i got this from alldata
2006 Dodge Magnum V8-5.7L VIN 2
Vehicle Level
Transmission and Drivetrain
Automatic Transmission/Transaxle
Service and Repair
Check Oil Level
Check Oil LevelNotesSpecial Tools
Dipstick 9336
CHECK OIL LEVEL
NOTE: The dipstick will protrude from the fill tube when installed.
Vehicle Level
Dipstick 9336
CHECK OIL LEVEL
- Verify that the vehicle is parked on a level surface.
- Remove the dipstick tube cap. WARNING: Risk of accident from vehicle starting off by itself when engine running. Risk of injury from contusions and burns if you insert your hands into the engine when it is started or when it is running. Secure vehicle to prevent it from moving off by itself. Wear properly fastened and close-fitting work clothes. Do not touch hot or rotating parts.
- Actuate the service brake. Start engine and let it run at idle speed in selector lever position P.
- Shift through the transmission modes several times with the vehicle stationary and the engine idling
- Warm up the transmission, wait at least 2 minutes and check the oil level with the engine running. Push the Oil Dipstick 9336 into transmission fill tube until the dipstick tip contacts the oil pan and pull out again, read off oil level, repeat if necessary.
- Check transmission oil temperature using the appropriate scan tool. NOTE: The true transmission oil temperature can only be read by a scan tool in REVERSE or any forward gear position.
- The transmission Oil Dipstick 9336 has indicator marks every 10mm . Determine the height of the oil level on the dipstick and using the height, the transmission temperature, and the Transmission Fluid Graph, determine if the transmission oil level is correct.
- Add or remove oil as necessary and recheck the oil level.
- Once the oil level is correct, install the dipstick tube cap
