Magnum shuts off while driving...
Results 1 to 13 of 13
    Junior Member Cali-Magnum's Avatar Cali-Magnum is an unknown quantity at this point
    Nov 2007
    Porter Ranch, California
    29
    Anyone had this problem, my Magnum has shut off twice now while driving, justs powers off. It will re-start immediately when I put it back in park, so not sure what's up. Any ideas? Thanks for any help.
    Hidden Content K&N Intake, Magnaflow Exhaust, Jet Stage 1, 20" Torq Thrusts, Eibach Pro Kit Springs and Sway Bars.
    Member O.A. for life's Avatar O.A. for life is an unknown quantity at this point
    Jan 2008
    St George, ut
    71
    Hey thats funny cuz my guage cluster went dead twice yesterday after putting it in park! Stayed running but goes dead for a second or two.
    Any thoughts?
    Lou
    Lou is offline
    Member Lou's Avatar Lou is making a name for themself!Lou is making a name for themself!
    Jan 2008
    Miami, FL
    114
    Can we get a little more detail? Did you check for codes?
    Does the car make any noise or anything as it shuts off... does the acc power stay on when it shuts off?
    That could be alot of things...
    Nov 2007
    29
    How do you check the codes? The car shuts off, electrical cuts off, only idiot light showing is the oil light.
    QUE TU SABE DESO TRUEST ONE's Avatar TRUEST ONE is a Magnum All Star!TRUEST ONE is a Magnum All Star!TRUEST ONE is a Magnum All Star!TRUEST ONE is a Magnum All Star!TRUEST ONE is a Magnum All Star!TRUEST ONE is a Magnum All Star!
    Jun 2007
    Maryland
    1,435
    Another question, do you have a remote start alarm system installed? I remember a friend of mine had a car and the remote start "brain" went crazy and would shut his car off!
    Nov 2007
    29
    Hi, no, no remote start. It's really weird, makes no sound or noise, in fact the one day I was driving and all of a sudden, nothing, I was sitting in stop n go traffic, and didn't realize the car just died. I'll pull the ecm out tomorrow and check to make sure all the plug ins are seated tight. Thanks
    I'd Rather be Camping! SilverMaggie's Avatar
    SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!SilverMaggie is the keeper of all Magnum knowledge!
    May 2006
    So.Cal.
    9,853
    This is a somewhat common problem and, of course, can be very dangerous!
    Go check out this website:
    Auto Recalls, Free Car Reports, Consumer Complaints, Service Bulletins
    In Loving Memory
    Member customcompacts's Avatar customcompacts is an unknown quantity at this point
    Apr 2007
    Brooklyn, CT
    322
    Mine Shuts Off Too! But Only When I'm Trying To Go Over 125 HAHA
    Member DR_SRT8's Avatar DR_SRT8 is just warmin' up!
    Dec 2007
    Oxnard, CA
    42
    Do you have any special anti-theft? I have the Lo-Jac + early warning. If the chip I have on my key ring is not within a fixed distance of the car it will "call me" (technology is awesome, but sometimes it sucks) and eventually shut down.
    Hidden Content I don't speed, I just get to the speed limit faster than others.
    Lou
    Lou is offline
    Jan 2008
    Miami, FL
    114
    It only happens while your on idle?
    To check for the codes you can get a scanner at auto zone ($40 ish), or if not there is "combination" you can do... (some one help me out with this, I forgot what it was) it will show the code, if any, in the driver information center.
  13. #11
    Nov 2007
    29
    Silver Maggie, thanks, checked the website and like you said, appears common. I'll take it to the dealer and see what I can get them to do. I'm not going to leave knowing what I know now, to have them tell me nothing is wrong. I'll make them re-flash the computer at the very least. Thanks for the other tips, I'll get a code scanner too. Every little bit of knowledge helps.
  14. #12
    Newbie turboshopo is an unknown quantity at this point
    Aug 2013
    3
    mine does the same thing trying to figure it out.
  15. #13
    ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!ronald_smail is a Magnum All Star!
    May 2009
    1,119
    Two minor things that could be an issue.
    1. make sure all your main power connections are tight and secure i.e. the battery connects in the trunk and the fuse box (+) jump port under the hood. Mine was loose and my car would shut off while driving.
    2. make sure you have a good battery in your key. Mine was dead (after I took a swim with my keys, the battery must've shorted out), and a few hours after I was already home and about to leave home again, I started my car, put it in drive and it shut off. Tried again and it shut off again. I tried a third time and it wouldn't even turn over. Switched out my battery in the key and everything went back to normal.
    Good luck!
