oil pressure problems and the non-stop "DING"...
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
    Newbie gt90 is an unknown quantity at this point
    Mar 2010
    groton, CT
    15
    Question oil pressure problems and the non-stop "DING"...
    Okay so i had the common P0520 code with a flashing oil light and dinging that by now is literally constant once she warms up. So I replaced the oil pressure sensor located behind the alternator, that didn't fix it, instead the code changed from a P0520 to a P0522 = Oil pressure sensor circut low voltage. Now I've heard talk of both an oil pressure sending unit and an oil pressure switch. One located on the block behind the alternator and one by the oil filter. My oil pressure readings on the EVIC are all over the place, anywhere from 0-99psi with no rhyme or reason. I'm wondering if maybe it's the sensor by the oil filter? What exactly does it sound like the mafunction here is? And which sensor is which?
    I don't think I can stand the "DING" much longer lol and not having MDS kinda sucks too.
    Thanks for any help you can offer! and on a side note, you guys were able to help fix my sunroof sealing issue that I struggled with for months!
    MR 3 FIFTEEN FROST's Avatar
    FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious!
    Mar 2009
    ILLINOIS [815]
    11,767
    You already checked your oil level, I presume. Did you just get an oil change or anything ?
    Just lower it.
    Mar 2010
    groton, CT
    15
    yup, after 4k miles it's only 1/4qt low
    loven the super charged life jayalbertcars's Avatar
    jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge! jayalbertcars is the keeper of all Magnum knowledge!
    May 2006
    bel air maryland
    14,651
    what year and engine do u have i can do some research for u
    DODGE MAGNUM "THE POSSIBLITIES ARE ENDLESS "
    May 2006
    bel air maryland
    14,651
    i just saw in another thread u have an 06 r/t awd do u have a warrenty on the car
  7. #6
    Mar 2010
    groton, CT
    15
    oops lol I've got an '05 R/T RWD, no warranty
  8. #7
    May 2006
    bel air maryland
    14,651
    sorry i thought that was u let me do some reseach i will get back to u
  9. #8
    Mar 2010
    groton, CT
    15
    Awesome, thank you!
  10. #9
    May 2006
    bel air maryland
    14,651
    sorry i did not forget i worked 15 hrs today we were slamed i will have some answers for u friday night
  11. #10
    //CMOM | Secret Agent// concussion's Avatar
    concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to! concussion is the one everyone should be listening to!
    Feb 2008
    Charlotte, NC
    3,185
    replace the sensors, then the sending unit. Also check for loose connections to the sensors before you replace them.
    And change your oil, 4K... it's time, unless you're running Royal Purple.
    PickleFork & MMPG: Custom Cam | Indy: 6.1 Heads | Modern | Muscle: Stage 1+ SRT Intake Manifold, 85mm TB | Paramount: VB, Shift Kit, Flex Plate, 4000 Dominator TC | PickleFork: FrankenTake V, Ported SRT Headers | Getrag: LSD 3.06 gears | Maganaflow: 6.1 HF cats | SLP: LMII, UD Pulley | SRT: Modified Suspension, Injectors | AMG: Paddles, Clutches | PLCMAN: Harness | BT: Can, Emblems | Lead Foot
    11.861 @ 112.76 1.63 60'
  12. #11
    Newbie TimsRT's Avatar TimsRT is an unknown quantity at this point
    Jun 2011
    Cottonwood Heights, Utah
    16
    I think I might piggy back onto this thread.
    I've had my '05 RT since the end of May. I was dropping the GF off at work this morning, and as I was slowing to a stop in the parking lot, the car surged forward (as if I were gently pressing the accelerator) then got the 'ding' and my oil pressure light came on. I shut it off immediately and checked the oil level, and for any leaks. The oil was at the bottom of the 'safe' zone on the stick, and no leaks were found. This was about 15 minutes ago. I haven't had a chance to hook up my code scanner yet.
    Anyone else had that happen, with the sudden surge and then the oil light coming on?
  13. #12
    Jun 2011
    16
    Just checked for codes, and none are present.
  14. #13
    Mar 2010
    groton, CT
    15
    Okay, well I already replaced the sensor behind the alternator, it's possible I got a bad one as I didn't get an oem mopar one. what other sensors are part of this system, and where is the sending unit?
  15. #14
    May 2006
    bel air maryland
    14,651
    p m sent
  16. #15
    Member F-5.7's Avatar F-5.7 is just warmin' up!
    Nov 2010
    Rhode Island
    470
    Im having the same issues...
    A week after changing the oil w/Royal purple I got the P0520 code. (5.7l)
    Replaced the oil sensor behing the Alt. Sensor was cracked and was weeping oil.
    Cleared the codes and all was OK for two weeks.
    Now I have P0520 & P0522 codes with 0-99 psi showing on the EVIC. Oil pressure is fluctuating wildly.
    Did my new sensor go bad? Could it be something else? What was done to fix your problem?
    Thanks.
    Dave
    K&N CAI, SRT-8 Cat Back Exhaust, DiabloSport inTune (Diablo Tune 93 oct.)
