can some one help me !!!
Results 1 to 8 of 8
    Newbie flow11234's Avatar flow11234 is an unknown quantity at this point
    Jul 2011
    pa
    6
    Unhappy can some one help me !!!
    two issues
    • my oil light keeps blinking on and off ,for example this moring on a 45min drive it did it twice,it comes on blinking and then it goes off
    I already checked the oil levels and they where fine,im lost on this one .
    • my window washer fluid doesnt work its filled up and also when i hit the swich i dont hear the nose as if its doing anything
    help me please
    Who Dat !!! Ren504's Avatar
    Ren504 is a Magnum All Star! Ren504 is a Magnum All Star! Ren504 is a Magnum All Star! Ren504 is a Magnum All Star! Ren504 is a Magnum All Star! Ren504 is a Magnum All Star!
    Dec 2009
    New Orleans, Houston
    1,406
    I can't help with this one homie but someone will chime in soon. Hope you get it fixed!!
    In Memory of Danny Cox
    5/27/92 - 8/7/11
    Senior Member D-LASH's Avatar
    D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious! D-LASH is a Magnum Genious!
    Oct 2009
    NC from LI,NY
    4,301
    <bump> for some help
    Taking mine to the dealer tom. If it's under warranty, and a nice low deduct., that's the best thing to do, of course someone'll do their best to help out
    GL
    Member Psssdoff's Avatar Psssdoff is a Magnum Expert! Psssdoff is a Magnum Expert! Psssdoff is a Magnum Expert! Psssdoff is a Magnum Expert! Psssdoff is a Magnum Expert!
    Oct 2009
    the big smoke, T.O.
    517
    if you're not hearing the sprayer pump, chances are it's not getting power...personally i'd check the fuses....according to the manual, it should be #18, a pink 30amp fuse under the hood for the windshield wiper/washer....although if the wipers move but not spray it's probably not the fuse but rather the pump itself, or the switch on the steering column.....does the rear sprayer work? if so, it's probably the button on the end of the stalk mounted lever.....
    2005 SXT
    Pioneer Speakers front and back
    DEPO Projector Headlights
    DDM 5000K HID Kit
    Big Bully SRI
    WeatherTech FloorLiners
    Class II Hidden Hitch
    BT Catch Can
    Strutwise Stainless Steel Hood and Tail Gate Struts
    Drake's Billet Strut Tower Brace
    MOPAR Remote Starter
    Interior Light LED Conversion
    Switchback LED Signal Lights
    Pioneer AVH-P4400BH Headunit
    They call me Destroyer MagWag's Avatar
    MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge! MagWag is the keeper of all Magnum knowledge!
    Jul 2007
    Im anywhere and everywhere
    11,579
    My pump actually unplugged itself once, check the connection on the pump, located behind the passenger front splashguard in the fender behind the bumper
    Version 2.0 soon, stay tuned!
    rollin a dodge... it just aint a magnum
  7. #6
    Senior Member B-Rock's Avatar B-Rock is a Magnum Superstar! B-Rock is a Magnum Superstar! B-Rock is a Magnum Superstar! B-Rock is a Magnum Superstar! B-Rock is a Magnum Superstar! B-Rock is a Magnum Superstar! B-Rock is a Magnum Superstar! B-Rock is a Magnum Superstar! B-Rock is a Magnum Superstar!
    Dec 2008
    NorCal
    1,255
    Check your oil pressure in your hidden EVIC menus if you have EVIC. Our cars are notorious for having the oil pressure sensor go out on them. You might do a key dance trick as well just to double check that you are not throwing codes. Then of course, you need to double check your oil level.
    05' Mag RT Mods: Eibach Pro System drop, Frankentake IV, Mesh Grill, 20" Gienelle Rims V-5's w/ 275/40/20's,
    Flowmaster Force II SS, Challenger 6.1 motor mounts,
    6000k DDM HID Kit/Highs, Lows, Fogs, Predator!, 180F T-Stat, No ESP mod, JVC NT3HDT
  8. #7
    Member Lil mag 2.7's Avatar Lil mag 2.7 is a Magnum Expert in Training! Lil mag 2.7 is a Magnum Expert in Training! Lil mag 2.7 is a Magnum Expert in Training!
    Mar 2010
    portage in
    294
    iv had the same prob, it ended up being the oil sending unit senser. pass side next to the oil filter with two lil wires comming out of it. looks like a senser in the side up high in the oil pan, atleast on a 2.7 anyway, good luck my man on this simple fix.
  9. #8
    Jul 2011
    pa
    6
    thanks everybody for ya help good looking out,i not even gonna lie have this issuses kind of truned me off form the maggies while at lease the SE
