Stripped Idler Pulley Screw
Results 1 to 3 of 3
    Newbie dkm098 is an unknown quantity at this point
    Apr 2012
    1
    I was working on my car and decided to replace the idler pulley, comes to find out that the center screw is stripped, i was trying using a screw extractor with a angled drill bit to fit in the tight space to do it. I was wondering if anyone would know a better way to do this, besides going to the dealership where ill lose a arm and a leg.
    Senior Member FloridaRT's Avatar
    FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious!
    Aug 2007
    Ocala, FL
    3,319
    Why are you using a drill and a screw extrcator if the bolt hole is stripped??
    You did get the old bolt out - right?
    If so, you need to re-tap the hole to a bigger size and use a new bolt.
    Maybe use heli-coil to repair the stripped bolt hole??
    Good luck,
    Bob
    Bob in Ocala, Florida (73 year old guy who loves cars), 05' Magnum RT.
    Many mod's, all of Danko products and a few 402 Motoring items.
    Senior Member shane93nc's Avatar shane93nc is a Magnum All Star! shane93nc is a Magnum All Star! shane93nc is a Magnum All Star! shane93nc is a Magnum All Star! shane93nc is a Magnum All Star! shane93nc is a Magnum All Star!
    May 2009
    James Island,SC
    1,818
    Good luck with your fix and keep us posted. Also welcome to CM from NC.
