I ordered a low temp 180 degree thermostat by Jet. Does anyone know the benefits of these other than your engine running cooler and possibley releasing horsepower, or is that about it. I only paid $30 for it.
hello i went to install a 180 stat in mne when i removed the factory one i found it was a 180 degree stat from the factory i returned the one i bought my engine is a 3.5
This may be a dumb question but with the low temp thremostat how hot does your engine run? Mine is an average of 220 degrees. Sometimes hotter depending on how hard and how much I drove it.
depending on what you want i for, but most lower temp t-stats are acquired to prevent dreaded heat soak that causes a loss of hp and time on the track...unless you plan on hitting the track alot then the stock t-stat is good enough for you...
BUT
If you go the t-stat way, just know a fan mod of some sort will definitely be needed.
