Since I ordered my air suspension, I wanted to place my switches on the dash somewhere. I have had switchbox's before, but hate having to keep them in my lap when I am driving. After looking around the dash, I figured I would fill the pocket right above the ashtray since I never use it anyway. If you have dual climate or navigation, you may not have this pocket. Here are some instructions on what I did:
1. First Take off the center console. Open up the ashtray and tug. This will require some force to get it free.
2. Unplug all of the wiring harness'. There is one that you have to use a screwdriver to pull the orange safety tab away to get it off. It is circled below.
3. I chose to take off the buttons near the vents so there would be no risk of damaging them, plus I will be driving the car while I work on this project. They were held on by (2) 5/32" screws. I was suprised to find that I did have a 5/32" socket in my toolbox. It will probably be the only time I use it.
4. The climate controls are held on by (4) 5/32" screws, pictured below. Remove them and keep them in a safe place.
5. Take out your dremmel and try to cut as close as you can to the edge. Be sure not to cut off the 2 clips on the bottom.
6. Here is a pic with the pocked removed. I changed out the dremmel bit to a sander and smoothed out the edges.
7. Take some sandpaper and scuff the area that we are about to fiberglass. This will help with adhesion.
8. Take a piece of cardboard and make a template of the hole. Cut out the template and secure it to the back of the bezel.
9. I put some saran wrap around the cardboard to make it easier to remove.
Continued. . .
