Go Back   Custom Dodge Magnum Forums > Tech Articles > Misc. Mods
Misc. Mods Tech Articles only!
Old 08-14-2007, 05:26 AM   #1
05 MAG RT
05 MAG RT's Avatar
05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!
HID flickering fix.
If your HIDs flicker this is the capacitor (radio shack) you need to put on the relay switch:
If you don't have HIDs and want some that won't flicker, buy them from LIGHTING623 on E-bay, they work with our Magnums, get 5000k, they are brighter and cause less glare than higher K, I also recommend you get projector headlights to run your HIDs (better light cutoff pattern, see for yourself in my sig link)
05 MAG RT's Sig:CHECK OUT MY RIDE (CLICK HERE)
See you there: www.lasvegascarshows.com
MY 42" LCD HDTV/360/5.1SETUP
The new 360 avatars suck big time, thanks MS!
Old 10-13-2007, 06:58 PM   #2
3.57MagnuM
3.57MagnuM's Avatar
3.57MagnuM is a Magnum Expert!3.57MagnuM is a Magnum Expert!3.57MagnuM is a Magnum Expert!3.57MagnuM is a Magnum Expert!
I know this thread has been sitting for two months but I just found it now.
I have an sxt magnum and I was wondering where I would find the relay switch that I need to place the capacitor on?
T.I.A.
3.57MagnuM's Sig:"I did absolutely nothing and it was everything I thought it could be"
3.57MagnuM is offline   Reply With Quote
Old 10-13-2007, 09:00 PM   #3
kermit
kermit's Avatar
radio shack or any electronic shop!
Old 10-13-2007, 09:41 PM   #4
3.57MagnuM
3.57MagnuM's Avatar
No, I meant how do I know which relay switch I have to put the capacitor on.
I have the capacitor already, I'm just not sure which relay is for the headlights.
Old 10-13-2007, 10:08 PM   #5
05 MAG RT
05 MAG RT's Avatar
Relay that came with the HID kit, if you didn't get one with the kit you have to get a universal wiring harness, can get it from here: Xenonrider.com - Automotive Xenon & Bi-Xenon HID (High Intensity Discharge) Headlight Conversion Kits for Cars & Motorcycles Xenon rider
Old 10-14-2007, 04:28 AM   #6
3.57MagnuM
3.57MagnuM's Avatar
Thanks Mag RT.
I misunderstood then.
What I have is the xenon hyperwhite replacement bulbs, not an hid kit.
But they do flicker every now and then which is why I asked.
Would the same capacitor work if I just placed it directly into the bulb socket?
T.I.A.
Old 10-14-2007, 05:22 AM   #7
05 MAG RT
05 MAG RT's Avatar
Thanks Mag RT.
T.I.A.
Those are not HID's, they're just cheap painted bulbs, HID flicker will act like a strobe light, if your 55w bulbs flicker once in a while, use quality bulbs, like sylvania ST's!
This is an HID thread.
Old 10-24-2007, 07:52 AM   #8
MY357
MY357's Avatar
MY357 is just warmin' up!
Last night I noticed when I was driving down a highway, I turned on my brights then turned the fan on full blast and the headlights flickered for a few secs it was pretty odd...I did this a couple times and was just wondering if the charging system wasnt reacting fast enough..
MY357 is offline   Reply With Quote
Old 10-26-2007, 05:23 AM   #9
05 MAG RT
05 MAG RT's Avatar
New HID kit from the same vendor (flicker free) for $105, with new slim ballasts: eBay Motors: 9006 10000K AUTO HID CONVERSION KIT -Super Slim Ballast (item 130162337679 end time Nov-09-07 12:09:04 PST)
Old 02-17-2008, 08:34 PM   #10
Justin@AACstyle.com
Justin@AACstyle.com's Avatar
Justin@AACstyle.com is making a name for themself!Justin@AACstyle.com is making a name for themself!
Originally Posted by 05 MAG RT View Post
I also recommend you get projector headlights to run your HIDs (better light cutoff pattern)
You see most cheap HID kits (ie ebay hids) use a rebased HID bulb to save money, the most common bulb is a D2S which they modify to fit any light (ie: 9006) the D2S was not designed for a reflector and is wide open. Reflectors have facets that reflect light onto the road. If you use a rebased bulb like a D2S the element (referred to the filament in the halogen application) is moved forward several mm which causes the angle that the light hits the facets to change and thus throws light everywhere and into the faces of oncoming traffic.
With our kits the bulbs geometry is an exact replica of the 9006XS so the element is exactly where the filament is positioned in relation to the
reflector therefore performs as intended. The light is focused on the road where intended but just brighter.
Dont take my word for it, here is a Charger output example with our 6000K HID Kit:
Notice the light is focused and aimed 100% under the field of vision of any other drivers.
The light is properly focused, just amplified.
Justin@AACstyle.com's Sig:-Justin
"Now serving all LX platforms!"
Advanced Automotive Concepts
www.aacstyle.com
1(800)407-5776
www.AACstyle.com
Justin@AACstyle.com is offline   Reply With Quote
HTML code is On
