There have been a lot of people buying this lately so I thought I'd post up the settings I use in my car. Make adjustments as you see fit for your own style.
Tranzformer settings
When you download the utility, plug the transformer into the computer. Open the utility (configure).
The window will open and you should be at the "shift kit" tab.
click the "drive shift strength settings" and set up as follows -
Accelerating............. Decelerating
1-2 = 40................. 4-5 = 20
2-3 = 55................. 3-4 = 20
3-4 = 65................. 2-3 = 20
4-5 = 75................. 1-2 = 10
At the bottom, set "drive throttle scaling" to 40
now click the "autoshift stick strength settings" and enter the same information as above.
Now, go back to the tabs at the top of the program and click on the "auto upshift RPM" tab.
Check the "enable auto upshift" box. This will make sure that the transmission shifts if you miss a manual mode shift. For the R/T, set these to 5800 which are the stock shift points for the 5.7. For SRT or modded R/T that can run at higher RPM, these can be set higher (6000 - 6400)
***If you choose, leave the box unchecked and the transmission will hold selected gear and bounce off the rev limiter.
Now click on the final tab "options"
Check the "enable steering wheel button shifting" box if you want to use it.
That's it, now click the "save values" box at the bottom of the program to save your settings.
