Results 1 to 9 of 9
    Member Funky Hemi's Avatar Funky Hemi is just warmin' up!
    Oct 2009
    Arizona
    180
    180 T-stat installed, help adjusting predator?
    I was wondering what/how/why the Predator should be adjusted considering this new mod. I dont know if it matters but I live in AZ and it is really hot here about 8 months out of the year! Thanks
    -Ross
    2006 Magnum R/T RWD - Custom Magnaflow Catback & Removed Resonators - RotoFab CAI w/ No Air Silencer - 180 Tstat - DS Predator 91 CAI - OEM Boston Acoustic - OEM 4.5" LCD Nav/DVD/BT/Aux - 2-way Alarm/Remote Start - Tint - 22" Forged Aluminum Wheels - 265/35/22 Falken Tires - Debadged Hatch
  2. # ADS
    Sponsored Advertiser
    Nov 2006
    Interwebz
    Who's Counting
    Senior Member Prospector's Avatar
    Prospector is a Magnum Superstar! Prospector is a Magnum Superstar! Prospector is a Magnum Superstar! Prospector is a Magnum Superstar! Prospector is a Magnum Superstar! Prospector is a Magnum Superstar! Prospector is a Magnum Superstar! Prospector is a Magnum Superstar!
    May 2007
    Cincinnati, OH
    7,824
    PM Fireman2118 for fan adjustment
    PHIL SXT
    Dual Magnaflow Cat Back Exhaust System
    K&N Series 63 CAI, Ported Throttle Body
    Big Bully Catch Can, Diablo Predator
    Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge! Radglenn is the keeper of all Magnum knowledge!
    Warren, MI
    14,387
    If you do not adjust the fans they will not come on with the lower temps...They are programmed to come on over 200 ish......I reprogrammed mine and the car stays at 186....all day.....
    Here is the post from Fireman2118 (bill) to me when I did mine....
    .Here's how I set up my fan speeds with a 180 thermostat. They have my car running at 183 to 186 and on hot days in traffic, it may get to 192 tops.
    The temps could be set cooler but then the fans would be running too much, which puts them at risk of wearing out too quickly. It's best to go with a 170 thermostat
    if even cooler temps are desired. With a 180 thermostat, I've found these settings to be a good balance between fan longevity and cool running.
    When in the Predator, load your tune and select "modify tune"
    You'll see
    "Cooling fans A/C off"
    "Cooling fans A/C on"
    select
    "Cooling fans A/C off" Here, you'll have 6 settings.
    Set them as follows -As the temps are set make sure to save each one.
    High MPH HS fan on - 192.19
    High MPH LS fan on - 184.99
    High MPH MS fan on - 192.19
    Low MPH HS fan on - 192.19
    Low MPH LS fan on - 184.99
    Low MPH MS fan on - 192.19
    Now go back to "modify tune" and select "Cooling fans A/C on"
    Here you have 3 settings. Set as follows
    HS fan on - 192.19
    LS fan on - 184.99
    MS fan on - 192.19
    These setting will keep your car in the mid 180s to 190 or so.
    Radglenn's Rad Mag..........................................HEMI registry#1003
    FIND THE MAGNUM IS BACK!! 70.91.121.98---- logon: custom---- password: magnum
    www.3gcustomz.com parts, parts, parts!! www.radglenn.com My Site, poke around some
    Member 1HOTWGN's Avatar 1HOTWGN is making a name for themself!
    Aug 2009
    Seacrest Beach, Florida
    58
    You'll see
    select
    HS fan on - 192.19
    LS fan on - 184.99
    MS fan on - 192.19
    This is a GREAT post...
    Hemi registry #1020
    SRT-8 #1, shaved handles & rear wiper, custom airbrush, stainless steel motor bay, stainless steel Air-Hammer, stainless steel Magnaflow cat-back, Billet Technology catch can w/ bracket-WOW, Billet shift handle, HID's w/halos, smoked LED tails.
    Oct 2009
    Arizona
    180
    Perfect. Thanks!
  7. #6
    Oct 2009
    Arizona
    180
    It sure seems like my fans are on A LOT! As soon as my Magnum warms up it seems like the fans never turn off.. If this is not normal I am thinking I got the wrong T-stat.. Is there anyway to check the T-stat that was installed? (the Mag's previous owner told me he is 100% it the 180 was installed)
  8. #7
    Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge! Fireman2118 is the keeper of all Magnum knowledge!
    Foster City, CA
    7,438
    You may have the wrong thermostat installed. The fans will operate a bit more than usual but they shouldn't be on all that much.
    I would recommend the Jet 180 thermostat (Part # 10183). I just switched to that when I had my heads and cam installed. It works really well.
    '05 R/T 370 rwhp / 390 rwtq - PPP stage 3 big valve heads, PPP/Comp stage 2 cam, forged pushrods, 6.1 lifters, 25% UD pulley, JBA headers, JBA mids, Corsa exhaust, Paramount billet stator 3400 stall TC, Mopar TCM, Silver box electronic shift kit, 215mm diff. w/3.06 gears, Jet 180 t-stat, DS Predator, CMR by Johan, Aria M CAI, Taylor 8.2mm short wires, Eibach Sportline springs, Pro dampers & sways, REM adj. endlinks, REM strut bar, Wilwood stage 2 big brake kit, 22" KMC Dime, Dunlop SP Sportmaxx
  9. #8
    Member scarin's Avatar scarin is just warmin' up!
    Sep 2009
    Scottsdale, Az
    30
    Ok I have read a bunch of threads about this and Still not sure I get it. A little slow tonight. My mag started throwing a 0128 code so my first step is to check fluid level and replace the Tstat and hope that solves the problem. From what I have read many of you have gone with the 180 tstat but this is only good with a fan speed adjustment. Since i do have a CAI but not a Predator I should go with a stock Tstat until I am ready to buy a Predator. Is this accurate?
    2005 RT AWD HEMI - Cool Vanilla
  10. #9
    Warren, MI
    14,387
    That would probably be a good idea, when I installed the 180 without adjusting the fans, nothing changed, she still ran at 210........after the predator, 185......
