Overhead console removal?
Results 1 to 7 of 7
    Newbie Houseofhemi is an unknown quantity at this point
    Apr 2012
    North Carolina
    16
    Alright Guys. How do I remove the overhead console(map light, homelink, sunroof control area). Need access to power for detector. Thanks
    Jim
    MR 3 FIFTEEN FROST's Avatar
    FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious!
    Mar 2009
    ILLINOIS [815]
    11,838
    It's only held in by three push clips. Use a putty knife or somethin to get under the edges and gently pry it to start seperating the console from the headliner. From there, use your fingers and start to to pull downward until you get those pins to seperate. It's held in there really well so it'll take some effort to seperate em since it's the first time removin it. After this, it'll come out much easier next time. Once it's loose, there's a wire that you'll need to unplug and the console will be completely out.
    Just lower it.
    where's my airbrush?? GreenKing's Avatar
    GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler! GreenKing knows more than the President of Chrysler!
    Dec 2007
    @ The Chop Shop
    14,764
    ^yup. Just did mine again tonight, was just that simple!
    Senior Member Wexy21's Avatar Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar! Wexy21 is a Magnum Superstar!
    Apr 2011
    St. Louis
    1,698
    You'll need to be carefull unplugging this wire. It's a pain (atleast on mine). You need to unscrew the black lid to get it off, but after that, what was said above is all you need to do. here's a pic for reference and a link to my post when I had troubles getting the wire off.
    http://www.custommagnums.com/forums/...to-inside.html
    05 Magnum RT...87 Grand National...65 Fairlane 500...91 GMC Syclone...98 Buell S1W
    Mar 2009
    ILLINOIS [815]
    11,838
    Just find that tab that snaps the plug into place and use a lil flat head to seperate it. I don't have a sun roof, but I'm sure it's the same type of plug. It's the same thing for the sun visors too.
    Just lower it.
  7. #6
    Apr 2012
    North Carolina
    16
    Thanks Guys. Easy As you said.
    Jim
  8. #7
    Member FFEdge's Avatar FFEdge is a Magnum Expert in Training! FFEdge is a Magnum Expert in Training! FFEdge is a Magnum Expert in Training!
    Nov 2010
    NW Alabama
    406
    Anyone have a picture of the hole it goes in when you remove the console?
