How To: Replace the Hood Struts
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
    Senior Member uscbigdawg's Avatar uscbigdawg is a Magnum All Star! uscbigdawg is a Magnum All Star! uscbigdawg is a Magnum All Star! uscbigdawg is a Magnum All Star! uscbigdawg is a Magnum All Star! uscbigdawg is a Magnum All Star!
    May 2009
    Palmdale & Sacramento, CA
    1,605
    So, got these for Christmas from my lovely wife and at the request of a couple of folks, here's what I did on the install. I apologize that the pics are after the fact.
    Step 1: Check your kit from Mopar Supercenter
    - You should have 2 struts and 2 ball studs
    (For simplicity, I only removed 1)
    Step 2: Identify the hole in the fender(s) where the ball stud is to go and the stud that's already on the hood (forgive the crappy graphics as I'm just using the junk on Photobucket).
    Step 3: Thread the hole for the ball stud.
    - The ball stud is probably self-tapping, but for $15 I got a tap & die kit from Harbor Freight
    - The ball stud is a M8 (more specifically a M8-1.25) so pull out your M8 bit, place it in the T-handle and lock it down
    - You can apply oil to the thread cutter, but I didn't as it was only about a 1/8 thick piece to get through.
    - Keeping the tap vertical, just apply some pressure and turn. You can start the cut with both handles on, but after like 1 rotation, one handle has to come off and you do a crappy dance unlocking and relocking the tap (my power drill wasn't gettin' it as the battery was super low).
    - Repeat twice.
    Step 4: Insert Ball Stud
    - I spun the ball stud on just to "marry" the threads and it was perfect. Backed it out and applied some blue Loc-Tite and called it a day. You can break Blue Lock-Tite pretty easy. Red requires heat.
    Step 5: Get your two ball studs and attach the strut
    - This is better with two people or if you're tall as in this case, I inserted the strut to the bottom stud, held the hood with my right hand (the hood stand has the hood higher than the struts come), and then popped in the top part of the strut.
    Done.
    Hope that helps for all the SE/SXT guys that don't have struts.
    Rich
    ETA: The only tools were the tap & die set and a 12 or 13mm wrench (can't remember).
    Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge!
    Warren, MI
    18,712
    Not only the SE/SXT guys, Rich! My loaded R/T/R did not come with them either.....
    Good Write up!
    Find the MAGNUM!!! 70.91.121.98 user:custom password:magnum
    2008 R/T/R, LED tails, Stealth bulbs, DUAL color interior lights, lockpick, rear camera, Digital TV,
    AIRBRUSHED ENGINE COVER, Painted Calipers
    May 2009
    1,605
    Pics put in correct order.
    scotto is gettin' serious now! scotto is gettin' serious now! scotto is gettin' serious now!
    Jun 2009
    Windsor, Ont
    291
    Its a 13 mm, I just did this last month as well. And its also not too hard to hold the hood up with your head, I always get stuck doing 2 man jobs when nobody else is available.
    NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge! NOTPAID4 is the keeper of all Magnum knowledge!
    Feb 2008
    Salisbury, North Carolina
    25,077
    Both of my 05 RT's came with them, but both the 06's, the SRT and SXT did NOT! I don't really mind the prop rod, althought for shows I just a "rams head" sword... I like the look of it to prop the hood up!
    My Cars:
    2006 Magnum SRT8 "SHADOW"
    2005 Red Magnum R/T "LUCKY"
    2005 Blue Magnum R/T "BLUE"
    2006 Chrysler 300SRT "CHEETA"
    Plus have SEVERAL OTHER RIDES
    "Old Geezers LOVE cars Too!!!
    Hemi Registry #864 2/15/08
    Jim
  7. #6
    Fab HO Magworks's Avatar
    Magworks is a Magnum All Star! Magworks is a Magnum All Star! Magworks is a Magnum All Star! Magworks is a Magnum All Star! Magworks is a Magnum All Star! Magworks is a Magnum All Star!
    Aug 2009
    For now...Michigan
    968
    Gotta do this...Great write up Rich...Thanks for the info...
    Mark
    2008 Light Sandstone Metallic.
  8. #7
    Senior Member QuickSilver08's Avatar
    QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge! QuickSilver08 is the keeper of all Magnum knowledge!
    May 2008
    Cincinnati, OH
    9,173
    Lookin good! Now you need a PCM cover
    PCM Cover Kit - Challenger / Charger / Magnum / 300
  9. #8
    May 2009
    1,605
    Eh...you'd be surprised what you can find in the yards/Craigslist. Too, I'm holding off on that 'til I get my cabin filter done.
    Rich
  10. #9
    www.zygotecustoms.com Greg095's Avatar
    Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler! Greg095 knows more than the President of Chrysler!
    Nov 2006
    Utah
    11,940
    Nice writeup. Moved to Tech.
    Wheels // Accessories // Body kits // Suspension // Electronics
  11. #10
    Senior Member igolo's Avatar
    igolo is a Magnum Superstar! igolo is a Magnum Superstar! igolo is a Magnum Superstar! igolo is a Magnum Superstar! igolo is a Magnum Superstar! igolo is a Magnum Superstar! igolo is a Magnum Superstar! igolo is a Magnum Superstar!
    Aug 2008
    Mobile, Al
    6,555
    Gotta get me a set of those!!
  12. #11
    Um... hullo? onelook's Avatar
    onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious! onelook is a Magnum Genious!
    Oct 2008
    Central Utah
    3,459
    Eh!? Your SRT didn't come with them!? I thought all SRTs had those?? I guess I just got lucky!
    See my gallery here: OneLook's Gallery
  13. #12
    Magnified rwalshphoto's Avatar rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious! rwalshphoto is a Magnum Genious!
    Oct 2007
    Phoenix, AZ
    2,318
    Nice write up! Mine were wore out so I bought some a couple weeks back from Mopar Supercenter (LX hood strut kit)...I think they have them on sell for $59 for the pair. I've got extra of those mounting ball-studs if anyone wants them. My car is an 05 so I didnt need them - just replacing the worn struts.
    Starting over with a new Magnum RT... 6.1L with SRT Max Cam, Corsa catback, SRT Suspension, silver Brembos, graphite powder coated Charger SRT wheels, frost white intake manifold and valve cover, matte black engine bay, 300C SRT front end, Black Ops 300-Challenger style carbon fiber hood coming soon. Project "SnoMachine" all work performed by Plum Floored Creations.
  14. #13
    May 2009
    1,605
    For those that need/want this upgrade, take up Ryan on his offer and then you can pick up struts (especially the bad ass stainless ones) from http://www.strutwise.com/
    Rich
    ETA: I'm pretty sure they don't specifically outline the Magnum hood strut, but do for the 300M. Same thing.
  15. #14
    I'm a liar Vadermag's Avatar
    Vadermag is a Magnum Expert! Vadermag is a Magnum Expert! Vadermag is a Magnum Expert! Vadermag is a Magnum Expert! Vadermag is a Magnum Expert!
    Dec 2009
    ATL
    388
    Just ordered mine from Mopar Supercenter $52.13.
  16. #15
    Newbie Welcho's Avatar Welcho is an unknown quantity at this point
    Jan 2010
    Abilene, TX
    3
    Just got mine in today, shipped to TX for $64.16 from Mopar Supercenter. ordered on the 7th got here 2 days later at 0900. Installed in 5 mins total. As the Geico commercial says, easy peasy lemon squeezey
