AWD Coilovers, looking for any and all information
Results 1 to 3 of 3
    Hemi-sphere Dancer riperoo's Avatar
    riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious! riperoo is a Magnum Genious!
    Sep 2007
    Bucks County PA
    1,936
    Hey all, howdy, been a away for bit, but back to many new faces. Looking for some info on Coilovers, I am a few months away from pulling the Mag off the road as a daily driver and starting to take it to the next level. First is going to be suspension, something that I just couldn't see doing while having the Mag as a daily driver in the Northeast, but now it is time. I am looking for any and all info on coilovers for an AWD. Lots of questions, first, besides the coilovers, what else do I need, or what should I do at the same time? I have seen damper kits, it appears to me that they are needed on some and not on others, camber kits? How low can I go? And how much of a hassle to raise it up? Thanks in advance!!
    MR 3 FIFTEEN FROST's Avatar
    FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious!
    Mar 2009
    ILLINOIS [815]
    11,770
    This should pretty much cover it.
    AWD Install of BCR Coilovers
    Just lower it.
    Sep 2007
    Bucks County PA
    1,936
    Thank Frost, I did see that right up by Rob, and I am sure I will be using it religiously when i install. But, I would like to hear some more about other options, including the BT's, get a feel for what people think are the best and any insight gained if they have been running them for a while.
