Go Back   Custom Dodge Magnum Forums > Tech Articles > Styling Mods
Styling Mods Tech Articles only!
Old 06-02-2008, 09:18 PM   #1
SoCalRT
Firewall How-To
So a couple of weeks ago I made a firewall out of aluminum and I think it came out pretty good and it was also pretty inexpensive to complete. I then did one for BigAl SE and also one for Catzcradle SXT so I could make some patterns. I thought I start making some up, but I just don't have the time so here is a walk through on how to make one yourself. Some of the tools needed are tin snips, drill, hole saws, assorted files and sanding blocks. On the first couple I did I used tin snips only and they don't leave the best edge and my hands were killing me, so I switched to a saber saw with a 32-36 TPI blade and it came out much smoother...
First you will need to make a pattern, but before that you need to remove the thing attached to the passenger side fender liner with the vacuum hoses. I just moved it back and attached it to the large bundle of wires. You will also need to remove the little panel seen below and the PCM mount 13mm bolts.
I started with construction paper that I pressed into the area after I guesstimated the shape and once I was happy with the fit I transferred it to poster board and fine tuned it by cutting and added paper where needed.
Once you are happy with the pattern, transfer it to the aluminum with a black Sharpie. Flip the pattern so you are putting it on the back of the material to reduce damage when you are cutting it out. On the curves I used a circle gauge and drilled out holes with a hole saw to get a good curve.
Once the layout it complete drill the holes and connect the dots. with the saw a was able to get much closer to the finished edge with little risk of damage. After a few trial fits and additional trimming, you want to leave about a #2 pencil width between the firewall and the engine so it won't rub with the engine running. we made Catzcradle a little close and he needed to do some additional trimming when he got home. Then sand it to prep for paint, punch or drill mounting holes and install. I did 5 mounting spots, one in the center and one one each side in the center of the curve and one on each end...
One thing I did my new one was add tabs to the end as the cross bar it mounts to has very solid braces at the ends, plus it cleans up the end as well. the end 13mm bolt secures the firewall...On the SXT cover we covered to large vacuum hose with braided stainless and used a 3/4" grommet for additional protection...
I bought a 3 x 5 sheet of heavy aluminum for $27.00 and it is enough for 4 or 5 firewalls a couple of bucks for paint ans screws and your good to go...
Go for it, you know you want one...
Old 06-02-2008, 09:19 PM   #2
SoCalRT
Here are a couple of shots of the finished product.
BigAl's...
And mine...
Old 06-02-2008, 09:22 PM   #3
1BlsdEsq
1BlsdEsq's Avatar
1BlsdEsq is a Magnum Expert!1BlsdEsq is a Magnum Expert!1BlsdEsq is a Magnum Expert!1BlsdEsq is a Magnum Expert!
Major props to you Bret!!! That's a great write-up and a GREAT job!!! Gotta love the D.I.Y. projects!!
1BlsdEsq's Sig:
1BlsdEsq is offline   Reply With Quote
Old 06-02-2008, 09:24 PM   #4
Magmania
Asian Persuasion
Magmania's Avatar
Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!Magmania is the one everyone should be listening to!
Great write up Brett.
And a great looking mod as well.
Once you do that you probably can't help but to continue on with more under hood mods.
Magmania's Sig:
Old 06-02-2008, 09:28 PM   #5
SoCalRT
Thanks, yeah yesterday I added real branded hoses, not the covers and cleaned up a few more things...
Old 06-02-2008, 09:44 PM   #6
dformer
dformer's Avatar
dformer is a Magnum All Star!dformer is a Magnum All Star!dformer is a Magnum All Star!dformer is a Magnum All Star!dformer is a Magnum All Star!dformer is a Magnum All Star!
WOW that looks great. I dont have the tools for this so it must wait.
dformer's Sig:MODS: Check my profile.
dformer is offline   Reply With Quote
Old 06-03-2008, 05:14 AM   #7
MadDad
Resistance is Futile
MadDad's Avatar
MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!MadDad is a Magnum Genious!
great work -- now I just to find a sheet of aluminum that big.
Old 06-03-2008, 07:58 AM   #8
2001shadowace
Drivin the Kasket Karrier
2001shadowace's Avatar
2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!
Looks real good Brett, nice write up. I am going to have to try this.
2001shadowace's Sig:
2001shadowace is offline   Reply With Quote
Old 06-03-2008, 08:03 AM   #9
CalMagnum
CalMagnum's Avatar
CalMagnum is gettin' serious now!CalMagnum is gettin' serious now!
Well done, great job Brett...
CalMagnum is offline   Reply With Quote
Old 06-03-2008, 08:31 AM   #10
JRob007
BakNdaHood... CM4Lyf!
JRob007's Avatar
JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!
Great write up! ... and even better work!!!!
JRob007's Sig:
JRob007 is offline   Reply With Quote
HTML code is On
