My engine shut-off...
Results 1 to 7 of 7
    Newbie Miss's Avatar Miss is an unknown quantity at this point
    May 2007
    NORTHERN CALI
    4
    2006 Dodge Magnum 3.5 SXT
    Help? Today, while driving the engine just shut off out of nowhere. It also hiccups when I'm at a stop light, every once in a while. But, the engine shutting off worries me. Is anyone else having this problem. There is no "check engine" light that comes on . I just had the "rocker assemblies" replaced...could that be part of the problem? That had to be replaced because the engine was making a "ticking" noise and Dodge fixed that.
    Do I have to take it back to Dodge because the engine shut off?
    Can this be fixed or do I have to wait for the check engine light to come on? I just need help.
    Greatly appreciated...
    Melissa
    Senior Member B-Rock's Avatar B-Rock is a Magnum Superstar!B-Rock is a Magnum Superstar!B-Rock is a Magnum Superstar!B-Rock is a Magnum Superstar!B-Rock is a Magnum Superstar!B-Rock is a Magnum Superstar!B-Rock is a Magnum Superstar!B-Rock is a Magnum Superstar!B-Rock is a Magnum Superstar!
    Dec 2008
    NorCal
    1,255
    Were you stopping quickly then hit gas hard. I've had that shut my engine off before in a parking garage. Trying to chirp the tires loudly, never had it happen again. Some times you can get a code if you do the key dance trick even if there isn't a CEL. Have you tried to do the key dance yet? Also, did you recently get gas or get down very close to empty when this happened. Sorta sounds like when you have water in your tank, but I'm no expert.
    05' Mag RT Mods: Eibach Pro System drop, Frankentake IV, Mesh Grill, 20" Gienelle Rims V-5's w/ 275/40/20's,
    Flowmaster Force II SS, Challenger 6.1 motor mounts,
    6000k DDM HID Kit/Highs, Lows, Fogs, Predator!, 180F T-Stat, No ESP mod, JVC NT3HDT
    May 2007
    NORTHERN CALI
    4
    Hi B-Rock
    No, actually I had just put the car in reverse and she just shut off. I haven't tried the key dance. Can you please tell me how to do this?
    Yes, got gas about 2 days ago, filled up the tank. I don't usually fill up, but I was headed to a casino in the middle of nowhere.
    Thanks
    Melissa
    Senior Member FloridaRT's Avatar
    FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!FloridaRT is a Magnum Genious!
    Aug 2007
    Ocala, FL
    3,801
    Might be the fuel/vapor device inside the tank, early cars have this problem. I have to keep mine at less than 3/4 tank or it will stall.
    No fix or recall on this, the whole gas tank needs to be replaced............... $$$$$$$$$$$$
    Was it hard to restart?? If so, loosen the gas cap next time it happens.
    Good luck,
    Bob
    Bob in Ocala, Florida, Age 76 - Married 55 years, 05' Magnum RT. Superchips tuner, No-ESP mod, Magnaflow Mufflers, 402 Motoring rear spoiler, mud flaps, tinted & painted tail lights. Danko shaker hood, 69' Charger grill, front spoiler, rear diffuser, installed 9011 & 9012 headlight bulbs.
    Banned imjester77 is making a name for themself!
    Apr 2008
    VA
    455
    check the battery in you key fob....sometime that stupid battery will start to go dead and kick off the engine kill as if you just stole your own car! happened to me a few months back, and read a post about that exact thing. changed the battery and all has been well so far.
    Dec 2008
    NorCal
    1,255
    key dance is easy, but only works if you have the digital display under neath your speedo with temp and compass I think. You just turn your key from on to ACC and repeat 3 times in a row, then your odometer area will start flashing the latest codes if none are there it will just throw zeros up. Write down the code if you get one, it will flash through 3 or 4 blank ones sometimes before it give you a code, so don't turn away until the odometer pops back up. Good luck.
    full 300 swap inside and out hellsfire's Avatar
    hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!hellsfire is a Magnum Genious!
    Nov 2008
    hamilton, ohio
    3,307
    i would check the fuel pressure, then start to truble shoot
