Old 12-25-2006, 08:52 PM   #1
Greenmag
Greenmag is an unknown quantity at this point
Auto Dimming Mirror
Has anyone installed one of these? Gentech seems to be a supplier - but not sure of install problems or time to do it.
Dick
Greenmag is offline   Reply With Quote
Old 12-25-2006, 09:03 PM   #2
peybella
peybella's Avatar
peybella is just warmin' up!
I installed an OEM mirror with the Blue-tooth capability. Blue tooth is difficult but the auto dimming is just a matter of proper wiring that runs through the area up under the sun glasses holder plate. (It just snaps down out of the way.)
Give me some time and I will get you the wiring diagram but it's fairly simple as the hot and ground wires needed to get the dimming to work is located in the harness mentioned in area above. I tied the mirror and my radar detector into this harness.
peybella's Sig:Greg
http://www.1986whs.com -
The car-
Old 12-26-2006, 06:37 AM   #3
Greenmag
Thanks - did not know there was an OEM option - will check in with my dealer today.
And I'll watch for the diagram - thanks
Dick
Old 01-12-2007, 06:00 PM   #4
Greenmag
Peybella:
I have the OEM mirror - there was no wire with it to attach to wiring harness in the area above - are there some pix for this install?? The module that contains the sunglass holder and the spotlights looks like it snaps right out - but I don't want to snap some tabs that are critical
Thanks
Dick
