Another Hemi with a failed valve seat (pics)
Results 1 to 15 of 15
    lae
    lae is offline
    Member lae is an unknown quantity at this point
    Sep 2010
    SoCal
    30
    #4 cylinder. I pulled the head today. 05 Magnum RT 80,000 miles/ Someone has been in this engine before. The head surfaces are all scratched up.ton is installed backwards. The pistons have 03/44 on them. Any clue? .030 over? of some other meaning.. The cylinder may clean up with a hone. I have no idea which route I am going to go. I may just replace the head, the piston (if the cylinder is okay) and fix the damn fans. Seems like they were not working (quick bench test today) to but the temp gauge never went above the halfway point. I will build a stroker with another block and then swap.
    Attached Thumbnails Attached Thumbnails Another Hemi with a failed valve seat (pics)-p3050903.jpg Another Hemi with a failed valve seat (pics)-p3050904.jpg Another Hemi with a failed valve seat (pics)-p3050907.jpg
    Member EMMJAY's Avatar EMMJAY is just warmin' up!
    Jun 2010
    Port Huron, MI
    348
    Not good man! Good luck with the fix
    Senior Member cleary524's Avatar cleary524 is a Magnum All Star!cleary524 is a Magnum All Star!cleary524 is a Magnum All Star!cleary524 is a Magnum All Star!cleary524 is a Magnum All Star!cleary524 is a Magnum All Star!cleary524 is a Magnum All Star!
    Nov 2008
    NW RI
    1,023
    That is awful to see. Looks like your going to need new pistons and heads. That's tough! Might be time for a stroker upgrade!
    2005 Magnum RT AWD 344AWHP/358AWTRQ
    FRI Sidewinder Cam, Edelbrock Headers, JBA High Flow Cats, Magnaflow Catback, Tune by Johan, SLP 25% UDP, Jet 180* T-stat, aFe Stg II CAI, 85mm Throttle Body, Catch Can & Freak351 Silver Trans Box. Eibach Pro Line Springs, Billet Tech Interrior, Engine Kit, EGR Block & "M" Emblems, R/T Badges, Custom Magnum R/T Grille.
    Hidden Content & Vidoes
    U.S.A.
    18,841
    Never seen anything like that before. Looks like someone took a ballpeen hammer to that piston.
    lae
    lae is offline
    Sep 2010
    SoCal
    30
    On lxforums there are a few that have had the same exact issue and the damage to the pistons and heads look identical.
    Member didyoma's Avatar didyoma is a Magnum Expert!didyoma is a Magnum Expert!didyoma is a Magnum Expert!didyoma is a Magnum Expert!
    Nov 2009
    Da 219
    866
    Wow bro, that's some ugly stuff. Good luck.
    Member JamesOttawa's Avatar JamesOttawa is a Magnum Expert!JamesOttawa is a Magnum Expert!JamesOttawa is a Magnum Expert!JamesOttawa is a Magnum Expert!
    Aug 2010
    Ottawa, ON, Canada
    628
    The heads can be fixed (ground and polished) but then you are increasing combustion chamber volume and losing compression ability.
    The piston(s) is(are) toast.
    Looks like the piston has hit one of the valves.
    That usually happens when you have broken valve springs.
    Definitely needs a complete rebuild.
    Last Mod (2016/05): BBK Silver Ceramic Shorty Headers, Phase 2 Motortrend Red Intake Clamps
    Of course I don't look busy... I did it right the first time!
    Vehicle: 2006 Magnesium R/T
    I'm a philanthropist... I just don't have any money!
    Hemi Registry: #1509 (2011/02)
    The project that I'm working on is so secret... Even I don't know what I'm doing!
    lae
    lae is offline
    Sep 2010
    SoCal
    30
    The Seat on the intake valve "fell out". Parts of it are imbedded in the piston and the head. I though about having the head repaired but I can get good used one for $150 and a new one for $300 I will just go that route.
    Member benhom's Avatar benhom is just warmin' up!
    Sep 2009
    Rising Sun, MD
    799
    longs machine shop, in elkton md
    will redo BOTH heads for $115
    or atleast thats what i have been quoted for different vehicles
    so $300 for 2 used ones...$600 for 2 new ones...or just over $100 for 2?
    id be calling some shops man
    Ahhhh VTEC, all of the lag, none of the turbo....it's like waiting for bad sex
    Aug 2010
    Ottawa, ON, Canada
    628
    Ah... THAT's where that metal cam from.
    Yup... Sounds like some replacement heads would be your best bet.
  13. #11
    Member him fast's Avatar him fast is an unknown quantity at this point
    Feb 2009
    175
    Wow! That doesn't look good.
  14. #12
    Warren, MI
    18,985
    WOW!! that makes me sick..........quite the mess, but fixable...... and looks like you are on the right path....
  15. #13
    Member The Dodge's Avatar The Dodge is a Magnum All Star!The Dodge is a Magnum All Star!The Dodge is a Magnum All Star!The Dodge is a Magnum All Star!The Dodge is a Magnum All Star!The Dodge is a Magnum All Star!
    Aug 2010
    Olympia WA
    329
    Those pictures are almost too painful to look at!!
  16. #14
    lae
    lae is offline
    Sep 2010
    SoCal
    30
    I found another passenger side head at a local machine shop for $100. The Piston, connecting rod, rings, gaskets,head bolts, and a catch can are on the way and everything should be here by the 16th.
  17. #15
    Newbie magnumbaby is an unknown quantity at this point
    May 2016
    1
    Dropping Valve Seats
    If you have experienced this or know someone who has, please sign this petition: https://www.change.org/p/chrysler-gr...fb_ref=Default
