I did it! took apart the whole rear painted it black still ahve to work forword will post when done. Used Duplicolor Flat Black (yes Flat it doesnt look it) vinyal and fabric paint. First wiped everything down with prep wipes to get any anything off.Then sprayed away put out in the sun to dry then repainted and dried you get the picture. used about 4 1/2 cans of paint. im triing to post pics too so if you cant see them i could use some advise on posting them. See ya
looks good man! how did you get the parts out? ive been trying to figure that out for a while now! looks really good though!
its so simple for the whole back is 14 screws, 2 carpet push plugs, 2 10mm bolts and 2 bid nuts for the seat belts. just get a trim tool for like 8 bucks or less so you dont break anything and make sure you use the prep wipes before you paint
