Go Back   Custom Dodge Magnum Forums > Tech Articles > Misc. Mods
Misc. Mods Tech Articles only!
Old 03-11-2007, 06:55 PM   #1
steve
The Boss
steve's Avatar
How to remove the center console
This is a simple writeup on how to remove the center console out of your Dodge Magnum. While this isn't a mod in itself, you may need to use this info to complete another mod, i.e. installing a stereo system.
1. Remove the center bezel but pulling towards you. Next you must remove the ash tray. A flathead or panel popper helps to get the ashtray out. It is held in by 2 clips.
2. Remove the 2 phillips head screws behind the ashtray.
3. Remove the 2 phillips head screws underneath the little mat above the shifter.
4. Open up the center arm rest/storage compartment. At the bottome you will need to remove the 3 bolts.
5. Disconnect any wiring harness and slowly remove the console.
Thats it.
steve's Sig:Steve
steve is online now   Reply With Quote
Old 03-15-2007, 08:19 AM   #2
Strykker
Strykker's Avatar
Strykker is a Magnum Expert in Training!Strykker is a Magnum Expert in Training!Strykker is a Magnum Expert in Training!
Thanks, It is so simple but if you don't know where to start you can certainly tear some stuff up figuring it out. I got a couple ideas this helps a bunch.
Strykker's Sig:
Sig by Hazman
Magnum Owners Club #1293
5.7L Hemi Registry #00619
http://www.cardomain.com/ride/2331622
Strykker is offline   Reply With Quote
Old 09-17-2008, 08:31 PM   #3
DKelso
DKelso is an unknown quantity at this point
How do you get the heater controls loose from the basel as you show and hoe did you get the lighter unhooked? I would just cut them if i didn't need them for a power port.
Thanks,
Race on,
Kelso
DKelso is offline   Reply With Quote
Old 09-17-2008, 08:49 PM   #4
fam0516
fam0516's Avatar
fam0516 is a Magnum Superstar!fam0516 is a Magnum Superstar!fam0516 is a Magnum Superstar!fam0516 is a Magnum Superstar!fam0516 is a Magnum Superstar!fam0516 is a Magnum Superstar!fam0516 is a Magnum Superstar!fam0516 is a Magnum Superstar!fam0516 is a Magnum Superstar!
Send a message via AIM to fam0516
ugh i did it once!! such a pain!!
fam0516's Sig:
Keep callin it a hearse..N..Youll be in the back!
fam0516 is offline   Reply With Quote
Old 09-17-2008, 09:13 PM   #5
TheFOSS
TheFOSS's Avatar
TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!
I belive you have little tabs on the side.. i did it once also.. I got the console loose in the front. next to the air controls and lift that end up to the roof. Reach under and you can feel the tabs..
TheFOSS's Sig:
2005 InfernoRed R/T
Mods:
Engine: Mopar CAI , JBA Shorty Headers , Diablo Predator , Custom painted engine cover and pillers, BT oilcap, fuse box cover, power steeriing, and washer fluid cap
Exterior: Shaved Side Moldings and Badges , Tinted Tails
Interior: Red C/F Dash Kit , BT shiftknob , Modified Shifter
TheFOSS is offline   Reply With Quote
Old 09-17-2008, 09:17 PM   #6
Jaymag
Jaymag's Avatar
Jaymag is making a name for themself!Jaymag is making a name for themself!
Send a message via MSN to Jaymag
Good write up, i'm planning on doing the no-esp mod this weekend so this will save me some time looking for bolts
Jaymag is offline   Reply With Quote
HTML code is On
