Old 02-17-2007, 01:05 PM   #1
messenger961
messenger961 is an unknown quantity at this point
removing shift knob
i want to replace my shift knob with a custom one. does anyone know how to remove the stock one?
tom
messenger961 is offline   Reply With Quote
Old 02-17-2007, 01:23 PM   #2
Bigal470
you can call me Bagnum
it just unscrews might be tight at first......
Alex
Old 02-17-2007, 02:10 PM   #3
05HEMIMAGNUM
Support our Troops!
05HEMIMAGNUM's Avatar
Bigal is correct, we just changed one on my buddies Magnum and it was tight at first but then it came right off..Be Gentle..
Old 02-17-2007, 09:27 PM   #4
SilverMaggie
GO STEELERS!!!!!!!!
SilverMaggie's Avatar
SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!
Send a message via Yahoo to SilverMaggie
I've been wanting to change mine too but the ones i've seen say for " manual transmission only" Does it really matter or do I need to find one for an automatic?
SilverMaggie's Sig:
SilverMaggie is online now   Reply With Quote
Old 02-18-2007, 08:56 AM   #5
messenger961
It just screws off....Boy do I feel stupid.....
Best to all Tom
Old 02-18-2007, 11:28 AM   #6
Bigal470
the only thing that really matters is the size of the shaft most come with adapters...I got one from MOMO and it works good had to use an adaptor and toth is day no problems at all..
Old 02-18-2007, 06:58 PM   #7
peybella
peybella's Avatar
peybella is just warmin' up!
I found that the Manual shifter replacements will fit much better than the one's listed as automatic. It's because the shifter shaft is smaller in diameter than the standard automatic shafts.
The original will be hard to unscrew at first as I'm pretty sure the OEM uses a bit of lock tight material.
peybella's Sig:Greg
http://www.1986whs.com -
The car-
Old 02-19-2007, 05:07 PM   #8
tree 27
tree 27's Avatar
tree 27 is just warmin' up!
Thanks For The Info Fellas! Ive Been Wanting To Repalce My Shifter Knob Too, But It Seems That The Only Ones You Can Find Are Manual Transmissions! Im Glad I Know Now That I Can Go With One For A Manual Transmission.
tree 27 is offline   Reply With Quote
Old 03-02-2007, 04:59 PM   #9
kermit
kermit's Avatar
meeh too
changing mine out
