Code P0128 again
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
    Member JohnnyBravo's Avatar JohnnyBravo is just warmin' up!
    Jan 2009
    Kentucky
    212
    Code P0128 again
    Almost a year ago, I had my check engine light come on and I got code 0128. I looked that up and it said the engine temperature was operating below thresh hold. Tonight I got the same code again. I didn't change the thermostat last time, I pulled fuse 11 and the light went off never to return until today.
    In both situations the outside temperature was under 30 degrees and there was snow. I didn't let the engine warm up and when I drove off and I didn't get up to speed quickly. Should I go ahead and replace the thermostat or should I just keep driving and not worry about it? I'm thinking it could be more the circumstances other than a defective part.
    Thanks for your time
    My magnum at the dragstrip
    2005 Dodge magnum R/T
    2004 Pontiac Grand Prix GT
    1998 Ford F150
    1957 Chevy 210 4 door
    1957 Chevy 210 2 door
    Member HU$TLER's Avatar HU$TLER is making a name for themself!
    Jul 2009
    SAN DIEGO
    892
    may need to replace i need to do the same. my weather is nice in socal but my thermostat reads cold.
    Dont tote no .22's ..........Magnum cost me 22
    Sat it on 'em 22 ..............Birds go for 22
    Lil mama super thick ......She say she 22
    She seen them 22's........ We in room two 22
    Hidden Content SUPERCHARGED V6, yes she flies with four Verticals
    and IPHONE smart start. SDMOPAR!!!!
    MOL
    MOL is offline
    Senior Member MOL's Avatar
    MOL is a Magnum Superstar!MOL is a Magnum Superstar!MOL is a Magnum Superstar!MOL is a Magnum Superstar!MOL is a Magnum Superstar!MOL is a Magnum Superstar!MOL is a Magnum Superstar!MOL is a Magnum Superstar!MOL is a Magnum Superstar!
    Apr 2007
    SAN DIEGO, CA
    2,689
    here is the problem right here. when it is that cold out you need to let it warm up a little. just pull the fuse to clear the code. are you running a low temp or stock t-stat?
    RALPH
    THE ONLY THING THIS WAGON HAULS IS ASS!
    Senior Member Dragon's Avatar Dragon is a Magnum Expert!Dragon is a Magnum Expert!Dragon is a Magnum Expert!Dragon is a Magnum Expert!Dragon is a Magnum Expert!
    Jan 2009
    Tacoma,WA.
    1,689
    Agreed, P0128 means that the T-stat is stuck open, so trying allowing it to warm up for 5-10mins before driving in Temps that cold.... If you're still getting that code, then the T-stat is Faulty and not closing or closing completely thus triggering the code.... To keep from giving yourself other headaches down the road, instead of Pulling Fuse 11, why not just disconnect the battery for a few to allow it to properly reset everything???
    Should you still see this Code pop up even after replacing the Stat, then I would start looking at the Coolant Temp Sensor(s) Connections, and the Sensor(s) themselves...
    MOL
    MOL is offline
    Apr 2007
    SAN DIEGO, CA
    2,689
    you can still get that code even if the t-stat is working properly. it is caused buy the amount of time it take the engine to warm up in relationship to the amount of distance the car is driven. it could be a faulty t-stat but if it is then you should be getting that code more often then once a year.
    RALPH
    Jan 2009
    Tacoma,WA.
    1,689
    True, that would be why I was agreeing with your first post....
    Member HemiR/T's Avatar HemiR/T is gettin' serious now!HemiR/T is gettin' serious now!HemiR/T is gettin' serious now!
    Aug 2007
    Houston T.X.
    939
    i agree with MOL, happened to me a couple of times
    De Molded-KMC Jacks and Fives-Tinted Tails-Black Housing Headlights-Two Tone Bumper-Toyo Proxes 4-Drilled/Slotted Rotors-CSRT8 Diffuser-AFE CAI-Diablo-Removed Resonators
    Econo Heads-Sidewinder Cam-JBA Headers
    Jul 2009
    SAN DIEGO
    892
    mines on daily. light went out after fuse 11 then 10 mins driving popped up again!
    Member JCSRT8's Avatar JCSRT8 is a Magnum Expert!JCSRT8 is a Magnum Expert!JCSRT8 is a Magnum Expert!JCSRT8 is a Magnum Expert!
    Sep 2008
    Atlanta,GA
    458
    Happens to me when it gets really cold and it doesnt warm up enough. Let the engine get to 120 degrees before driving and you'll be fine.
    Jan 2009
    Kentucky
    212
    Thanks for the replies.
    I'm still running the stock thermostat. From now on I'll let the engine warm up before I drove off. If it only comes on once or twice a year I would think the thermostat is still good.
    Thanks for your time and help everyone.
    Merry Christmas!
    1998 Ford F150
  13. #11
    Senior Member 02proxdude's Avatar 02proxdude is a Magnum Expert!02proxdude is a Magnum Expert!02proxdude is a Magnum Expert!02proxdude is a Magnum Expert!
    Dec 2008
    Montrose, Minnesota
    1,390
    i have the same problem here in mn, drive around in less than drive till you have at least 180 degrees indicated through EVIC and have the heater off or very low for that time. Mine finally cleared its own code after about a month of the CEL being on at me, and i havent seen a day above 25 out in that entire month. From what i learned the cold air intake dosent help: and being in manual mode overrides the cylinder cutout so its always a V-8 helps get to temp faster. works for me so far
  14. #12
    Jan 2009
    Kentucky
    212
    Thanks for th reply!
    1998 Ford F150
  15. #13
    ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!
    May 2009
    1,119
    I would say replace it, better be safe then sorry. Make sure you replace it right though! I really screwed up my old camaro replacing mine...
  16. #14
    Dec 2008
    Montrose, Minnesota
    1,390
    any news? i have found really just leaving it in 4th on the freeway for till i get temp has made the difference needed to keep the light off, and cyceling the heat. Watching it climb on evic is a good passer time on the back roads before you get into real driving too
  17. #15
    Jan 2009
    Kentucky
    212
    I haven't drove my Magnum in over a week. I did drive it right after the code popped up and I reset the computer. The code didn't reappear. I'll wait it out and see if it comes back on.
    1998 Ford F150
