Old 09-04-2007, 11:07 AM   #1
MadDad
Resistance is Futile
MadDad's Avatar
MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!
Anyone got Black Seatbelts?
Since I'm doing the color change on the interior I thought I'd switch out the seatbelts too. The parts tech's 'puter only gave him codes -- no colors -- and none of the LXs on the lot had black belts so the VIN deal was out.
Does Chrysler even offer black belts? I suppose I could try dye on the belts.
Help? Suggestions?
Old 09-04-2007, 11:56 AM   #2
HemiLover
They are available, as seen in the pic below but I believe they are dark slate (like the dash), not black..
Old 09-04-2007, 11:58 AM   #3
HemiLover
...come to find out I have the dark ones!
I'll PM you my VIN....
Old 09-04-2007, 12:03 PM   #4
Meat_Wagon
Meat_Wagon's Avatar
Meat_Wagon is an unknown quantity at this point
You could take the belt assembly apart and go to a junkyark and get some belts that are black. I did that in my impala. i just took out the passanger side belt and went searchin through the yard to find a belt that was the same width. then i took out all the belts and reattached all the hardware. I ended up having to take them to a professional seanstress to have them sawn. it was alot of work but it was worth it.
Meat_Wagon is offline   Reply With Quote
Old 09-04-2007, 01:57 PM   #5
MadDad
MadDad's Avatar
Thanks HL and olly! I knew I could count on my CM compadres!
