need some help
Results 1 to 6 of 6
Thread: need some help
    Member j2theu's Avatar j2theu is just warmin' up!
    Aug 2010
    Bronx, N.Y.
    176
    Blog Entries
    1
    need some help
    i wasdriving on the highway and floored the throttle and all i see in the rearveiw mirror is smoke. upon slowing down to pullover the smoke stoppped. i looked under the car to see what i see and its leaking by the trans fluid pan and transfer case, but it wasn't trans fluuid it was clear and had no odor at all. now i have a very slight whine that you can barely hear but i can hear it cause i know my car. any idea what this fkuid could be and what might have happened? any and al help is appreciated. thanks
    Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler! Fireman2118 knows more than the President of Chrysler!
    U.S.A.
    17,181
    Did you have your air conditioner on? The fluid you see may just be condensation from the A/C system. It'll drip from right next to the transmission pan. As far as the smoke at W.O.T. You may just be burning a bit of oil.
    Check all your fluid levels to be sure.
    & 85mm throttle body - 6.1 fuel injectors - 6.1 fuel rails - 25% UDP - Jet 180 tstat - LMI 4" true CAI - MSD "Blaster" coils - 8.2mm Taylor wires - JBA headers - JBA high flow mids - Corsa catback
    Diablosport Intune - CMR by Ditos - Paramount "Dominator" 3000 stall tc & stage II valve body - Tranzformer shift kit - 226mm Getrag 3.91 LSD - BC racing coilovers - Eibach front & rear sways
    BWoody endlinks - Razors Edge strut bar - Wilwood big brake kit by TCE - W6A 6 piston front calipers on 14.25" 2 piece GT rotors - Dynapro 4 piston rear calipers on 13" 2 piece GT rotors
    Vossen VVSCV3 & Nitto 420s - 22" x 9" w/265/35/22 & 22" x 10.5" w/295/30/22 ----- Hemi Registry #943
    Aug 2010
    Bronx, N.Y.
    176
    Blog Entries
    1
    yes i had the ac on. i checked my oil level and its fine and have to wait til monday to check trans fluid.another fluid i should check? coolant is fine also.
    U.S.A.
    17,181
    That clear fluid was just water! A/C condensation
    Aug 2010
    Bronx, N.Y.
    176
    Blog Entries
    1
    ok thanks Fireman for the help, that eased my mind lol.
  7. #6
    Member F-5.7's Avatar F-5.7 is just warmin' up!
    Nov 2010
    Rhode Island
    568
    It sounds like the same thing happened to me.
    Check: 5.7 Smoke Screen??
    In my case, after driving the same stretch of road a few times I realized there were multiple dips in the road with each larger than the first. The last one lifts you out of the seat a bit... Which at the speed I was traveling made it even worse. It was soon after the dips when I noticed the smoke. Because I am not running a catch can, I think it could have disturbed any residual oil in the intake, thus the smoke... I have not tried to re-create this on the same strech of road nor has it happened again. Hope this helps...?
    K&N CAI, SRT-8 Cat Back Exhaust, DiabloSport inTune (Diablo Tune 93 oct.)
