Is my car cranking too long before it starts ?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
    MR 3 FIFTEEN FROST's Avatar
    FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!FROST is a Magnum Genious!
    Mar 2009
    ILLINOIS [815]
    12,414
    I turn the key and it'll crank 3 or four seconds before the engine starts. I've had the car for 4 years and I always remember it bein that way. I replaced the battery cuz I tried to start it and it did nothing. All the interior lights went out when I turned the key, it seemed like it was time for a replacement. My battery was 5 years old anyway. After the new battery, it started up instantly for the first couple days. Now, it's actin like it did before. Is this a normal thing for Magnums or does it sound like I need a new alternator ?
    Just slam it.
    Member RTpower's Avatar RTpower is just warmin' up!
    Apr 2012
    Austin,TX (512)
    546
    I have the same problem but mines about 2 to 3 secs and sometimes it won't start on the first try but itl start up on the 2nd always...?
    252.646.2160 Grille Master NC-SXT's Avatar NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!NC-SXT is a Magnum Genious!
    Jan 2006
    3,467
    Try these first, There is a TSB for this issue on the challenger
    Mopar Ground Cable Upgrade Kit 05-09 300, Challenger, Charger, Magnum 5.7L R/T 6.1L SRT8
    Mar 2009
    ILLINOIS [815]
    12,414
    Thanks for the info, NC. That's the last thing that woulda crossed my mind. For that price, it's definitely worth a try.
    Just slam it.
    Member lovelinds's Avatar
    lovelinds is a Magnum All Star!lovelinds is a Magnum All Star!lovelinds is a Magnum All Star!lovelinds is a Magnum All Star!lovelinds is a Magnum All Star!lovelinds is a Magnum All Star!
    Feb 2012
    San Diego, CA
    840
    mine cranks 5 times with my remote start… and 5-6 times with my key.
    grounding kits work..
    my two girls
    U.S.A.
    18,841
    I still have my original battery. It's almost 8 years old and my car starts immediately.
    Senior Member Wexy21's Avatar Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!Wexy21 is a Magnum Superstar!
    Apr 2011
    St. Louis
    1,705
    Blog Entries
    1
    Yep, mine too. It starts almost instantly, like half a crank it seems. Original battery. Different engines, but maybe you should check for trouble codes??
    05 Magnum RT...87 Grand National...65 Fairlane 500...91 GMC Syclone...98 Buell S1W
    Member Mikey97d's Avatar Mikey97d is a Magnum Expert in Training!Mikey97d is a Magnum Expert in Training!Mikey97d is a Magnum Expert in Training!
    May 2011
    Connecticut
    809
    Thanks for the link on the grounding cables. I am going to try that first.
    There were some threads regarding slow starting or 2nd try on LXForums for the V8's and the fix was either the camshaft sensor or the crankshaft sensor. Everyone was trying the camshaft sensor first because that is the easy one to get too. I would like to put more weight on the TSB fix for the Challenger than the sensors causing the issue.
    '06 R/T AWD
    Legmaker "Frankentake" IV Design
    255/55R18 Tires on '10 Charger AWD Wheels
    Pappa John Shifter
    Parrot Blue Tooth
    Mopar Hidden Hitch & 7 Way Connector
    Member Psssdoff's Avatar Psssdoff is a Magnum Expert!Psssdoff is a Magnum Expert!Psssdoff is a Magnum Expert!Psssdoff is a Magnum Expert!Psssdoff is a Magnum Expert!
    Oct 2009
    the big smoke, T.O.
    520
    same here
    2005 SXT
    Pioneer Speakers front and back
    DEPO Projector Headlights
    DDM 5000K HID Kit
    Big Bully SRI
    WeatherTech FloorLiners
    Class II Hidden Hitch
    BT Catch Can
    Strutwise Stainless Steel Hood and Tail Gate Struts
    Drake's Billet Strut Tower Brace
    MOPAR Remote Starter
    Interior Light LED Conversion
    Switchback LED Signal Lights
    Pioneer AVH-P4400BH Headunit
    Member Lil mag 2.7's Avatar Lil mag 2.7 is a Magnum Expert in Training!Lil mag 2.7 is a Magnum Expert in Training!Lil mag 2.7 is a Magnum Expert in Training!
    Mar 2010
    portage in
    326
    when i had my remote start instaed, it wouldnt crank long enough to start it, so i had the guy go back in and reprogram my remote start to crank a lil longer (total of maby 2.5 sec). never has ever been a prob, although it probably wouldnt be when u have 2 kenitik 2400 series bateries that are 1700 cranking amps ea, and a lil tiny 2.7 moter, lolol.
  13. #11
    Mar 2009
    ILLINOIS [815]
    12,414
    No codes, it's all clear.
    Just slam it.
  14. #12
    Mar 2009
    ILLINOIS [815]
    12,414
    I read to replace the battery every 4 years and when my car wouldn't start, I figured it was time. (5 years old). I'm overly paranoid about batteries and tires, I've had bad experiences with both. I'll order the grounding kit and see if it helps.
    Just slam it.
  15. #13
    Member mcdizzle's Avatar mcdizzle is making a name for themself!mcdizzle is making a name for themself!
    Jun 2012
    54
    lean conditions will make a vehicle crank longer than needed too. do you have any engine mods? have you replaced your wires and plugs lately?
    '06 Silver Magnum R/T
    too many ideas, not enough $
  16. #14
    Member aaronagis's Avatar aaronagis is gettin' serious now!aaronagis is gettin' serious now!
    May 2012
    70
    My 06 RT starts instantly. i just stick the key in and a flick of the wrist and shes purring... off topic, but what was the OEM battery in the RT? just curious if mine has been replaced or not...
  17. #15
    Apr 2011
    St. Louis
    1,705
    Blog Entries
    1
    Jesus
    I think I need 1700 cranking amps, just to say I have 1700 cranking amps.
