Old 10-27-2006, 09:37 AM   #1
peybella
peybella's Avatar
peybella is just warmin' up!
New Flash Info.
Thought I should share this. The information below is what others have found on anohter forum site. The web address is listed at the bottom. Let me know of questions and I will try to get answers. The word I'm getting is that these will work with V6 (both 2.7 and 3.5) as well as the Hemi 8's
Regards,
Greg
B&G Gas Miser Flash (JTEC) - $350 includes shipping (2nd Day Air)
This PCM upgrade is designed for vehicles with no modifications (Average 1-4 mpg increase)
Revised timing & fuel tables for better gas mileage
Shift points raised to 5000 rpm
Rev limit raised to 5400 rpm
B&G Premium Flash (JTEC) - $350 includes shipping (2nd Day Air)
This PCM upgrade is designed for vehicles with little or no modifications using stock intake manifold
Revised premium fuel & timing tables
B&G M1 Flash (JTEC) - $450 includes shipping (2nd Day Air) (*)
This PCM upgrade is designed for vehicles that have installed the M1 manifold.
Shift point raised to 5400 rpm
Rev limit raised to 6000 rpm
Torque management removed
Speed limit raised 130 mph
B&G 408 Flash (JTEC) - $450 includes shipping (2nd Day Air) (*)
This PCM upgrade is designed for vehicles that have installed “Stroked Motors” or highly modified with big cam or larger then stock injectors.
Revised premium fuel & timing tables (to accommodate big cam/large injectors)
Shift points raised to 5800 rpm
Rev limit raised to 6500 rpm
Speed limit raised 140 mph
B&G Supercharged Flash (JTEC) - $450 includes shipping (2nd Day Air) (*)
This PCM upgrade is designed for vehicles that have installed a supercharger that require a custom timing control once vehicle goes into boost.
Revised premium fuel & timing tables (accommodate supercharger)
Shift points raised 5800 rpm
Rev limit raised 6500 rpm
B&G Custom Flash (JTEC) - $950 includes shipping (2nd Day Air) (*)
This PCM upgrade is designed for the customer who provides his own specifications for fuel and timing, shift points, rev limit, and speed limit settings or packages that are not factory engine/trans options.
Revised timing & fuel tables (per customer request)
Shift points (per customer request)
Rev limit (per customer request)
Speed limit raised but not removed (per customer request)
www.bgperformancepcm.com
peybella's Sig:Greg
http://www.1986whs.com -
The car-
