| Interior Styling Custom upholstery - Share your tricks |
Gearshift Lever-mounted Control Switches
The other day I was surfing eBay looking for decent gearshift lever knobs that I could possibly add control switches to when I came across this unit:
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=140265550923&ssPageNam e=ADME:B:EOIBSA:CA:11 ![]() When it arrived, I was able to take it apart: ![]() After some modifications, I added two switches. the one on the front side is a single-pole-double-throw momentary-on switch (3 leads will come off the switch - when the switch is depressed one set of contacts opens and another set closes) that you depress to actuate. The second side switch is again a single-pole-double-throw, this time rocker actuated (3 leads - ON/ON in this case): ![]() Now this gearshift knob borders on the comical in it's original finish with the translucent side pieces. I prepped and painted the body parts semi-gloss black, but am now torn whether to leave the red translucent side pieces as-is: ![]() To deal with the "thickness" of the knob's base versus the thin gearshift rod (I dislike chrome), I have created a thicker looking stock similer to what i did with the headrest arms: ![]() ...on the gearshift rod. however, in this shot I think the translucent red clashes not only with the wood grain but generally looks kinda ricey (please excuse the insult - I am refering to those who take imports and try to make them look/sound like something they are not): ![]() I am considering painting the inside of the lenses black, which would remove most of the red so-to-speak. I also considered painting the inside silver or gold to mimic a candy paint with those colors as the basecoat, but I think it would stand out too much. Or I could paint the exteriors the same semi-gloss black and be done with it. Anyone have any thoughts? Addendum: what may you ask are the switches for? Well, the rocker switch could arm NO2, the momentary-ON switch could actuate a line-lock, or temporarily interrupt PWR to the DSS module (this causes the CAN bus to ignore any more I/P's until a key-cycle), or also arm NO2 systems, etc... |
Hemi-sphere Dancer
And LED inside the red housings would look awesome, maybe tint it with some VHT nightshades to dareken it up and then back light it with a colored LED, that would look T*ts, like you idea for thikening the shaft, well done, beans for the mod. And BTW the shifter is reminding me of a Huey stick, what are you going to use the switched for? Taking out bogies???
#9 | |
lol! Now that's a mod! Ejector seats! I would probably just paint the inserts opaque and be done with it. I would go for a deep gloss black. As for hiding the comparatively thin stalk, you could try chopping it. Kinda looks like the new shift knob is taller than the stock anyway. Nice mod! |
#10 | ||||
Thanks! I'll add to this thread when I have installed it. I want to cut down the gearshift shaft ~1/2" or so, then shrink some black glue-lined heatshrink onto the shaft itself..right down to the bottom so no chrome shows, then a short length of split rubber fuel line hose to support the corrogated wire loom sheathing that will hide/protect the 6 electrical leads. I'm thinking now of just painting the translucent side pieces glossy black basecoat/clearcoat for durability, I just can't imagine any other color working here... Last edited by Hemissary; 10-05-2008 at 08:14 PM.. |
