Old 07-31-2007, 07:50 PM   #1
Varshaska's Avatar
Varshaska is an unknown quantity at this point
SunRoof Problem
Just happened today, my sunroof stopped working. I looked in the manual, and did not see anything about a fuse. I planned on taking it to the dealership tomorrow since the Mag is brandnew, but thought I would tap some of your minds. Is there a fuse for it?
Varshaska is offline   Reply With Quote
Old 07-31-2007, 08:28 PM   #2
Evaluating...
MagWag's Avatar
i check em all when im lost....
MagWag's Sig:MEMBERS MAP!
www.myspace.com/thompstud
No, No, NO DRAMA!
MagWag is online now   Reply With Quote
Old 08-06-2007, 08:11 AM   #3
bigkevin20 is just warmin' up!
I had the same problem with my silver 06 hemi. You have to check fuse 40 it has come loose. It is in the back simply just press down on all the fuses and it will work again.
bigkevin20 is offline   Reply With Quote
Old 08-06-2007, 08:18 AM   #4
24's and AWD? Absolutely!
DA HNIC's Avatar
Yeah, usually it just shakes loose. Just check all your fuses, it's the quickest fix.
DA HNIC's Sig:
Old 08-06-2007, 08:33 AM   #5
BakNdaHood... CM4Lyf!
JRob007's Avatar
JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!
Would checking fuse 40 help if my sunroof doesn't "seal" all the way closed? Mine works, opens and tilts fine, but whenever I close it, it recently stopped sealing shut.... there's a small space between the roof and sunroof in the back (if you can picture it....)
JRob007's Sig:
JRob007 is offline   Reply With Quote
Old 08-06-2007, 04:55 PM   #6
DA HNIC's Avatar
I know exactly what you mean now. My Mag started to do the same and water would come through. I took it to the dealership and they stated they had to updae the sunroof control software. They didn't charge me anything but the Mag was there for a different reason .
DA HNIC's Sig:
Old 08-06-2007, 06:38 PM   #7
Yeah if it's not a problem like DA HNIC says you can try to adjust it. Behind those rubber "accordian" thingy's along the sides (between the glass and interior cover) there are some adjustment screws. With the roof closed loosen up the adjustments slightly and push up on the rear of the glass then tighten everything back up. A buddy lookin at the roof may help...
Old 08-06-2007, 07:18 PM   #8
Asian Persuasion
Magmania's Avatar
Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!
I once heard that there is a self calibrating procedure for the sunroof closing.
I think it was as easy as just holding down the close button for 3-5 seconds.
I am not sure of the exact procedure. Maybe it is in the manual? I will try this on my car after work tonight and see what happens.
This might be the procedure that will work for Rob007's problem.
Magmania's Sig:
Old 08-06-2007, 10:11 PM   #9
lilcardwell's Avatar
lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!
you might want to check here TSB's: Complete list of all TSBs & Recalls issued for 2005-2008 LX models - Chrysler 300C & SRT8 Forum and see if theres a TSB for it.
I didnt take my time reading through all of them...sorry.
this list is for all the LX models.
lilcardwell is offline   Reply With Quote
Old 08-07-2007, 08:13 AM   #10
JRob007's Avatar
Thanks all for your suggestions.
JRob007's Sig:
