1692 DTC Set In ECM
    P1693 DTC Detected in Companion JTEC Mod
    P1694 No BUS Message Received from ECM Mod
    P1695 No CCD/J1850 Messages from the Body Ctrl Mod.
    P1696 PCM Failure EEPROM Write Denied
    P1697 PCM Failure SRI Mile Not Stored
    P1698 No CCD/J1850 Message From TCM/PCM
    P1719 Skip Shift Solenoid Circ
    P1740 TCC or O/D Solenoid Perf
    P1756 Gov Press Not Equal to Target @ not15-20 PSI
    P1757 Gov Press above 3 PSI in gear with 0 MPH
    P1762 Gov Press Sens Offset Volts Too Low or Hi
    P1763 Governor Press Sens Volts Too Hi
    P1764 Governor Press Sens Volts Too Low
    P1765 Trans 12 Volt Supply Relay CTRL Circ
    P1899 P/N Switch Stuck in Park or in Gear
    P2000 NOx Trap Eff Below Threshold Bank1
    P2001 NOx Trap Eff Below Threshold Bank2
    P2002 Particulate Trap Eff Below Threshold Bank1
    P2003 Particulate Trap Eff Below Threshold Bank2
    P2004 Intake Manif Runner Ctrl Stuck Open Bank1
    P2005 Intake Manif Runner Ctrl Stuck Open Bank2
    P2006 Intake Manif Runner Ctrl Stuck Closed Bank1
    P2007 Intake Manif Runner Ctrl Stuck Closed Bank2
    P2008 Intake Manif Runner Ctrl Circ/Open Bank1
    P2009 Intake Manif Runner Ctrl Circ Low Bank1
    P2010 Intake Manif Runner Ctrl Circ Hi Bank1
    P2011 Intake Manif Runner Ctrl Circ/Open Bank2
    P2012 Intake Manif Runner Ctrl Circ Low Bank2
    P2013 Intake Manif Runner Ctrl Circ Hi Bank2
    P2014 Intake Manif Runner Pos Sens/Switch Circ Bank1
    P2015 Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank1
    P2016 Intake Manif Runner Pos Sens/Switch Circ Low Bank1
    P2017 Intake Manif Runner Pos Sens/Switch Circ Hi Bank1
    P2018 Intake Manif Runner Pos Sens/Switch Circ Interm Bank1
    P2019 Intake Manif Runner Pos Sens/Switch Circ Bank2
    P2020 Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank2
    P2021 Intake Manif Runner Pos Sens/Switch Circ Low Bank2
    P2022 Intake Manif Runner Pos Sens/Switch Circ Hi Bank2
    P2023 Intake Manif Runner Pos Sens/Switch Circ Interm Bank2
    P2024 EVAP Emissions (EVAP) Fuel Vapor Temp Sens Circ
    P2025 EVAP Fuel Vapor Temp Sens Perf
    P2026 EVAP Fuel Vapor Temp Sens Circ Low Voltage
    P2027 EVAP Fuel Vapor Temp Sens Circ Hi Voltage
    P2028 EVAP Fuel Vapor Temp Sens Circ Interm
    P2029 Fuel Fired Heater Disabled
    P2030 Fuel Fired Heater Perf
    P2031 Exhaust Gas Temp Sens Circ Bank1 Sens2
    P2032 Exhaust Gas Temp Sens Circ Low Bank1 Sens2
    P2033 Exhaust Gas Temp Sens Circ Hi Bank1 Sens2
    P2034 Exhaust Gas Temp Sens Circ Bank2 Sens2
    P2035 Exhaust Gas Temp Sens Circ Low Bank2 Sens2
    P2036 Exhaust Gas Temp Sens Circ Hi Bank2 Sens2
    P2037 Reductant Inj Air Press Sens Circ
    P2038 Reductant Inj Air Press Sens Circ Range/Perf
    P2039 Reductant Inj Air Press Sens Circ Low Input
    P2040 Reductant Inj Air Press Sens Circ Hi Input
    P2041 Reductant Inj Air Press Sens Circ Interm
    P2042 Reductant Temp Sens Circ
    P2043 Reductant Temp Sens Circ Range/Perf
    P2044 Reductant Temp Sens Circ Low Input
    P2045 Reductant Temp Sens Circ Hi Input
    P2046 Reductant Temp Sens Circ Interm
    P2047 Reductant Injector Circ/Open Bank1 Unit 1
    P2048 Reductant Injector Circ Low Bank1 Unit 1
    P2049 Reductant Injector Circ Hi Bank1 Unit 1
    P2050 Reductant Injector Circ/Open Bank2 Unit 1
    P2051 Reductant Injector Circ Low Bank2 Unit 1
    P2052 Reductant Injector Circ Hi Bank2 Unit 1
    P2053 Reductant Injector Circ/Open Bank1 Unit 2
    P2054 Reductant Injector Circ Low Bank1 Unit 2
    P2055 Reductant Injector Circ Hi Bank1 Unit 2
    P2056 Reductant Injector Circ/Open Bank2 Unit 2
    P2057 Reductant Injector Circ Low Bank2 Unit 2
    P2058 Reductant Injector Circ Hi Bank2 Unit 2
    P2059 Reductant Inj Air Pump Ctrl Circ/Open
    P2060 Reductant Inj Air Pump Ctrl Circ Low
    P2061 Reductant Inj Air Pump Ctrl Circ Hi
    P2062 Reductant Supply Ctrl Circ/Open
    P2063 Reductant Supply Ctrl Circ Low
    P2064 Reductant Supply Ctrl Circ Hi
    P2065 Fuel Level Sens B Circ
    P2066 Fuel Level Sens B Perf
    P2067 Fuel Level Sens B Circ Low
    P2068 Fuel Level Sens B Circ Hi
    P2069 Fuel Level Sens B Circ Interm
    P2070 Intake Manif Tuning (IMT) Valve Stuck Open
    P2071 IMT Valve Stuck Closed
    P2075 IMT Valve Pos Sens/Switch Circ
    P2076 IMT Valve Pos Sens/Switch Circ Range/Perf
    P2077 IMT Valve Pos Sens/Switch Circ Low
    P2078 IMT Valve Pos Sens/Switch Circ Hi
    P2079 IMT Valve Pos Sens/Switch Circ Interm
    P2080 Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens1
    P2081 Exhaust Gas Temp Sens Circ Interm Bank1 Sens1
    P2082 Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens1
    P2083 Exhaust Gas Temp Sens Circ Interm Bank2 Sens1
    P2084 Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens2
    P2085 Exhaust Gas Temp Sens Circ Interm Bank1 Sens2
    P2086 Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens2
    P2087 Exhaust Gas Temp Sens Circ Interm Bank2 Sens2
    P2088 A Camshaft Pos Actuator Ctrl Circ Low Bank1
    P2089 A Camshaft Pos Actuator Ctrl Circ Hi Bank1
    P2090 B Camshaft Pos Actuator Ctrl Circ Low Bank1 c)
    P2091 B Camshaft Pos Actuator Ctrl Circ Hi Bank1 c)
    P2092 A Camshaft Pos Actuator Ctrl Circ Low Bank2
    P2093 A Camshaft Pos Actuator Ctrl Circ Hi Bank2
    P2094 B Camshaft Pos Actuator Ctrl Circ Low Bank2 c)
    P2095 B Camshaft Pos Actuator Ctrl Circ Hi Bank2 c)
    P2096 Post Catalyst Fuel Trim Sys Too Lean Bank1
    P2097 Post Catalyst Fuel Trim Sys Too Rich Bank1
    P2098 Post Catalyst Fuel Trim Sys Too Lean Bank2
    P2099 Post Catalyst Fuel Trim Sys Too Rich Bank2
    P2100 Throttle Actuator Ctrl Motor Circ/Open
    P2101 Throttle Actuator Ctrl Motor Circ Range/Perf
    P2102 Throttle Actuator Ctrl Motor Circ Low
    P2103 Throttle Actuator Ctrl Motor Circ Hi
    P2104 Throttle Actuator Ctrl Sys-Forced Idle
    P2105 Throttle Actuator Ctrl Sys-Forced Engine Shutdown
    P2106 Throttle Actuator Ctrl Sys-Forced Limited Power
    P2107 Throttle Actuator Ctrl Mod Processor
    P2108 Throttle Actuator Ctrl Mod Perf
    P2109 Throttle/Pedal Pos Sens A Minimum Stop Perf
    P2110 Throttle Actuator Ctrl Sys-Forced Limited RPM
    P2111 Throttle Actuator Ctrl Sys-Stuck Open
    P2112 Throttle Actuator Ctrl Sys-Stuck Closed
    P2113 Throttle/Pedal Pos Sens B Minimum Stop Perf
    P2114 Throttle/Pedal Pos Sens C Minimum Stop Perf
    P2115 Throttle/Pedal Pos Sens D Minimum Stop Perf
    P2116 Throttle/Pedal Pos Sens E Minimum Stop Perf
    P2117 Throttle/Pedal Pos Sens F Minimum Stop Perf
    P2118 Throttle Actuator Ctrl Motor Current Range/Perf
    P2119 Throttle Actuator Ctrl Throttle Body Range/Perf
    P2120 Throttle/Pedal Pos Sens/Switch D Circ
    P2121 Throttle/Pedal Pos Sens/Switch D Circ Range/Perf
    P2122 Throttle/Pedal Pos Sens/Switch D Circ Low Input
    P2123 Pedal Pos Sens1 Hi
    P2124 Throttle/Pedal Pos Sens/Switch D Circ Interm
    P2125 Throttle/Pedal Pos Sens/Switch E Circ
    P2126 Throttle/Pedal Pos Sens/Switch E Circ Range/Perf
    P2127 Pedal Pos Validation Switch 2 Low
    P2128 Pedal Pos Validation Switch 2 Hi
    P2129 Throttle/Pedal Pos Sens/Switch E Circ Interm
    P2130 Throttle/Pedal Pos Sens/Switch F Circ
    P2131 Throttle/Pedal Pos Sens/Switch F Circ Range Perf
    P2132 Throttle/Pedal Pos Sens/Switch F Circ Low Input
    P2133 Throttle/Pedal Pos Sens/Switch F Circ Hi Input
    P2134 Throttle/Pedal Pos Sens/Switch F Circ Interm
    P2135 Throttle/Pedal Pos Sens/Switch A/B Voltage Correlation
    P2136 Throttle/Pedal Pos Sens/Switch A/C Voltage Correlation
    P2137 Throttle/Pedal Pos Sens/Switch B/C Voltage Correlation
    P2138 Throttle/Pedal Pos Sens/Switch D/E Voltage Correlation
    P2139 Throttle/Pedal Pos Sens/Switch D/F Voltage Correlation
    P2140 Throttle/Pedal Pos Sens/Switch E/F Voltage Correlation
    P2141 Exhaust Gas Recirculation Throttle Ctrl Circ Low
    P2142 Exhaust Gas Recirculation Throttle Ctrl Circ Hi
    P2143 Exhaust Gas Recirculation Vent Ctrl Circ/Open
    P2144 Exhaust Gas Recirculation Vent Ctrl Circ Low
    P2145 Exhaust Gas Recirculation Vent Ctrl Circ Hi
    P2146 Fuel Injector Group 1 Supply Voltage Circ
    P2147 Fuel Injector Group 1 Supply Voltage Low
    P2148 Fuel Injector Group 1 Supply Voltage Hi
    P2149 Fuel Injector Group 2 Supply Voltage Circ
    P2150 Fuel Injector Group 2 Supply Voltage Low
    P2151 Fuel Injector Group 2 Supply Voltage Hi
    P2152 Fuel Injector Group C Supply Voltage Circ/Open
    P2153 Fuel Injector Group C Supply Voltage Circ Low
    P2154 Fuel Injector Group C Supply Voltage Circ Hi
    P2155 Fuel Injector Group D Supply Voltage Circ/Open
    P2156 Fuel Injector Group D Supply Voltage Circ Low
    P2157 Fuel Injector Group D Supply Voltage Circ Hi
    P2158 Vehicle Speed Sens B
    P2159 Vehicle Speed Sens B Range/Perf
    P2160 Vehicle Speed Sens B Circ Low
    P2161 Vehicle Speed Sens B Interm/Erratic
    P2162 Vehicle Speed Sens A / B Correlation
    P2163 Throttle/Pedal Pos Sens A Maximum Stop Perf
    P2164 Throttle/Pedal Pos Sens B Maximum Stop Perf
    P2165 Throttle/Pedal Pos Sens C Maximum Stop Perf
    P2166 Throttle/Pedal Pos Sens D Maximum Stop Perf
    P2167 Throttle/Pedal Pos Sens E Maximum Stop Perf
    P2168 Throttle/Pedal Pos Sens F Maximum Stop Perf
    P2169 Exhaust Press Regulator Vent Solenoid Ctrl Circ/Open
    P2170 Exhaust Press Regulator Vent Solenoid Ctrl Circ Low
    P2171 Exhaust Press Regulator Vent Solenoid Ctrl Circ Hi
    P2172 Throttle Actuator Ctrl Sys-Sudden Hi Airflow Detected
    P2173 Throttle Actuator Ctrl Sys-Hi Airflow Detected
    P2174 Throttle Actuator Ctrl Sys-Sudden Low Airflow Detected
    P2175 Throttle Actuator Ctrl Sys-Low Airflow Detected
    P2176 Throttle Actuator Ctrl Sys-Idle Pos Not Learned
    P2177 Sys Too Lean Off Idle Bank1
    P2178 Sys Too Rich Off Idle Bank1
    P2179 Sys Too Lean Off Idle Bank2
    P2180 Sys Too Rich Off Idle Bank2
    P2181 Cooling Sys Perf
    P2182 Engine Coolant Temp Sens2 Circ
    P2183 Engine Coolant Temp Sens2 Circ Range/Perf
    P2184 Engine Coolant Temp Sens2 Circ Low
    P2185 Engine Coolant Temp Sens2 Circ Hi
    P2186 Engine Coolant Temp Sens2 Circ Interm/Erratic
    P2187 Sys Too Lean at Idle Bank1
    P2188 Sys Too Rich at Idle Bank1
    P2189 Sys Too Lean at Idle Bank2
    P2190 Sys Too Rich at Idle Bank2
    P2191 Sys Too Lean at Hier Load Bank1
    P2192 Sys Too Rich at Hier Load Bank1
    P2193 Sys Too Lean at Hier Load Bank2
    P2194 Sys Too Rich at Hier Load Bank2
    P2195 O2 Sens Signal Stuck Lean Bank1 Sens1
    P2196 O2 Sens Signal Stuck Rich Bank1 Sens1
    P2197 O2 Sens Signal Stuck Lean Bank2 Sens1
    P2198 O2 Sens Signal Stuck Rich Bank2 Sens1
    P2199 Intake Air Temp Sens1 / 2 Correlation
    P2200 NOx Sens Circ Bank1
    P2201 NOx Sens Circ Range/Perf Bank1
    P2202 NOx Sens Circ Low Input Bank1
    P2203 NOx Sens Circ Hi Input Bank1
    P2204 NOx Sens Circ Interm Input Bank1
    P2205 NOx Sens Heater Ctrl Circ/Open Bank1
    P2206 NOx Sens Heater Ctrl Circ Low Bank1
    P2207 NOx Sens Heater Ctrl Circ Hi Bank1
    P2208 NOx Sens Heater Sense Circ Bank1
    P2209 NOx Sens Heater Sense Circ Range/Perf Bank1
    P2210 NOx Sens Heater Sense Circ Low Input Bank1
    P2211 NOx Sens Heater Sense Circ Hi Input Bank1
    P2212 NOx Sens Heater Sense Circ Interm Bank1
    P2213 NOx Sens Circ Bank2
    P2214 NOx Sens Circ Range/Perf Bank2
    P2215 NOx Sens Circ Low Input Bank2
    P2216 NOx Sens Circ Hi Input Bank2
    P2217 NOx Sens Circ Interm Input Bank2
    P2218 NOx Sens Heater Ctrl Circ/Open Bank2
    P2219 NOx Sens Heater Ctrl Circ Low Bank2
    P2220 NOx Sens Heater Ctrl Circ Hi Bank2
    P2221 NOx Sens Heater Sense Circ Bank2
    P2222 NOx Sens Heater Sense Circ Range/Perf Bank2
    P2223 NOx Sens Heater Sense Circ Low Bank2
    P2224 NOx Sens Heater Sense Circ Hi Bank2
    P2225 NOx Sens Heater Sense Circ Interm Bank2
    P2226 Barometric Press Circ
    P2227 Barometric Press Circ Range/Perf
    P2228 Barometric Press Circ Low
    P2229 Barometric Press Circ Hi
    P2230 Barometric Press Circ Interm
    P2231 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens1
    P2232 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens2
    P2233 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens3
    P2234 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens1
    P2235 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens2
    P2236 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens3
    P2237 O2 Sens Positive Current Ctrl Circ/Open Bank1 Sens1
    P2238 O2 Sens Positive Current Ctrl Circ Low Bank1 Sens1
    P2239 O2 Sens Positive Current Ctrl Circ Hi Bank1 Sens1
    P2240 O2 Sens Positive Current Ctrl Circ/Open Bank2 Sens1
    P2241 O2 Sens Positive Current Ctrl Circ Low Bank2 Sens1
    P2242 O2 Sens Positive Current Ctrl Circ Hi Bank2 Sens1
    P2243 O2 Sens Ref Voltage Circ/Open Bank1 Sens1
    P2244 O2 Sens Ref Voltage Perf Bank1 Sens1
    P2245 O2 Sens Ref Voltage Circ Low Bank1 Sens1
    P2246 O2 Sens Ref Voltage Circ Hi Bank1 Sens1
    P2247 O2 Sens Ref Voltage Circ/Open Bank2 Sens1
    P2248 O2 Sens Ref Voltage Perf Bank2 Sens1
    P2249 O2 Sens Ref Voltage Circ Low Bank2 Sens1
    P2250 O2 Sens Ref Voltage Circ Hi Bank2 Sens1
    P2251 O2 Sens Negative Current Ctrl Circ/Open Bank1 Sens1
    P2252 O2 Sens Negative Current Ctrl Circ Low Bank1 Sens1
    P2253 O2 Sens Negative Current Ctrl Circ Hi Bank1 Sens1
    P2254 O2 Sens Negative Current Ctrl Circ/Open Bank2 Sens1
    P2255 O2 Sens Negative Current Ctrl Circ Low Bank2 Sens1
    P2256 O2 Sens Negative Current Ctrl Circ Hi Bank2 Sens1
    P2257 Sec Air Inj Sys Ctrl A Circ Low
    P2258 Sec Air Inj Sys Ctrl A Circ Hi
    P2259 Sec Air Inj Sys Ctrl B Circ Low
    P2260 Sec Air Inj Sys Ctrl B Circ Hi
    P2261 T/Super Charger Bypass Valve-Mechanical
    P2262 Turbo Boost Press Not Detected-Mechanical
    P2263 T/Super Charger Boost Sys Perf
    P2264 Water in Fuel Sens Circ
    P2265 Water in Fuel Sens Circ Range/Perf
    P2266 Water in Fuel Sens Circ Low
    P2267 Water in Fuel Sens Circ Hi
    P2268 Water in Fuel Sens Circ Interm
    P2269 Water in Fuel Condition
    P2270 O2 Sens Signal Stuck Lean Bank1 Sens2
    P2271 O2 Sens Signal Stuck Rich Bank1 Sens2
    P2272 O2 Sens Signal Stuck Lean Bank2 Sens2
    P2273 O2 Sens Signal Stuck Rich Bank2 Sens2
    P2274 O2 Sens Signal Stuck Lean Bank1 Sens3
    P2275 O2 Sens Signal Stuck Rich Bank1 Sens3
    P2276 O2 Sens Signal Stuck Lean Bank2 Sens3
    P2277 O2 Sens Signal Stuck Rich Bank2 Sens3
    P2278 O2 Sens Signals Swapped Bank1 Sens3 / Bank2 Sens3
    P2279 Intake Air Sys Leak
    P2280 Air Flow Restriction / Air Leak Between Air Filter and MAF
    P2281 Air Leak Between MAF and Throttle Body
    P2282 Air Leak Between Throttle Body and Intake Valves
    P2283 Injector Ctrl Press Sens Circ
    P2284 Injector Ctrl Press Sens Circ Range/Perf
    P2285 Injector Ctrl Press Sens Circ Low
    P2286 Injector Ctrl Press Sens Circ Hi
    P2287 Injector Ctrl Press Sens Circ Interm
    P2288 Injector Ctrl Press Too Hi
    P2289 Injector Ctrl Press Too Hi-Engine Off
    P2290 Injector Ctrl Press Too Low
    P2291 Injector Ctrl Press Too Low-Engine Cranking
    P2292 Injector Ctrl Press Erratic
    P2293 Fuel Press Regulator 2 Perf
    P2294 Fuel Press Regulator 2 Ctrl Circ
    P2295 Fuel Press Regulator 2 Ctrl Circ Low
    P2296 Fuel Press Regulator 2 Ctrl Circ Hi
    P2297 O2 Sens Out of Range During Deceleration Bank1 Sens1
    P2298 O2 Sens Out of Range During Deceleration Bank2 Sens1
    P2299 Brake Pedal Pos / Accelerator Pedal Pos Incompatible
    P2300 Ignition Coil A Primary Ctrl Circ Low
    P2301 Ignition Coil A Primary Ctrl Circ Hi
    P2302 Ignition Coil A Sec Circ
    P2303 Ignition Coil B Primary Ctrl Circ Low
    P2304 Ignition Coil B Primary Ctrl Circ Hi
    P2305 Ignition Coil B Sec Circ
    P2306 Ignition Coil C Primary Ctrl Circ Low
    P2307 Ignition Coil C Primary Ctrl Circ Hi
    P2308 Ignition Coil C Sec Circ
    P2309 Ignition Coil D Primary Ctrl Circ Low
    P2310 Ignition Coil D Primary Ctrl Circ Hi
    P2311 Ignition Coil D Sec Circ
    P2312 Ignition Coil E Primary Ctrl Circ Low
    P2313 Ignition Coil E Primary Ctrl Circ Hi
    P2314 Ignition Coil E Sec Circ
    P2315 Ignition Coil F Primary Ctrl Circ Low
    P2316 Ignition Coil F Primary Ctrl Circ Hi
    P2317 Ignition Coil F Sec Circ
    P2318 Ignition Coil G Primary Ctrl Circ Low
    P2319 Ignition Coil G Primary Ctrl Circ Hi
    P2320 Ignition Coil G Sec Circ
    P2321 Ignition Coil H Primary Ctrl Circ Low
    P2322 Ignition Coil H Primary Ctrl Circ Hi
    P2323 Ignition Coil H Sec Circ
    P2324 Ignition Coil I Primary Ctrl Circ Low
    P2325 Ignition Coil I Primary Ctrl Circ Hi
    P2326 Ignition Coil I Sec Circ
    P2327 Ignition Coil J Primary Ctrl Circ Low
    P2328 Ignition Coil J Primary Ctrl Circ Hi
    P2329 Ignition Coil J Sec Circ
    P2330 Ignition Coil K Primary Ctrl Circ Low
    P2331 Ignition Coil K Primary Ctrl Circ Hi
    P2332 Ignition Coil K Sec Circ
    P2333 Ignition Coil L Primary Ctrl Circ Low
    P2334 Ignition Coil L Primary Ctrl Circ Hi
    P2335 Ignition Coil L Sec Circ
    P2336 Cylinder #1 Above Knock Threshold
    P2337 Cylinder #2 Above Knock Threshold
    P2338 Cylinder #3 Above Knock Threshold
    P2339 Cylinder #4 Above Knock Threshold
    P2340 Cylinder #5 Above Knock Threshold
    P2341 Cylinder #6 Above Knock Threshold
    P2342 Cylinder #7 Above Knock Threshold
    P2343 Cylinder #8 Above Knock Threshold
    P2344 Cylinder #9 Above Knock Threshold
    P2345 Cylinder #10 Above Knock Threshold
    P2346 Cylinder #11 Above Knock Threshold
    P2347 Cylinder #12 Above Knock Threshold
    P2400 EVAP Emission Sys Leak Detection Pump Ctrl Circ/Open
    P2401 EVAP Emission Sys Leak Detection Pump Ctrl Circ Low
    P2402 EVAP Emission Sys Leak Detection Pump Ctrl Circ Hi
    P2403 EVAP Emission Sys Leak Detection Pump Sense Circ/Open
    P2404 EVAP Emission Sys Leak Detection Pump Sense Circ Range/Perf
    P2405 EVAP Emission Sys Leak Detection Pump Sense Circ Low
    P2406 EVAP Emission Sys Leak Detection Pump Sense Circ Hi
    P2407 EVAP Emission Sys Leak Detection Pump Sense Circ Interm/Erratic
    P2408 Fuel Cap Sens/Switch Circ
    P2409 Fuel Cap Sens/Switch Circ Range/Perf
    P2410 Fuel Cap Sens/Switch Circ Low
    P2411 Fuel Cap Sens/Switch Circ Hi
    P2412 Fuel Cap Sens/Switch Circ Interm/Erratic
    P2413 Exhaust Gas Recirculation Sys Perf
    P2414 O2 Sens Exhaust Sample Error Bank1 Sens1
    P2415 O2 Sens Exhaust Sample Error Bank2 Sens1
    P2416 O2 Sens Signals Swapped Bank1 Sens2 / Bank1 Sens3
    P2417 O2 Sens Signals Swapped Bank2 Sens2 / Bank2 Sens3
    P2418 EVAP Emission Sys Switching Val
    Ill_Born_SS Post subject: RE: DODGE CODES Posted: Aug 29, 2008 - 12:54 PM
    P2419 EVAP Emission Sys Switching Valve Ctrl Circ Low
    P2420 EVAP Emission Sys Switching Valve Ctrl Circ Hi
    P2421 EVAP Emission Sys Vent Valve Stuck Open
    P2422 EVAP Emission Sys Vent Valve Stuck Closed
    P2423 HC Adsorption Catalyst Eff Below Threshold Bank1
    P2424 HC Adsorption Catalyst Eff Below Threshold Bank2
    P2425 Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
    P2426 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
    P2427 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Hi
    P2428 Exhaust Gas Temp Too Hi Bank1
    P2429 Exhaust Gas Temp Too Hi Bank2
    P2430 Sec Air Inj Sys Air Flow/Press Sens Circ Bank1
    P2431 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank1
    P2432 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank1
    P2433 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank1
    P2434 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank1
    P2435 Sec Air Inj Sys Air Flow/Press Sens Circ Bank2
    P2436 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank2
    P2437 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank2
    P2438 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank2
    P2439 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank2
    P2440 Sec Air Inj Sys Switching Valve Stuck Open Bank1
    P2441 Sec Air Inj Sys Switching Valve Stuck Closed Bank1
    P2442 Sec Air Inj Sys Switching Valve Stuck Open Bank2
    P2443 Sec Air Inj Sys Switching Valve Stuck Closed Bank2
    P2444 Sec Air Inj Sys Pump Stuck On Bank1
    P2445 Sec Air Inj Sys Pump Stuck Off Bank1
    P2446 Sec Air Inj Sys Pump Stuck On Bank2
    P2447 Sec Air Inj Sys Pump Stuck Off Bank2
    P2500 Generator Lamp/L-Terminal Circ Low
    P2501 Generator Lamp/L-Terminal Circ Hi
    P2502 Charging Sys Output Voltage
    P2503 Charging Sys Output Voltage Low
    P2504 Charging Sys Output Voltage Hi
    P2505 ECM/PCM Power Input Signal
    P2506 ECM/PCM Power Input Signal Range/Perf
    P2507 ECM/PCM Power Input Signal Low
    P2508 ECM/PCM Power Input Signal Hi
    P2509 CM/PCM Power Input Signal Interm
    P2510 ECM/PCM Power Relay Sense Circ Range/Perf
    P2511 ECM/PCM Power Relay Sense Circ Interm
    P2512 Event Data Recorder Request Circ/ Open
    P2513 Event Data Recorder Request Circ Low
    P2514 Event Data Recorder Request Circ Hi
    P2515 A/C Refrigerant Press Sens B Circ
    P2516 A/C Refrigerant Press Sens B Circ Range/Perf
    P2517 A/C Refrigerant Press Sens B Circ Low
    P2518 A/C Refrigerant Press Sens B Circ Hi
    P2519 A/C Request A Circ
    P2520 A/C Request A Circ Low
    P2521 A/C Request A Circ Hi
    P2522 A/C Request B Circ
    P2523 A/C Request B Circ Low
    P2524 A/C Request B Circ Hi
    P2525 Vacuum Reservoir Press Sens Circ
    P2526 Vacuum Reservoir Press Sens Circ Range/Perf
    P2527 Vacuum Reservoir Press Sens Circ Low
    P2528 Vacuum Reservoir Press Sens Circ Hi
    P2529 Vacuum Reservoir Press Sens Circ Interm
    P2530 Ignition Switch Run Pos Circ
    P2531 Ignition Switch Run Pos Circ Low
    P2532 Ignition Switch Run Pos Circ Hi
    P2533 Ignition Switch Run/Start Pos Circ
    P2534 Ignition Switch Run/Start Pos Circ Low
    P2535 Ignition Switch Run/Start Pos Circ Hi
    P2536 Ignition Switch Accessory Pos Circ
    P2537 Ignition Switch Accessory Pos Circ Low
    P2538 Ignition Switch Accessory Pos Circ Hi
    P2539 Low Press Fuel Sys Sens Circ
    P2540 Low Press Fuel Sys Sens Circ Range/Perf
    P2541 Low Press Fuel Sys Sens Circ Low
    P2542 Low Press Fuel Sys Sens Circ Hi
    P2543 Low Press Fuel Sys Sens Circ Interm
    P2544 Torque Management Request Input Signal A
    P2545 Torque Management Request Input Signal A Range/Perf
    P2546 Torque Management Request Input Signal A Low
    P2547 Torque Management Request Input Signal A Hi
    P2548 Torque Management Request Input Signal B
    P2549 Torque Management Request Input Signal B Range/Perf
    P2550 Torque Management Request Input Signal B Low
    P2551 Torque Management Request Input Signal B Hi
    P2552 Throttle/Fuel Inhibit Circ
    P2553 Throttle/Fuel Inhibit Circ Range/Perf
    P2554 Throttle/Fuel Inhibit Circ Low
    P2555 Throttle/Fuel Inhibit Circ Hi
    P2556 Engine Coolant Level Sens/Switch Circ
    P2557 Engine Coolant Level Sens/Switch Circ Range/Perf
    P2558 Engine Coolant Level Sens/Switch Circ Low
    P2559 Engine Coolant Level Sens/Switch Circ Hi
    P2560 Engine Coolant Level Low
    P2561 A/C Ctrl Mod Requested MIL Illumination
    P2562 Turbocharger Boost Ctrl Pos Sens Circ
    P2563 Turbocharger Boost Ctrl Pos Sens Circ Range/Perf
    P2564 Turbocharger Boost Ctrl Pos Sens Circ Low
    P2565 Turbocharger Boost Ctrl Pos Sens Circ Hi
    P2566 Turbocharger Boost Ctrl Pos Sens Circ Interm
    P2567 Direct Ozone Reduction Catalyst Temp Sens Circ
    P2568 Direct Ozone Reduction Catalyst Temp Sens Circ Range/Perf
    P2569 Direct Ozone Reduction Catalyst Temp Sens Circ Low
    P2570 Direct Ozone Reduction Catalyst Temp Sens Circ Hi
    P2571 Direct Ozone Reduction Catalyst Temp Sens Circ Interm/Erratic
    P2572 Direct Ozone Reduction Catalyst Deterioration Sens Circ
    P2573 Direct Ozone Reduction Catalyst Deterioration Sens Circ Range/Perf
    P2574 Direct Ozone Reduction Catalyst Deterioration Sens Circ Low
    P2575 Direct Ozone Reduction Catalyst Deterioration Sens Circ Hi
    P2576 Direct Ozone Reduction Catalyst Deterioration Sens Circ Interm/Erratic
    P2577 Direct Ozone Reduction Catalyst Eff Below Threshold
    P2600 Coolant Pump Ctrl Circ/Open
    P2601 Coolant Pump Ctrl Circ Range/Perf
    P2602 Coolant Pump Ctrl Circ Low
    P2603 Coolant Pump Ctrl Circ Hi
    P2604 Intake Air Heater A Circ Range/Perf
    P2605 Intake Air Heater A Circ/Open
    P2606 Intake Air Heater B Circ Range/Perf
    P2607 Intake Air Heater Relay 2 Low
    P2608 Intake Air Heater Relay 2 Hi
    P2609 Intake Air Heater Sys Perf
    P2610 ECM/PCM Internal Engine Off Timer Perf
    P2611 A/C Refrigerant Distribution Valve Ctrl Circ/Open
    P2612 A/C Refrigerant Distribution Valve Ctrl Circ Low
    P2613 A/C Refrigerant Distribution Valve Ctrl Circ Hi
    P2614 Camshaft Pos Signal Output Circ/Open
    P2615 Camshaft Pos Signal Output Circ Low
    P2616 Camshaft Pos Signal Output Circ Hi
    P2617 Crank Pos Signal Output Circ/Open
    P2618 Crank Pos Signal Output Circ Low
    P2619 Crank Pos Signal Output Circ Hi
    P2620 Throttle Pos Output Circ/Open
    P2621 Throttle Pos Output Circ Low
    P2622 Throttle Pos Output Circ Hi
    P2623 Injector Ctrl Press Regulator Circ/Open
    P2624 Injector Ctrl Press Regulator Circ Low
    P2625 Injector Ctrl Press Regulator Circ Hi
    P2626 O2 Sens Pumping Current Trim Circ/Open Bank1 Sens1
    P2627 O2 Sens Pumping Current Trim Circ Low Bank1 Sens1
    P2628 O2 Sens Pumping Current Trim Circ Hi Bank1 Sens1
    P2629 O2 Sens Pumping Current Trim Circ/Open Bank2 Sens1
    P2630 O2 Sens Pumping Current Trim Circ Low Bank2 Sens1
    P2631 O2 Sens Pumping Current Trim Circ Hi Bank2 Sens1
    P2632 Fuel Pump B Ctrl Circ /Open
    P2633 Fuel Pump B Ctrl Circ Low
    P2634 Fuel Pump B Ctrl Circ Hi
    P2635 Fuel Pump A Low Flow / Perf
    P2636 Fuel Pump B Low Flow / Perf
    P2637 Torque Management Feedback Signal A
    P2638 Torque Management Feedback Signal A Range/Perf
    P2639 Torque Management Feedback Signal A Low
    P2640 Torque Management Feedback Signal A Hi
    P2641 Torque Management Feedback Signal B
    P2642 Torque Management Feedback Signal B Range/Perf
    P2643 Torque Management Feedback Signal B Low
    P2644 Torque Management Feedback Signal B Hi
    P2645 A Rocker Arm Actuator Ctrl Circ/Open Bank1
    P2646 A Rocker Arm Actuator Sys Perf or Stuck Off Bank1
    P2647 A Rocker Arm Actuator Sys Stuck On Bank1
    P2648 A Rocker Arm Actuator Ctrl Circ Low Bank1
    P2649 A Rocker Arm Actuator Ctrl Circ Hi Bank1
    P2650 B Rocker Arm Actuator Ctrl Circ/Open Bank1
    P2651 B Rocker Arm Actuator Sys Perf or Stuck Off Bank1
    P2652 B Rocker Arm Actuator Sys Stuck On Bank1
    P2653 B Rocker Arm Actuator Ctrl Circ Low Bank1
    P2654 B Rocker Arm Actuator Ctrl Circ Hi Bank1
    P2655 A Rocker Arm Actuator Ctrl Circ/Open Bank2
    P2656 A Rocker Arm Actuator Sys Perf or Stuck Off Bank2
    P2657 A Rocker Arm Actuator Sys Stuck On Bank2
    P2658 A Rocker Arm Actuator Ctrl Circ Low Bank2
    P2659 A Rocker Arm Actuator Ctrl Circ Hi Bank2
    P2660 B Rocker Arm Actuator Ctrl Circ/Open Bank2
    P2661 B Rocker Arm Actuator Sys Perf or Stuck Off Bank2
    P2662 B Rocker Arm Actuator Sys Stuck On Bank2
    P2663 B Rocker Arm Actuator Ctrl Circ Low Bank2
    P2664 B Rocker Arm Actuator Ctrl Circ Hi Bank2
    P2665 Fuel Shutoff Valve B Ctrl Circ/Open
    P2666 Fuel Shutoff Valve B Ctrl Circ Low
    P2667 Fuel Shutoff Valve B Ctrl Circ Hi
    P2668 Fuel Mode Indicator Lamp Ctrl Circ
    P2669 Actuator Supply Voltage B Circ /Open
    P2670 Actuator Supply Voltage B Circ Low
    P2671 Actuator Supply Voltage B Circ Hi
    P2700 Trans Friction Element A Apply Time Range/Perf
    P2701 Trans Friction Element B Apply Time Range/Perf
    P2702 Trans Friction Element C Apply Time Range/Perf
    P2703 Trans Friction Element D Apply Time Range/Perf
    P2704 Trans Friction Element E Apply Time Range/Perf
    P2705 Trans Friction Element F Apply Time Range/Perf
    P2706 Shift Solenoid F
    P2707 Shift Solenoid F Perf or Stuck Off
    P2708 Shift Solenoid F Stuck On
    P2709 Shift Solenoid F Electrical
    P2710 Shift Solenoid F Interm
    P2711 Unexpected Mechanical Gear Disengagement
    P2712 Hydraulic Power Unit Leakage
    P2713 Press Ctrl Solenoid D
    P2714 Press Ctrl Solenoid D Perf or Stuck Off
    P2715 Press Ctrl Solenoid D Stuck On
    P2716 Press Ctrl Solenoid D Electrical
    P2717 Press Ctrl Solenoid D Interm
    P2718 Press Ctrl Solenoid D Ctrl Circ / Open
    P2719 Press Ctrl Solenoid D Ctrl Circ Range/Perf
    P2720 Press Ctrl Solenoid D Ctrl Circ Low
    P2721 Press Ctrl Solenoid D Ctrl Circ Hi
    P2722 Press Ctrl Solenoid E
    P2723 Press Ctrl Solenoid E Perf or Stuck Off
    P2724 Press Ctrl Solenoid E Stuck On
    P2725 Press Ctrl Solenoid E Electrical
    P2726 Press Ctrl Solenoid E Interm
    P2727 Press Ctrl Solenoid E Ctrl Circ / Open
    P2728 Press Ctrl Solenoid E Ctrl Circ Range/Perf
    P2729 Press Ctrl Solenoid E Ctrl Circ Low
    P2730 Press Ctrl Solenoid E Ctrl Circ Hi
    P2731 Press Ctrl Solenoid F
    P2732 Press Ctrl Solenoid F Perf or Stuck Off
    P2733 Press Ctrl Solenoid F Stuck On
    P2734 Press Ctrl Solenoid F Electrical
    P2735 Press Ctrl Solenoid F Interm
    P2736 Press Ctrl Solenoid F Ctrl Circ/Open
    P2737 Press Ctrl Solenoid F Ctrl Circ Range/Perf
    P2738 Press Ctrl Solenoid F Ctrl Circ Low
    P2739 Press Ctrl Solenoid F Ctrl Circ Hi
    P2740 Trans Fluid Temp Sens B Circ
    P2741 Trans Fluid Temp Sens B Circ Range Perf
    P2742 Trans Fluid Temp Sens B Circ Low
    P2743 Trans Fluid Temp Sens B Circ Hi
    P2744 Trans Fluid Temp Sens B Circ Interm
    P2745 Intermediate Shaft Speed Sens B Circ
    P2746 Intermediate Shaft Speed Sens B Circ Range/Perf
    P2747 Intermediate Shaft Speed Sens B Circ No Signal
    P2748 Intermediate Shaft Speed Sens B Circ Interm
    P2749 Intermediate Shaft Speed Sens C Circ
    P2750 Intermediate Shaft Speed Sens C Circ Range/Perf
    P2751 Intermediate Shaft Speed Sens C Circ No Signal
    P2752 Intermediate Shaft Speed Sens C Circ Interm
    P2753 Trans Fluid Cooler Ctrl Circ/Open
    P2754 Trans Fluid Cooler Ctrl Circ Low
    P2755 Trans Fluid Cooler Ctrl Circ Hi
    P2756 Torque Conv Clutch Press Ctrl Solenoid
    P2757 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Perf or Stuck Off
    P2758 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Stuck On
    P2759 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Electrical
    P2760 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Interm
    P2761 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ/Open
    P2762 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Range/Perf
    P2763 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Hi
    P2764 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Low
    P2765 Input/Turbine Speed Sens B Circ
    P2766 Input/Turbine Speed Sens B Circ Range/Perf
    P2767 Input/Turbine Speed Sens B Circ No Signal
    P2768 Input/Turbine Speed Sens B Circ Interm
    P2769 Torque Conv Clutch Circ Low
    P2770 Torque Conv Clutch Circ Hi
    P2771 Four Wheel Drive (4WD) Low Switch Circ
    P2772 Four Wheel Drive (4WD) Low Switch Circ Range/Perf
    P2773 Four Wheel Drive (4WD) Low Switch Circ Low
    P2774 Four Wheel Drive (4WD) Low Switch Circ Hi
    P2775 Upshift Switch Circ Range/Perf
    P2776 Upshift Switch Circ Low
    P2777 Upshift Switch Circ Hi
    P2778 Upshift Switch Circ Interm/Erratic
    P2779 Downshift Switch Circ Range/Perf
    P2780 Downshift Switch Circ Low
    P2781 Downshift Switch Circ Hi
    P2782 Downshift Switch Circ Interm/Erratic
    P2783 Torque Conv Temp Too Hi
    P2784 Input/Turbine Speed Sens A/B Correlation
    P2785 Clutch Actuator Temp Too Hi
    P2786 Gear Shift Actuator Temp Too Hi
    P2787 Clutch Temp Too Hi
    P2788 Auto Shift Manual Adaptive Learning at Limit
    P2789 Clutch Adaptive Learning at Limit
    P2790 Gate Select Direction Circ
    P2791 Gate Select Direction Circ Low
    P2792 Gate Select Direction Circ Hi
    P2793 Gear Shift Direction Circ
    P2794 Gear Shift Direction Circ Low
    P2795 Gear Shift Direction Circ Hi
    P2A00 O2 Sens Circ Range/Perf Bank1 Sens1
    P2A01 O2 Sens Circ Range/Perf Bank1 Sens2
    P2A02 O2 Sens Circ Range/Perf Bank1 Sens3
    P2A03 O2 Sens Circ Range/Perf Bank2 Sens1
    P2A04 O2 Sens Circ Range/Perf Bank2 Sens2
    P2A05 O2 Sens Circ Range/Perf Bank2 Sens3
    P3400 Cylinder Deactivation Sys Bank1
    P3401 Cylinder 1 Deactivation/Intake Valve Ctrl Circ/Open
    P3402 Cylinder 1 Deactivation/Intake Valve Ctrl Perf
    P3403 Cylinder 1 Deactivation/Intake Valve Ctrl Circ Low
    P3404 Cylinder 1 Deactivation/Intake Valve Ctrl Circ Hi
    P3405 Cylinder 1 Exhaust Valve Ctrl Circ/Open
    P3406 Cylinder 1 Exhaust Valve Ctrl Perf
    P3407 Cylinder 1 Exhaust Valve Ctrl Circ Low
    P3408 Cylinder 1 Exhaust Valve Ctrl Circ Hi
    P3409 Cylinder 2 Deactivation/Intake Valve Ctrl Circ/Open
    P3410 Cylinder 2 Deactivation/Intake Valve Ctrl Perf
    P3411 Cylinder 2 Deactivation/Intake Valve Ctrl Circ Low
    P3412 Cylinder 2 Deactivation/Intake Valve Ctrl Circ Hi
    P3413 Cylinder 2 Exhaust Valve Ctrl Circ/Open
    P3414 Cylinder 2 Exhaust Valve Ctrl Perf
    P3415 Cylinder 2 Exhaust Valve Ctrl Circ Low
    P3416 Cylinder 2 Exhaust Valve Ctrl Circ Hi
    P3417 Cylinder 3 Deactivation/Intake Valve Ctrl Circ/Open
    P3418 Cylinder 3 Deactivation/Intake Valve Ctrl Perf
    P3419 Cylinder 3 Deactivation/Intake Valve Ctrl Circ Low
    P3420 Cylinder 3 Deactivation/Intake Valve Ctrl Circ Hi
    P3421 Cylinder 3 Exhaust Valve Ctrl Circ/Open
    P3422 Cylinder 3 Exhaust Valve Ctrl Perf
    P3423 Cylinder 3 Exhaust Valve Ctrl Circ Low
    P3424 Cylinder 3 Exhaust Valve Ctrl Circ Hi
    P3425 Cylinder 4 Deactivation/Intake Valve Ctrl Circ/Open
    P3426 Cylinder 4 Deactivation/Intake Valve Ctrl Perf
    P3427 Cylinder 4 Deactivation/Intake Valve Ctrl Circ Low
    P3428 Cylinder 4 Deactivation/Intake Valve Ctrl Circ Hi
    P3429 Cylinder 4 Exhaust Valve Ctrl Circ/Open
    P3430 Cylinder 4 Exhaust Valve Ctrl Perf
    P3431 Cylinder 4 Exhaust Valve Ctrl Circ Low
    P3432 Cylinder 4 Exhaust Valve Ctrl Circ Hi
    P3433 Cylinder 5 Deactivation/Intake Valve Ctrl Circ/Open
    P3434 Cylinder 5 Deactivation/Intake Valve Ctrl Perf
    P3435 Cylinder 5 Deactivation/Intake Valve Ctrl Circ Low
    P3436 Cylinder 5 Deactivation/Intake Valve Ctrl Circ Hi
    P3437 Cylinder 5 Exhaust Valve Ctrl Circ/Open
    P3438 Cylinder 5 Exhaust Valve Ctrl Perf
    P3439 Cylinder 5 Exhaust Valve Ctrl Circ Low
    P3440 Cylinder 5 Exhaust Valve Ctrl Circ Hi
    P3441 Cylinder 6 Deactivation/Intake Valve Ctrl Circ/Open
    P3442 Cylinder 6 Deactivation/Intake Valve Ctrl Perf
    P3443 Cylinder 6 Deactivation/Intake Valve Ctrl Circ Low
    P3444 Cylinder 6 Deactivation/Intake Valve Ctrl Circ Hi
    P3445 Cylinder 6 Exhaust Valve Ctrl Circ/Open
    P3446 Cylinder 6 Exhaust Valve Ctrl Perf
    P3447 Cylinder 6 Exhaust Valve Ctrl Circ Low
    P3448 Cylinder 6 Exhaust Valve Ctrl Circ Hi
    P3449 Cylinder 7 Deactivation/Intake Valve Ctrl Circ/Open
    P3450 Cylinder 7 Deactivation/Intake Valve Ctrl Perf
    P3451 Cylinder 7 Deactivation/Intake Valve Ctrl Circ Low
    P3452 Cylinder 7 Deactivation/Intake Valve Ctrl Circ Hi
    P3453 Cylinder 7 Exhaust Valve Ctrl Circ/Open
    P3454 Cylinder 7 Exhaust Valve Ctrl Perf
    P3455 Cylinder 7 Exhaust Valve Ctrl Circ Low
    P3456 Cylinder 7 Exhaust Valve Ctrl Circ Hi
    P3457 Cylinder 8 Deactivation/Intake Valve Ctrl Circ/Open
    P3458 Cylinder 8 Deactivation/Intake Valve Ctrl Perf
    P3459 Cylinder 8 Deactivation/Intake Valve Ctrl Circ Low
    P3460 Cylinder 8 Deactivation/Intake Valve Ctrl Circ Hi
    P3461 Cylinder 8 Exhaust Valve Ctrl Circ/Open
    P3462 Cylinder 8 Exhaust Valve Ctrl Perf
    P3463 Cylinder 8 Exhaust Valve Ctrl Circ Low
    P3464 Cylinder 8 Exhaust Valve Ctrl Circ Hi
    P3465 Cylinder 9 Deactivation/Intake Valve Ctrl Circ/Open
    P3466 Cylinder 9 Deactivation/Intake Valve Ctrl Perf
    P3467 Cylinder 9 Deactivation/Intake Valve Ctrl Circ Low
    P3468 Cylinder 9 Deactivation/Intake Valve Ctrl Circ Hi
    P3469 Cylinder 9 Exhaust Valve Ctrl Circ/Open
    P3470 Cylinder 9 Exhaust Valve Ctrl Perf
    P3471 Cylinder 9 Exhaust Valve Ctrl Circ Low
    P3472 Cylinder 9 Exhaust Valve Ctrl Circ Hi
    P3473 Cylinder 10 Deactivation/Intake Valve Ctrl Circ/Open
    P3474 Cylinder 10 Deactivation/Intake Valve Ctrl Perf
    P3475 Cylinder 10 Deactivation/Intake Valve Ctrl Circ Low
    P3476 Cylinder 10 Deactivation/Intake Valve Ctrl Circ Hi
    P3477 Cylinder 10 Exhaust Valve Ctrl Circ/Open
    P3478 Cylinder 10 Exhaust Valve Ctrl Perf
    P3479 Cylinder 10 Exhaust Valve Ctrl Circ Low
    P3480 Cylinder 10 Exhaust Valve Ctrl Circ Hi
    P3481 Cylinder 11 Deactivation/Intake Valve Ctrl Circ/Open
    P3482 Cylinder 11 Deactivation/Intake Valve Ctrl Perf
    P3483 Cylinder 11 Deactivation/Intake Valve Ctrl Circ Low
    P3484 Cylinder 11 Deactivation/Intake Valve Ctrl Circ Hi
    P3485 Cylinder 11 Exhaust Valve Ctrl Circ/Open
    P3486 Cylinder 11 Exhaust Valve Ctrl Perf
    P3487 Cylinder 11 Exhaust Valve Ctrl Circ Low
    P3488 Cylinder 11 Exhaust Valve Ctrl Circ Hi
    P3489 Cylinder 12 Deactivation/Intake Valve Ctrl Circ/Open
    P3490 Cylinder 12 Deactivation/Intake Valve Ctrl Perf
    P3491 Cylinder 12 Deactivation/Intake Valve Ctrl Circ Low
    P3492 Cylinder 12 Deactivation/Intake Valve Ctrl Circ Hi
    P3493 Cylinder 12 Exhaust Valve Ctrl Circ/Open
    U0001 Hi Speed CAN Comm Bus
    U0002 Hi Speed CAN Comm Bus Perf
    U0003 Hi Speed CAN Comm Bus + Open
    U0004 Hi Speed CAN Comm Bus + Low
    U0005 Hi Speed CAN Comm Bus + H
    U0006 Hi Speed CAN Comm Bus - Open
    U0007 Hi Speed CAN Comm Bus - Low
    U0008 Hi Speed CAN Comm Bus - Hi
    U0009 Hi Speed CAN Comm Bus - shorted to Bus +
    U0010 Medium Speed CAN Comm Bus
    U0011 Medium Speed CAN Comm Bus Perf
    U0012 Medium Speed CAN Comm Bus + Open
    U0013 Medium Speed CAN Comm Bus + Low
    U0014 Medium Speed CAN Comm Bus + Hi
    U0015 Medium Speed CAN Comm Bus - Open
    U0016 Medium Speed CAN Comm Bus - Low
    U0017 Medium Speed CAN Comm Bus - Hi
    U0018 Medium Speed CAN Comm Bus - shorted to Bus +
    U0019 Low Speed CAN Comm Bus
    U0020 Low Speed CAN Comm Bus Perf
    U0021 Low Speed CAN Comm Bus + Open
    U0022 Low Speed CAN Comm Bus + Low
    U0023 Low Speed CAN Comm Bus + Hi
    U0024 Low Speed CAN Comm Bus - Open
    U0025 Low Speed CAN Comm Bus - Low
    U0026 Low Speed CAN Comm Bus - Hi
    U0027 Low Speed CAN Comm Bus - shorted to Bus +
    U0028 Vehicle Comm Bus A
    U0029 Vehicle Comm Bus A Perf
    U0030 Vehicle Comm Bus A + Open
    U0031 Vehicle Comm Bus A + Low
    U0032 Vehicle Comm Bus A + Hi
    U0033 Vehicle Comm Bus A - Open
    U0034 Vehicle Comm Bus A - Low
    U0035 Vehicle Comm Bus A - Hi
    U0036 Vehicle Comm Bus A - shorted to Bus A +
    U0037 Vehicle Comm Bus B
    U0038 Vehicle Comm Bus B Perf
    U0039 Vehicle Comm Bus B + Open
    U0040 Vehicle Comm Bus B + Low
    U0041 Vehicle Comm Bus B + Hi
    U0042 Vehicle Comm Bus B - Open
    U0043 Vehicle Comm Bus B - Low
    U0044 Vehicle Comm Bus B - Hi
    U0045 Vehicle Comm Bus B - shorted to Bus B +
    U0046 Vehicle Comm Bus C
    U0047 Vehicle Comm Bus C Perf
    U0048 Vehicle Comm Bus C + Open
    U0049 Vehicle Comm Bus C + Low
    U0050 Vehicle Comm Bus C + Hi
    U0051 Vehicle Comm Bus C - Open
    U0052 Vehicle Comm Bus C - Low
    U0053 Vehicle Comm Bus C - Hi
    U0054 Vehicle Comm Bus C - shorted to Bus C +
    U0055 Vehicle Comm Bus D
    U0056 Vehicle Comm Bus D Perf
    U0057 Vehicle Comm Bus D + Open
    U0058 Vehicle Comm Bus D + Low
    U0059 Vehicle Comm Bus D + Hi
    U0060 Vehicle Comm Bus D - Open
    U0061 Vehicle Comm Bus D - Low
    U0062 Vehicle Comm Bus D - Hi
    U0063 Vehicle Comm Bus D - shorted to Bus D +
    U0064 Vehicle Comm Bus E
    U0065 Vehicle Comm Bus E Perf
    U0066 Vehicle Comm Bus E + Open
    U0067 Vehicle Comm Bus E + Low
    U0068 Vehicle Comm Bus E + Hi
    U0069 Vehicle Comm Bus E - Open
    U0070 Vehicle Comm Bus E - Low
    U0071 Vehicle Comm Bus E - Hi
    U0072 Vehicle Comm Bus E - shorted to Bus E +
    U0073 Ctrl Mod Comm Bus Off
    U0100 Lost Comm with ECM/PCM A
    U0101 Lost Comm with TCM
    U0102 Lost Comm with Transfer Case Ctrl Mod
    U0103 Lost Comm with Gear Shift Mod
    U0104 Lost Comm with Cruise Ctrl Mod
    U0105 Lost Comm with Fuel Injector Ctrl Mod
    U0106 Lost Comm with Glow Plug Ctrl Mod
    U0107 Lost Comm with Throttle Actuator Ctrl Mod
    U0108 Lost Comm with Alternative Fuel Ctrl Mod
    U0109 Lost Comm with Fuel Pump Ctrl Mod
    U0110 Lost Comm with Drive Motor Ctrl Mod
    U0111 Lost Comm with Battery Energy Ctrl Mod A
    U0112 Lost Comm with Battery Energy Ctrl Mod B
    U0113 Lost Comm with Emissions Critical Ctrl Information
    U0114 Lost Comm with 4-Wheel Drive Clutch Ctrl Mod
    U0115 Lost Comm with ECM/PCM B
    U0121 Lost Comm with ABS (ABS) Ctrl Mod
    U0122 Lost Comm with Vehicle Dynamics Ctrl Mod
    U0123 Lost Comm with Yaw Rate Sens Mod
    U0124 Lost Comm with Lateral Acceleration Sens Mod
    U0125 Lost Comm with Multi-axis Acceleration Sens Mod
    U0126 Lost Comm with Steering Angle Sens Mod
    U0127 Lost Comm with Tire Press Monitor Mod
    U0128 Lost Comm with Park Brake Ctrl Mod
    U0129 Lost Comm with Brake Sys Ctrl Mod
    U0130 Lost Comm with Steering Effort Ctrl Mod
    U0131 Lost Comm with Power Steering Ctrl Mod
    U0132 Lost Comm with Ride Level Ctrl Mod
    U0133 Reserved by Document
    U0134 Reserved by Document
    U0135 Reserved by Document
    U0136 Reserved by Document
    U0137 Reserved by Document
    U0138 Reserved by Document
    U0139 Reserved by Document
    U0140 Lost Comm with Body Ctrl Mod
    U0141 Lost Comm with Body Ctrl Mod A
    U0142 Lost Comm with Body Ctrl Mod B
    U0143 Lost Comm with Body Ctrl Mod C
    U0144 Lost Comm with Body Ctrl Mod D
    U0145 Lost Comm with Body Ctrl Mod E
    U0146 Lost Comm with Gateway A
    U0147 Lost Comm with Gateway B
    U0148 Lost Comm with Gateway C
    U0149 Lost Comm with Gateway D
    U0150 Lost Comm with Gateway E
    U0151 Lost Comm with Restraints Ctrl Mod
    U0152 Lost Comm with Side Restraints Ctrl Mod Left
    U0153 Lost Comm with Side Restraints Ctrl Mod Right
    U0154 Lost Comm with Restraints Occupant Sensing Ctrl Mod
    U0155 Lost Comm with Instrument Panel Cluster Ctrl Mod
    U0156 Lost Comm with Information Center A
    U0157 Lost Comm with Information Center B
    U0158 Lost Comm with Head Up Display
    U0159 Lost Comm with Parking Assist Ctrl Mod
    U0160 Lost Comm with Audible Alert Ctrl Mod
    U0161 Lost Comm with Compass Mod
    U0162 Lost Comm with Navigation Display Mod
    U0163 Lost Comm with Navigation Ctrl Mod
    U0164 Lost Comm with HVAC Ctrl Mod
    U0165 Lost Comm with HVAC Ctrl Mod Rear
    U0166 Lost Comm with Auxiliary Heater Ctrl Mod
    U0167 Lost Comm with Vehicle Immobilizer Ctrl Mod
    U0168 Lost Comm with Vehicle Security Ctrl Mod
    U0169 Lost Comm with Sunroof Ctrl Mod
    U0170 Lost Comm with Restraints Sys Sens A
    U0171 Lost Comm with Restraints Sys Sens B
    U0172 Lost Comm with Restraints Sys Sens C
    U0173 Lost Comm with Restraints Sys Sens D
    U0174 Lost Comm with Restraints Sys Sens E
    U0175 Lost Comm with Restraints Sys Sens F
    U0176 Lost Comm with Restraints Sys Sens G
    U0177 Lost Comm with Restraints Sys Sens H
    U0178 Lost Comm with Restraints Sys Sens I
    U0179 Lost Comm with Restraints Sys Sens J
    U0180 Lost Comm with Automatic Lighting Ctrl Mod
    U0181 Lost Comm with Headlamp Leveling Ctrl Mod
    U0182 Lost Comm with Lighting Ctrl Mod Front
    U0183 Lost Comm with Lighting Ctrl Mod Rear
    U0184 Lost Comm with Radio
    U0185 Lost Comm with Antenna Ctrl Mod
    U0186 Lost Comm with Audio Amplifier
    U0187 Lost Comm with Digital Disc Player/Changer Mod A
    U0188 Lost Comm with Digital Disc Player/Changer Mod B
    U0189 Lost Comm with Digital Disc Player/Changer Mod C
    U0190 Lost Comm with Digital Disc Player/Changer Mod D
    U0191 Lost Comm with Television
    U0192 Lost Comm with Personal Computer
    U0193 Lost Comm with Digital Audio Ctrl Mod A
    U0194 Lost Comm with Digital Audio Ctrl Mod B
    U0195 Lost Comm with Subscription Entertainment Rcvr Mod
    U0196 Lost Comm with Rear Seat Entertainment Ctrl Mod
    U0197 Lost Comm with Telephone Ctrl Mod
    U0198 Lost Comm with Telematic Ctrl Mod
    U0199 Lost Comm with Door Ctrl Mod A
    U0200 Lost Comm with Door Ctrl Mod B
    U0201 Lost Comm with Door Ctrl Mod C
    U0202 Lost Comm with Door Ctrl Mod D
    U0203 Lost Comm with Door Ctrl Mod E
    U0204 Lost Comm with Door Ctrl Mod F
    U0205 Lost Comm with Door Ctrl Mod G
    U0206 Lost Comm with Folding Top Ctrl Mod
    U0207 Lost Comm with Moveable Roof Ctrl Mod
    U0208 Lost Comm with Seat Ctrl Mod A
    U0209 Lost Comm with Seat Ctrl Mod B
    U0210 Lost Comm with Seat Ctrl Mod C
    U0211 Lost Comm with Seat Ctrl Mod D
    U0212 Lost Comm with Steering Column Ctrl Mod
    U0213 Lost Comm with Mirror Ctrl Mod
    U0214 Lost Comm with Remote Function Actuation
    U0215 Lost Comm with Door Switch A
    U0216 Lost Comm with Door Switch B
    U0217 Lost Comm with Door Switch C
    U0218 Lost Comm with Door Switch D
    U0219 Lost Comm with Door Switch E
    U0220 Lost Comm with Door Switch F
    U0221 Lost Comm with Door Switch G
    U0222 Lost Comm with Door Window Motor A
    U0223 Lost Comm with Door Window Motor B
    U0224 Lost Comm with Door Window Motor C
    U0225 Lost Comm with Door Window Motor D
    U0226 Lost Comm with Door Window Motor E
    U0227 Lost Comm with Door Window Motor F
    U0228 Lost Comm with Door Window Motor G
    U0229 Lost Comm with Heated Steering Wheel Mod
    U0230 Lost Comm with Rear Gate Mod
    U0231 Lost Comm with Rain Sensing Mod
    U0232 Lost Comm with Side Obstacle Detection Ctrl Mod Left
    U0233 Lost Comm with Side Obstacle Detection Ctrl Mod Right
    U0234 Lost Comm with Convenience Recall Mod
    U0235 Lost Comm with Cruise Ctrl Front Distance Range Sens
    U0300 Internal Ctrl Mod Software Incompatibility
    U0301 Software Incompatibility with ECM/PCM
    U0302 Software Incompatibility with Trans Ctrl Mod
    U0303 Software Incompatibility with Transfer Case Ctrl Mod
    U0304 Software Incompatibility with Gear Shift Ctrl Mod
    U0305 Software Incompatibility with Cruise Ctrl Mod
    U0306 Software Incompatibility with Fuel Injector Ctrl Mod
    U0307 Software Incompatibility with Glow Plug Ctrl Mod
    U0308 Software Incompatibility with Throttle Actuator Ctrl Mod
    U0309 Software Incompatibility with Alternative Fuel Ctrl Mod
    U0310 Software Incompatibility with Fuel Pump Ctrl Mod
    U0311 Software Incompatibility with Drive Motor Ctrl Mod
    U0312 Software Incompatibility with Battery Energy Ctrl Mod A
    U0313 Software Incompatibility with Battery Energy Ctrl Mod B
    U0314 Software Incompatibility with 4WDClutch Ctrl Mod
    U0315 Software Incompatibility with ABS Ctrl Mod
    U0316 Software Incompatibility with Vehicle Dynamics Ctrl Mod
    U0317 Software Incompatibility with Park Brake Ctrl Mod
    U0318 Software Incompatibility with Brake Sys Ctrl Mod
    U0319 Software Incompatibility with Steering Effort Ctrl Mod
    U0320 Software Incompatibility with Power Steering Ctrl Mod
    U0321 Software Incompatibility with Ride Level Ctrl Mod
    U0322 Software Incompatibility with Body Ctrl Mod
    U0323 Software Incompatibility with Instrument Panel Ctrl Mod
    U0324 Software Incompatibility with HVAC Ctrl Mod
    U0325 Software Incompatibility with Auxiliary Heater Ctrl Mod
    U0326 Software Incompatibility with Veh Immobilizer Ctrl Mod
    U0327 Software Incompatibility with Vehicle Security Ctrl Mod
    U0328 Software Incompatibility with Steering Angle Sens Mod
    U0329 Software Incompatibility with Steering Column Ctrl Mod
    U0330 Software Incompatibility with Tire Press Monitor Mod
    U0331 Software Incompatibility with Body Ctrl Mod A
    U0400 Invalid Data Received
    U0401 Invalid Data Received From ECM/PCM
    U0402 Invalid Data Received From Trans Ctrl Mod
    U0403 Invalid Data Received From Transfer Case Ctrl Mod
    U0404 Invalid Data Received From Gear Shift Ctrl Mod
    U0405 Invalid Data Received From Cruise Ctrl Mod
    U0406 Invalid Data Received From Fuel Injector Ctrl Mod
    U0407 Invalid Data Received From Glow Plug Ctrl Mod
    U0408 Invalid Data Received From Throttle Actuator Ctrl Mod
    U0409 Invalid Data Received From Alternative Fuel Ctrl Mod
    U0410 Invalid Data Received From Fuel Pump Ctrl Mod
    U0411 Invalid Data Received From Drive Motor Ctrl Mod
    U0412 Invalid Data Received From Battery Energy Ctrl Mod A
    U0413 Invalid Data Received From Battery Energy Ctrl Mod B
    U0414 Invalid Data Received From 4-Wheel Drive Clutch Ctrl Mod
    U0415 Invalid Data Received From ABS Ctrl Mod
    U0416 Invalid Data Received From Vehicle Dynamics Ctrl Mod
    U0417 Invalid Data Received From Park Brake Ctrl Mod
    U0418 Invalid Data Received From Brake Sys Ctrl Mod
    U0419 Invalid Data Received From Steering Effort Ctrl Mod
    U0420 Invalid Data Received From Power Steering Ctrl Mod
    U0421 Invalid Data Received From Ride Level Ctrl Mod
    U0422 Invalid Data Received From Body Ctrl Mod
    U0423 Invalid Data Received From Instrument Panel Ctrl Mod
    U0424 Invalid Data Received From HVAC Ctrl Mod
    U0425 Invalid Data Received From Auxiliary Heater Ctrl Mod
    U0426 Invalid Data Received From Vehicle Immobilizer Ctrl Mod
    U0427 Invalid Data Received From Vehicle Security Ctrl Mod
    U0428 Invalid Data Received From Steering Angle Sens Mod
    U0429 Invalid Data Received From Steering Column Ctrl Mod
    U0430 Invalid Data Received From Tire Press Monitor Mod
    U0431 Invalid Data Received From Body Ctrl Mod A
    your my boy blue... bookeem's Avatar
    bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!
    Jan 2009
    north jerzy
    5,221
    now thats a list and nice breakdown of all the meanings..
    good going Fireman..
    Member raz2k8's Avatar raz2k8 is a Magnum All Star!raz2k8 is a Magnum All Star!raz2k8 is a Magnum All Star!raz2k8 is a Magnum All Star!raz2k8 is a Magnum All Star!raz2k8 is a Magnum All Star!raz2k8 is a Magnum All Star!
    Apr 2008
    Roseville,Michigan
    587
    great thread! very helpful! should be made a sticky at the top
    Senior Member CalMagnum's Avatar CalMagnum is a Magnum Expert in Training!CalMagnum is a Magnum Expert in Training!CalMagnum is a Magnum Expert in Training!
    May 2007
    Calgary, Alberta, CAN
    1,401
    Thanks Fireman,
    This may be a silly question but are these codes for all 3.5, 5.7 and the 6.1?
    U.S.A.
    18,841
    For all... All years, makes and models
    May 2007
    1,401
    Thank you...
    where's my airbrush?? GreenKing's Avatar
    GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!
    Dec 2007
    @ The Chop Shop
    14,795
    definitely going to bookmark this page!
    FORUM RULES: Hidden Content
    ULTIMATE CM.COM HOW-TO:Hidden Content
    PLEASE SUPPORT OUR VENDORS:Hidden Content
    I am a computer.
    Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!Chutsk10 is the keeper of all Magnum knowledge!
    Jun 2008
    Vancouver BC
    5,685
    Hum, I have seen this somewhere, I thought it was on the "ultimate guide" . . . or maybe it was the "how to do everything" guide over at LX forums. . .
    oh well either way it is good to have here. Thanks.
    Even Angels Cast Shadows B00MER's Avatar B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!B00MER is a Magnum Genious!
    Jan 2008
    latitude 32.934N. longitude -97.251W
    3,864
    nice, or just use: Diagnostic Trouble Codes (DTC)
    Member HemiR/T's Avatar HemiR/T is gettin' serious now!HemiR/T is gettin' serious now!HemiR/T is gettin' serious now!
    Aug 2007
    Houston T.X.
    939
    i hope i dont have to look at this thread again! lol dont want to be searching for a code unless its for a game or something! lol Nice job by the way of getting those!
    De Molded-KMC Jacks and Fives-Tinted Tails-Black Housing Headlights-Two Tone Bumper-Toyo Proxes 4-Drilled/Slotted Rotors-CSRT8 Diffuser-AFE CAI-Diablo-Removed Resonators
    Econo Heads-Sidewinder Cam-JBA Headers
  13. #11
    NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!NOTPAID4 is the keeper of all Magnum knowledge!
    Feb 2008
    Salisbury, North Carolina
    26,554
    Very nice Bill, copied this to my favorites.... Might come in handy!
    MyHidden Content Cars:Hidden Content
    2006 Magnum SRT8 "SHADOW"
    2005 Red Magnum R/T "LUCKY"
    2005 Blue Magnum R/T "BLUE"
    2006 Chrysler 300SRT "CHEETA"
    Plus have SEVERAL OTHER RIDES
    "Old Geezers LOVE cars Too!!!
    Hemi Registry #864 2/15/08
    Jim
  14. #12
    Warren, MI
    18,985
    COOL Bill...It should be added....Thanks!!!
  15. #13
    CAUSE THAT'S WHATS UP! DeadDog's Avatar
    DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!DeadDog is a Magnum Genious!
    Feb 2009
    Hamburg NJ
    3,406
    how crazy is it that cars of today need this much programming to go down the road.. NUTS!!!
  16. #14
    180 RWHP 201 trq Smokin05magnum's Avatar
    Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!Smokin05magnum is a Magnum Superstar!
    Sep 2008
    Minnesota
    2,281
    Blog Entries
    1
    P0682 Cylinder 12 Glow Plug Circ
    Really humm
    Big Bully CIA, added Fogs, Lowered on Eibach Pro-kit, Eye lids, Color matched under hood items, 20X9 Boss wheels wrapped in Hancock 275/40 rubber, Wiper delete, Dual 7" head rest monitors, Lighted grill, under seat lighting , RED L.E.D. dome lights, Papa John "13" shift knob, De-badged
    Waiting to install Dual Exhaust
  17. #15
    Member haist82's Avatar haist82 is a Magnum Expert in Training!haist82 is a Magnum Expert in Training!haist82 is a Magnum Expert in Training!haist82 is a Magnum Expert in Training!
    Jul 2009
    EARTH
    991
    hey fireman i know that dragon already told me ,but there is no p0000 on ur list!
    do work son
Page 1 of 2 1 2 LastLast
