Results 1 to 6 of 6
    Newbie GuySmit99 is an unknown quantity at this point
    Mar 2010
    5
    ESP light with flashing Red Light
    Since putting on the eibach springs every once in awhile I get the ESP light and this other light that flashes. If I turn off the car and turn it back on, it goes away. Anybody know what would cause this??? How do I fix it??? I have an 06 Sxt. Here is a pic of my dash with the lights on. And the red light on the left flashes. Thanks
  2. # ADS
    Sponsored Advertiser
    Nov 2006
    Who's Counting
    Quando omni flunkus moritati. stingrayj's Avatar stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious! stingrayj is a Magnum Genious!
    Sep 2008
    Hanover, PA
    3,598
    I have heard of this. I'll see what I can dig up. In the meantime, I'd say try checking your wire connections. I believe that this is related to the ABS systems losing its signal. Could be wrong, though.
    FYI, the lightning bolt is usually related to the throttle sensor and the little car doing a burnout (call it whatever you want) is related to the traction and stability controls.
    Hemi? Noooooooo! gangster wagon's Avatar
    gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious! gangster wagon is a Magnum Genious!
    Jun 2007
    southern utah
    5,486
    When i had my fender fix and they put it back together. There is an ABS Seniors in the wheelwell, that they forgot to put back together as soon as they did it went away. Maybe you pulled it a little when you changed your spring in the front?
    3.5L Diablo Six Pak!!
    Dean
    Mar 2010
    5
    What does this sensor plug into? Where is it located?? Anybody have a picture of what it looks like??
    Member magnum05's Avatar magnum05 is gettin' serious now! magnum05 is gettin' serious now! magnum05 is gettin' serious now!
    Mar 2007
    Baltimore Md
    962
    That looks like a throttle sensor light, Are you having any problem with how the car is running or is the check engine light on? I just worked on a Charger with the same light was on and it was a major vacuum leak from the EGR tube at the intake manifold. Good Luck
  7. #6
    Programming and wiring GURU nyinstaller's Avatar
    nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious! nyinstaller is a Magnum Genious!
    Jul 2007
    South florida Resident.
    1,114
    Since you have abs I am pretty sure you will have a sensor in each wheel well. they will go from the knuckle To inner fender in front and in the rear it will go from the drivers rear to the pass side then the two rears go into one hole in the trunk,.
    there is a change you damaged or pulled one of the wires out of its socket. However they are held in there by Metal spring clips. Just go ahead and push in on all four If you have 4 Just to make sure they are all making good connections.
    Chrysler/Dodge/jeep Programmer/ Diagnostics via starmobile.
    2006 magnum transplanted with the v8 6.1l srt brakes Kooks Long tube headers. ported painted Intake manifold. debadged 300 grip touring front end converstion.
    There is always a brighter side to the dark ones. its just always at first hard to see.
    future mods Feeler: Air bags.
