Results 1 to 9 of 9
Thread: Tire question
    Newbie Tulsa R/t's Avatar Tulsa R/t is an unknown quantity at this point
    Dec 2009
    Tulsa, Ok
    5
    Tire question
    I just ordered a set of Boss 338 in black. 20x8.5 in the front and 20x10 in the rear. I am also getting EIBACH pro kit springs installed on Wednesday. My question is with the pro kit and staggered wheels what tire size? 245/45 20 in the front or will 255/45 work and will 275/40 work in the rear? Or do I need to do 245/45 in the front and 255/45 in the rear?
  2. # ADS
    Sponsored Advertiser
    Nov 2006
    Interwebz
    Who's Counting
    Member magmax's Avatar magmax is a Magnum Expert! magmax is a Magnum Expert! magmax is a Magnum Expert! magmax is a Magnum Expert! magmax is a Magnum Expert!
    Aug 2009
    Queretaro, Mexico
    278
    Got 255 45 20 in front on a 8.5 rim, fit perfect but I will change for 255 40 20 because i found the side wall too high
    For the rear I got 295 30 22 on a 10.5 rim, no problem
    Mine are 22 in the back so you can put as wide as 295 in the back, just keep the heigh with no more than 3 % in differance of diameter to not alter the stability control.
    Member KrAzE's Avatar KrAzE is gettin' serious now! KrAzE is gettin' serious now! KrAzE is gettin' serious now!
    Sep 2009
    Springfield, IL
    288
    I have 22" rims on a 35W wall, 2" lower and it still fits.. slight rubbing on the front fenders... I wouldnt recommend this size, just telling you that you can go pretty big.
    [08:39] Rebecca: pretty sure your car is turning me on...and pretty sure thats the weridest thing I have EVER said
    Mod List: Diamondplate False Floor/Trunk | LED Lights | My Double Din Mod
    Dec 2009
    Tulsa, Ok
    5
    Thanks for the input!! Rims came in Friday and are sitting in my living room (SO PRETTY), pro-kit installed yesterday. I am out of town and not picking it up till tonight, cant wait to see it. Tires should be here any day! Cant wait to see it all together.
    Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge!
    Foster City, CA
    7,438
    Putting wider wheels on LX's requires some planning. It needs to be done right or you're going to have issues. Particularly when lowering. If you've done your planning and considered the following, then good for you, enjoy! But in case you haven't, here are a few things to consider..........
    (BTW- If you have questions, please ask)
    Some Magnums came with Nivomat self leveling rear shocks. If you have these, the rear of your car will not lower no matter which springs you use. They came standard on SRTs and on some R/T's. If you have standard shocks on the rear, lowering won't be your issue.
    Just remember that with a 10" wheel in the back, you may have rubbing issues.
    If you don't have the nivomats, you'll probably need to roll the rear fenders. Especially if you're dropping. If the wider wheel puts your rear tire under the fender lip and you lower while keeping the stock shocks (non nivomat), Rough roads will bounce your fender into your tire.
    You can really help yourself out by installing quality performance dampers (shocks) at the same time.
    Koni make the STR.T dampers
    Eibach makes the Pro dampers
    There are other brands also.
    '05 R/T 370 rwhp / 390 rwtq - PPP stage 3 big valve heads, PPP/Comp stage 2 cam, forged pushrods, 6.1 lifters, 25% UD pulley, JBA headers, JBA mids, Corsa exhaust, Paramount billet stator 3400 stall TC, Mopar TCM, Silver box electronic shift kit, 215mm diff. w/3.06 gears, Jet 180 t-stat, DS Predator, CMR by Johan, Aria M CAI, Taylor 8.2mm short wires, Eibach Sportline springs, Pro dampers & sways, REM adj. endlinks, REM strut bar, Wilwood stage 2 big brake kit, 22" KMC Dime, Dunlop SP Sportmaxx
  7. #6
    Dec 2009
    Tulsa, Ok
    5
    Finished. Sits just right. May need to roll the fenders.
  8. #7
    Double-U Tee Eff TheWraith's Avatar
    TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious! TheWraith is a Magnum Genious!
    May 2008
    Frisco, TX
    2,678
    they look good, bro! good choice on the Boss wheels!
    360rwhp / 390rwtq
    Spartan Max Cam - SRT Valve Springs - Inertia Forged Pushrods -
    Custom Predator Tune - JET 180º T'stat - DSP - BT Oil Catch Can -
    K&N CAI - 6-speed-Challenger Motor Mounts - Ported Thottle Body -
    JBA Shorty Headers - JBA/HHP Catless Mid Pipes - SLP Loudmouth -
    SLP Pulley
  9. #8
    Member n2fordmuscle's Avatar n2fordmuscle is a Magnum All Star! n2fordmuscle is a Magnum All Star! n2fordmuscle is a Magnum All Star! n2fordmuscle is a Magnum All Star! n2fordmuscle is a Magnum All Star! n2fordmuscle is a Magnum All Star!
    Apr 2008
    Canton, GA
    688
    Looks great! What size tires did you end up going with?
  10. #9
    Dec 2009
    Tulsa, Ok
    5
    245/45 in the front and 275/40 in the back. Good thing I did the pro-kit. I was going to do the sportlines but I think I would have had rubbing issues.
