| Interior Styling Custom upholstery - Share your tricks |
#11 |
this is a feature that can be turned off
#12 |
this is a list of a few things you can do with the FOB you dont need EVIC:
To turn off/on "Flash Lights On Lock/Unlock": 1. Press the UNLOCK button for 4 to 10 seconds. 2. While the UNLOCK button is pressed, (after 4 seconds) press the LOCK button. Release both buttons. The "Flash Lights On Lock/Unlock" feature can be reactivated by repeating this procedure. To turn off/on "Remote Unlock Driver's Door 1st": 1. Press the LOCK button for 4 to 10 seconds. 2. While the LOCK button is pressed, (after 4 seconds) press the UNLOCK button. Release both buttons. The "Remote Unlock Driver's Door 1st" can be reactivated by repeating this procedure. To turn off/on "Sound Horn On Lock": 1. Press the LOCK button for 4 to 10 seconds. 2. While the LOCK button is pressed, (after 4 seconds) press the PANIC button. Release both buttons. The "Sound Horn On Lock" feature can be reactivated by repeating this procedure. I tried this last procedure using the UNLOCK button and PANIC button together. It didn't seem to do anything. If anyone else finds that it changes something please let the Forum know. Automatic Door Locks at 15mph: For vehicles not equipped with the EVIC, the Automatic Door Locks can be enabled or disabled by performing the following procedure:
#14 | |
Honesty is My Best Policy
i remember someone saying you have to use Starscan to disable it?? is this true?? |
#15 |
i had to activate the feature on my ride i dont cruz with my arm on the door so no big deal to me
funny thing it worked on my car till i installed my fogs and activated them through starscan... we tried to reactivate the feature with starscan and it wouldn't work.... |
#20 |
i think they are required (in my area anyways) as a safety requirement, in case of roller over/power issue. i know when ppl go to take a license test the instructor will check the windows an locks in case you roll it an they get trapt in there. ive had friends get declined to take the driving test once an instructor inspects the vehicle an finds something like this is missing or not working.
