So set my car up with automatic lights the other day this option is cool. I have an SE so when in auto mode the lights turn on and off with the ignition….I hear in the other models they have a sensor so they only turn on when its dark….so to do it just pull the knob off in the recess you will see on the bottom a stop just one tab and on the top right side you will see two tabs I removed the first one which allows you to turn the knob one notch past the off position which is auto lights…….enjoy if you haven’t done it yet
Yes,they are. Theres a couples of good write ups on lxforum.Do a search. One way is to remove the tab and the other is to replace the switch ($50.00). Read the articles first.
quick question? I just pull the knob? I tried pretty hard and it dindt budge, didnt want to break it but I just give it a good hard tug. If I break somthing im commin to get cha! Just kidding
its not gona break.....just grab it with some vise-grips and hit it with a hammer......
