Who Knows About Center Console Repair ???
Results 1 to 10 of 10
    Newbie Mrgreezy is an unknown quantity at this point
    Jun 2012
    Redding Ca
    2
    Unhappy Who Knows About Center Console Repair ???
    Needing Help !!!
    Mod Gnome Wrangler MadDad's Avatar
    MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge! MadDad is the keeper of all Magnum knowledge!
    Feb 2007
    Gray, TN
    5,920
    Welcome to the forum -- you will probably have a better chance of getting some help if you post a question with some specifics about what you need in the appropriate section.
    Senior Member FloridaRT's Avatar
    FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious! FloridaRT is a Magnum Genious!
    Aug 2007
    Ocala, FL
    3,319
    Yup, we need more information before we can help you.........................
    Bob
    Bob in Ocala, Florida (73 year old guy who loves cars), 05' Magnum RT.
    Many mod's, all of Danko products and a few 402 Motoring items.
    Member mavis' minion's Avatar mavis' minion is just warmin' up!
    May 2012
    LAX WI
    75
    um... the answer is 42 !?! not sure though without specifics. Mounting issue or bezel repair or wiring concern ??
    "evening officer. no officer. i have no idea. oh?? naw that can't be right. yes officer i will follow you to the station. ><
    MR 3 FIFTEEN FROST's Avatar
    FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious! FROST is a Magnum Genious!
    Mar 2009
    ILLINOIS [815]
    11,840
    Welcome from Illinois. We need more info, please.
    Just lower it.
  7. #6
    Jun 2012
    Redding Ca
    2
    There is 3 bolts holding down the center console which are located in the center console box underneath the rubber mat, I got pushed into my driver's seat Via horseplay, (stupid doing it around my ride I know) but the problem is the bolts have busted through the plastic about a half inch all around each bolt, I thought about using big washers but the area is small and limited space I want to anchor this console so not even god could move it if he wanted to, any Ideas ??? help me out guys !!! -Greezy.
  8. #7
    Mar 2009
    ILLINOIS [815]
    11,840
    Just lower it.
  9. #8
    Senior Member The_gunslinger's Avatar The_gunslinger is a Magnum Expert in Training! The_gunslinger is a Magnum Expert in Training! The_gunslinger is a Magnum Expert in Training!
    Feb 2011
    Houston TX
    1,421
    The meaning of life!!
    I would say washers would be possible for a quick fix. There's not much that would hold it down better than the factory set up. Being that the bolts have pulled through already, you have now weakened the.plastic around the holes so unless you use some pretty big washers they're not going to hold all that well.
    The thing that separates the men from the boys, is how much C4 they have in their toys!
    Try not. Do or do not. There is no try.
    Nerves make you cautious, fear makes you stupid.
    http://www.spacecitylx.com/
    Some people just need a high five... In the face... With a chair.
  10. #9
    Feb 2011
    Houston TX
    1,421
    Welcome from Houston btw.
  11. #10
    Senior Member NYCmagnum05's Avatar NYCmagnum05 is making a name for themself!
    Jan 2012
    Q BOROUGH NyC
    1,828
    Welcome from NYC
    I am here: http://tapatalk.com/map.php?jrap13
    tee jay
