Old 08-04-2008, 08:53 AM   #21
Xcbellx
Xcbellx's Avatar
Xcbellx is a Magnum Expert!Xcbellx is a Magnum Expert!Xcbellx is a Magnum Expert!Xcbellx is a Magnum Expert!Xcbellx is a Magnum Expert!
so has everyone scrapped these projects?
Xcbellx's Sig:
BigBully Intakes ...Coming Soon
Xcbellx is offline   Reply With Quote
Old 08-04-2008, 09:04 AM   #22
MDMagnum
MDMagnum is just warmin' up!
Send a message via AIM to MDMagnum Send a message via Yahoo to MDMagnum
I'm still tinkering with mine. I bought a drill press (thank you harbor freight) but am having to make some redesigns. I know I need to take pictures but the prototype is very rough. The basic concept I started with was a 3in ID pvc pipe for the outer casing, capped on one end with a cleanout on the other. Down the center would be a 1in ID pvc pipe with alternating stainless wire coiling up the pipe. The problem I ran into is keeping the wires from crossing. SS wire is hard to work with. My latest change is to move to two small dowels with tightly wrapped wire with each being a separate electrode. I am going to be working on it more this week and will hopefully be bringing it to the Northern VA Chantilly M&G. It won't be installed but maybe at least operational.
I need to find some time on a lift to run the line from the rear to the front and need to select the tubing based on heat resistance.
I will warn you now that it is very rough. I'm trimming the budget until I get it working. Then I will probably commission someone else to build the pretty into the next design.
Also I'm looking into putting in a CAI so I can put a custom fitting onto the intake. If I get the exhaust as well I may be able to get my mechanic to run the tubing under the chassis but money will restrict.
MDMagnum is offline   Reply With Quote
Old 08-04-2008, 09:17 AM   #23
SoCalRT
My generator and MAP enhansor are completed and working, on my shop bench. Now that is is finished I'm a little hesitant to run it and hack into the MAP wiring...
I was going to put it in my wifes truck but I know she isn't going to want to mess with it...
Old 08-04-2008, 10:27 AM   #24
TheFOSS
TheFOSS's Avatar
TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!
I'm still interested.. i just don't have the time or money to do the research or build.. I was kinda waiting to see what the outcome was and if it works, i'll buy one i have found at a couple shops and install it..
TheFOSS's Sig:
2005 InfernoRed R/T
Mods:
Engine: Mopar CAI , JBA Shorty Headers , Diablo Predator , Custom painted engine cover and pillers, BT oilcap, fuse box cover, power steeriing, and washer fluid cap
Exterior: Shaved Side Moldings and Badges , Tinted Tails
Interior: Red C/F Dash Kit , BT shiftknob , Modified Shifter
TheFOSS is offline   Reply With Quote
Old 08-04-2008, 10:28 AM   #25
TheFOSS
TheFOSS's Avatar
That's great news!@
TheFOSS's Sig:
2005 InfernoRed R/T
Mods:
Old 08-04-2008, 10:23 PM   #26
MDMagnum
Well I completed my Electrolyzer after several revisions. And I have PICTURES!!!!.
http://i43.photobucket.com/albums/e399/estoltz/hho1.jpg
http://i43.photobucket.com/albums/e399/estoltz/hho2.jpg
The design as mentioned before is a 3 inch PVC with stainless steel wire wrapped around a pair if wooden dowels. I tested it off the car and got some bubbling. Current Catalyst to water ratio was 3TSP to a gallon. I got some bubbling. SoCalRT, how much bubbling should I be getting from an open electrolyzer on the bench.
I am not even going to venture to build a MAP/O2 sensor enhancer. I'm going to go ahead and purchase on this one I think.
Old 08-05-2008, 11:23 AM   #27
TheFOSS
TheFOSS's Avatar
Cool man.. do those have to be virtical all the time??
TheFOSS's Sig:
2005 InfernoRed R/T
Mods:
Old 08-05-2008, 04:23 PM   #28
MDMagnum
It does have to remain vertical. I'm probably going to mount it behind the back seat. I'm still not sure if I have it right as the videos I'm seeing online of HHO generators have a lot more bubbling going on.
Old 08-05-2008, 04:59 PM   #29
beekinLeadMan
beekinLeadMan's Avatar
beekinLeadMan is making a name for themself!
Originally Posted by arizonamag View Post
...Mine had to be set up in in between the radiator and front grill...
I'd be itnerested in some pics as well. You must have a smaller reservoir than mine to get it to fit up front without altering your front end.
beekinLeadMan's Sig:Erick - a.k.a. Beekin Lead Man
Check out tracks from the upcoming debut full length album from Beekin at www.beekin.com
beekinLeadMan is offline   Reply With Quote
Old 08-16-2008, 07:38 AM   #30
mikesn31
mikesn31 is an unknown quantity at this point
I fully support your idea on the HHO kit. I myself have been building on for my Magnum RT. I am going to use the plate system instead of the coil. I also have read that you can use the o2 sensor extenders which I currently installed after removing my cat's. I will aslo be installing mine in the rear of the car sourcing power from an acc power source. Power to you bro. I will post pictures soon...... 18.7mpg currently with a/c running.
mikesn31 is offline   Reply With Quote
