All are painted to color match the car. Hope you all like it.
Started by testing my painting skills on the washer cap.
I masked off the letters and painted. When I was done I peeled it off and went over it with a sharpie and the put 4 coats of clear on it.
After that I pulled out the gauge rings, ignition ring, radio bezel, and ashtray cover. Cleaned them with soap and rubbing alcohol.
Then I put on 2 coats of adhesion promoter, 4 light coats of paint, and 3 light coats of clear then 1 heavy coat of clear. It took about 2 days.
Finally I wiped them down and put on some Turtle wax Ice then 2 coats of Ice detailer spray and installed.
Well there it is. Next weekend I will be painting the fuse box cover and maybe the radiator shield(its going to say magnum on each side and the letters will taper with the contours of the shield). When I get another long weekend I will take out the sides of the center console and paint them the same color.
