HELP!! Malfunction Indicator Light
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
    Member veritas34's Avatar veritas34 is an unknown quantity at this point
    Aug 2009
    Music City, TN
    94
    I've been getting the MIL recently and can't figure it out. Sometimes I'll go to start the car and it won't start. It'll whine but won't turn all the way over. After I release the light will pop up for a second. If I wait a moment and try again it'll roar right up. What's the deal??
    Warren, MI
    18,986
    What lite are you seeing, how old in the battery?? how clean are the connections in the back AND under the hood???
    Aug 2009
    Music City, TN
    94
    The light is the yellow malfunction indicator light on the left gauge. The connections are clean under the hood. I'll have to check the back. The battery I'm unsure of. Should I try the "key code" thing I'm seeing in other posts?
    U.S.A.
    18,841
    Your talking about the CEL? (check engine light)
    Put key in turn to Acc then off, Acc, off, Acc. What code comes up?
    The code will appear where the odometer usually is.
    Aug 2009
    Music City, TN
    94
    I don't know if that's different from the yellow malfunction indicator light or not. I'll check the code during lunch.
    Aug 2009
    Music City, TN
    94
    WELL...I got all dashes from the get-go. I guess that means no trouble. I'm still lost as to why it does this, though. Any suggestions/thoughts?
    www.zygotecustoms.com Greg095's Avatar
    Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!Greg095 knows more than the President of Chrysler!
    Nov 2006
    Utah
    11,940
    I'm guessing your speaking of the indicator marked with the #25?
    Wheels // Accessories // Body kits // Suspension // Electronics
    Aug 2009
    Music City, TN
    94
    Quote: Originally Posted by greg095 View Post
    i'm guessing your speaking of the indicator marked with the #25?
    absolutely right...
    Nov 2006
    Utah
    11,940
    Quote: Originally Posted by veritas34 View Post
    absolutely right...
    And there is no code being flashed? Ummmmm..... Thats kinda odd.
    Aug 2009
    Music City, TN
    94
    Apologies...let me clarify. I only see this light when the key is in the ON position AFTER I've tried to start. The manual says I SHOULD see the light when the key is in the ON position. It doesn't stay on while driving or anything else. My question is does this have anything to do with the car not starting every now and then? It seems to be happening more frequently. No codes flash as described by previous threads that I've read. I get the "Dashes" right from the start and then "DONE" follows.
  13. #11
    U.S.A.
    18,841
    Probably not. The Yellow Check engine light is supposed to come on at start to test the light. If it goes off, then there are no issues.
  14. #12
    where's my airbrush?? GreenKing's Avatar
    GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!GreenKing knows more than the President of Chrysler!
    Dec 2007
    @ The Chop Shop
    14,795
    if you have dashes, and done, you have not thrown any codes. And you are correct, that light and the oil light will be on if the key is in the on position, but the car is not running.
    as for why it is not starting sometimes, could be several things. Including a weak starter, a weak battery (which in itself could be either the battery, or the alternator not charging your battery) or a loose connection at the battery. Could also be a poor vehicle ground issue
    FORUM RULES: Hidden Content
    ULTIMATE CM.COM HOW-TO:Hidden Content
    PLEASE SUPPORT OUR VENDORS:Hidden Content
  15. #13
    Aug 2009
    Music City, TN
    94
    I'll check the connections/battery/etc. when I get home tonight and go from there. Thanks a ton for the help fellas. I'll keep ya posted.
  16. #14
    your my boy blue... bookeem's Avatar
    bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!bookeem is the one everyone should be listening to!
    Jan 2009
    north jerzy
    5,221
    have u filled your gas tank very recently??
  17. #15
    Aug 2009
    Music City, TN
    94
    I'm a little over half full. I read where it could have something to do with gas, but I've tried diff octanes and it's been happening for a month or so now.
