I see alot of people making switch holders for there ashtrays whats the dimensions to make a little cover for that? It just sits in there right? How do I go about putting the wires in?
I used sheet metal for mine pretty easy i think i use construction paper to make a template then cut it out of metal then just bent it till it fit correctly....cut holes for the switches i used.. covered in matching material from my seats (came with new seat covers) installed switches and used double stick tap to mount... to run wires just pop the shift bezel off I think it already has a hole inside the pocket to route wires to the switches....
lol my only problem is i don' t have any tools for that. I thought maybe if i had the dimensions i could go get it cut somewhere? I'm gonna try and find a dremel
