Now you are ready to remove the last 2 fasteners at the top of the fascia...
Once those are out it's just a matter of a little tug on each side of the fascia...
If you have foglights, make sure not to pull too hard or too far.
If you have the foglight option just give them a 1/4 turn (counter clockwise)
and the bulb assembly will pop out.
Be careful not to knock them around too much.
Also I would suggest that you check them prior to reassembling the front end to make sure
that the filament did not break and that they light up.
Note: You can access the foglights for replacement by just removing the fender well fasteners
and reaching up inside. It's not necessary to have the fascia removed to get to them.
Final step is removing the fascia.
There is a styrofoam pad on the inside that just sits on the metal bumper support.
Here it is in all of it's glory.....
