I have the SE edition, it comes with a single exhaust. I was wondering if somebody make a Dual kit for the SE? I know I could probably put it on a rack take a look at it and make a Y bracket myself, but if there is a Cat-Back system for it I would rather go that route.
Thanks,
Chris
there are no kits as such, as far as I know.
Any muffler shop can split it off and add the tips of your choice though. Won't be true duel exhaust but it'll sound cool.
the sxt and se use the same kit and they do have duals for it... From what I have heard with duals you lose to much back pressure and lose power on the se
Not sure it has any to spare so I would stick to the single
Exactly, with the upgraded (free flowing) muffler, I noticed a lil drop in the off the line, but winds up great. Of course the 3.5 is a high rev engine design.
HEy Guys,
The 2.7 is TRUE duals, going into 1 muffler from the factory. The shops can cut ahead of the factory y pipe and instal a true dual system, but you may want a crossover or an x-pipe to balance the sound out.
-Jim
I did see that the 2.7 is basically a dual set up with a V. However, I was wondering how installing a dual system may effect the compression (hurt or help.) I would think it would help and installed correctly would give a nice sound. Also, do you know how to get a heat sheald pad for the gas tank side that will have the muffler up against it?
