Go Back   Custom Dodge Magnum Forums > Magnum Forum > Suspension Forum
Suspension Forum Lowering Kits, Wheels and Tires
Old 10-07-2008, 04:04 AM   #1
blkonblk
blkonblk is an unknown quantity at this point
need to trim bumpstop?
do i need to trim that bumpstop in the rear if im installing the dampners with the sportlines?
or are they only on the stock struts.
blkonblk is offline   Reply With Quote
Old 10-07-2008, 07:21 AM   #2
HemiLover
the new springs should come with new bump stops
Old 10-07-2008, 09:45 AM   #3
Fireman2118
Fireman2118's Avatar
Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!
You only need to trim the bump stops if your using the stock shocks.
Fireman2118's Sig:Brilliant Black '05 R/T
If common sense was common, I'd be unemployed!
Fireman2118 is offline   Reply With Quote
Old 10-07-2008, 02:52 PM   #4
blkonblk
yup that what i thot.
im going w 22" lorenzos... is a 12mm offset going to give me any probs with the drop??
Old 10-07-2008, 04:23 PM   #5
Fireman2118
I have 22 x 9.5 with a +18 offset. I know that your wheel will extend out 6mm further with a +12 offset. That's about 1/4"
Old 10-07-2008, 08:15 PM   #6
So*Cal Magnum
Honesty is My Best Policy
So*Cal Magnum's Avatar
So*Cal Magnum is a Magnum All Star!So*Cal Magnum is a Magnum All Star!So*Cal Magnum is a Magnum All Star!So*Cal Magnum is a Magnum All Star!So*Cal Magnum is a Magnum All Star!So*Cal Magnum is a Magnum All Star!So*Cal Magnum is a Magnum All Star!
post some pics once its dropped!
So*Cal Magnum's Sig:
2008 Magnum SE - Are You Gonna Drive It Or Buy It A Dress...
DODGER Fan 4 Life!!!
Livin' The OC Life and Lovin' It!
So*Cal Magnum is offline   Reply With Quote
