V6 Performance, Cams, TBs, Dyno, PICS / VIDEO
V6 Performance Parts: Write Up with Photos and Video
Parts to be discussed include:
Inertia Motorsports V1.1 Camshafts w/ lash caps
CNC Ported/Polished 74mm Throttle Body (BilletTech and I - Joint Venture)
Ported/Polished "Gasket Matched" Lower Intake Manifold
Disclaimer: I do not claim to be an expert of any sort. The opinions presented here are that of my own and others gathered from independent testers. I do not have any baseline numbers for my car so for comparison sake I am going to use Nathan's (BritishNate's) baseline numbers of 174 horsepower and 195 torque which was made on the same dyno in similar conditions as the information below. Our track times have always been comparable and our mods are nearly identical.
My car's current configuration:
2005 Dodge Magnum SXT (47,000miles)
Inertia V1.1 Cams
CNC ported/polished 74mm Throttle Body
Ported/Polished lower intake manifold
Airhammer HO Intake
Blastin Bobs 10db dual conversion (replaced suitcase w/ Dynomax muffler)
Custom tuning by Mike Lafrad
89 octane pump gas
Current best numbers:
15.62 @ 90 (700 DA)
199 horsepower, 220 torque
Air / Fuel Ratio:
[b]VIDEO:
[ame="http://www.youtube.com/watch?v=0WyeIqZ0iiM"]YouTube - Dodge 3.5L Cammed V6 Dyno[/ame]
The break down:
Estimated Gains based on averages: +25 horsepower, +25 torque
As you can see the car is running pretty rich especially at WOT. I do not have a wideband and tuning is still an on going process through email with Mike.
The differences in the runs shown are with different variations of throttle bodies, 1 test ported unit and 1 stock. The test ported unit is not the production unit nor does it reflect that gains that were found with the production unit tested on Nate's car. The blue line represents the test throttle body and the red represents stock.
The discrepancies: The run made with the ported test throttle body was literally driven right off the street onto the dyno completely heatsoaked, 2 test pulls before recording data. So the car was HOT (ECT of 218)! We did 3 runs and took the best and swapped out the throttle bodies. The car sat for about 20 min with 2 blower fans and the cool-it mod in while we swapped the throttle body. We did 3 more runs with the stock throttle body on with the ECT at about 190).
Photos:
Nate's current configuration:
Inertia V1.1 Cams
K&N Intake
Blastin Bobs 10db dual conversion (replaced suitcase w/ Magnaflow muffler)
89 octane pump gas
15.59 @ 89 (700 DA)
190 horsepower, 205 torque (with all mods except throttle body)
Dyno comparing with and without throttle body:
Without: 190hp, 205 tq
With: 195 hp, 210 tq
Gains: 5 hp, 5 tq
Video:
[ame="http://www.youtube.com/watch?v=AoKWpdh3izA"]YouTube - Dodge V6 Inertia Cams Dyno[/ame]
The Break down:
Car was ran at full heatsoak for every run including stock an ported throttle bodies. The only difference between my car and his are the ported lower intake manifold which I will be porting on his car probably over the weekend and probably get it back on the dyno to measure gains specifically for that.
The NEED for a Catch Can...
Throughout the tuning process we have encountered knock retard which has seemed to be reduced or eliminated every time I have remove and cleaned my upper manifold and throttle body. (which I have done so for modding purposes...lower manifold and throttle body testing). I believe the main culprit to be oil making itself through the upper manifold and into the firing chamber in turn causing knock.
Photos:
Parts Photos:
Throttle Body
Lower Intake Manifold:
Cams:
JetHot Sterling Ceramic Coated Valve Covers & Timing Covers, JBA Coated Shorties, Inertia Motorsport V1.1 Camshafts, Port Matched Manifold & Plenum, Ported/Polished Throttle Body, CMR Tune by Johan, Airhammer HO, Custom Catback
CNC Inertia Performance Heads
03-11-2009 08:47 PM
# ADS
Sponsored Advertiser
Great work ryan my car is running really good with that ported tb has a lot of pull great throttle response real good i had her on the highway she really opened up nice
Death Before Dishonor...
Morning bump, updated post with catch can info
C'mon guys I know there are more than 2 people who give a shit about V6 performance on this site. Where is everyone?
Im here im here....
Weve talked Ryan, nice write up too btw!
sweet, dude! after all of that, imagine what the Modern Muscle 3.5L V6 blower would do!
great job!
360rwhp / 390rwtq
Spartan Max Cam - SRT Valve Springs - Inertia Forged Pushrods -
Custom Predator Tune - JET 180º T'stat - DSP - BT Oil Catch Can -
K&N CAI - 6-speed-Challenger Motor Mounts - Ported Thottle Body -
JBA Shorty Headers - JBA/HHP Catless Mid Pipes - SLP Loudmouth -
SLP Pulley
