Go Back   Custom Dodge Magnum Forums > Magnum Forum > Suspension Forum
Suspension Forum Lowering Kits, Wheels and Tires
Old 10-10-2008, 09:10 AM   #1
bluemag
bluemag's Avatar
bluemag is an unknown quantity at this point
Exclamation Please, I need the help of all of those with KNOWLEDGE!
Hey gentlemen of the round table. I need your HELP.
I have a guy selling me the brembo brakes off a charger, with the rotors, pads, caliper and spindle, but to all of your knowledges will I need anything else to have this installed, I have an 05 Magnum RT.
THANK YOU!
bluemag is offline   Reply With Quote
Old 10-10-2008, 09:16 AM   #2
Russell
Russell's Avatar
Russell is a Magnum Expert in Training!Russell is a Magnum Expert in Training!Russell is a Magnum Expert in Training!
You might have a Issue when you try and put your rims back on .. Iam not 100% sure but I think there might be a problem with the larger Brembo kit
I am sure somebody will correct me if I am wrong ..
Russell is offline   Reply With Quote
Old 10-10-2008, 09:21 AM   #3
bluemag
bluemag's Avatar
Nope, I have the charger SRT 20".
Old 10-10-2008, 09:49 AM   #4
bluemag
bluemag's Avatar
So should I be good then? And believe me I appreciate the help.
Old 10-10-2008, 10:47 AM   #5
jayalbertcars
jayalbertcars's Avatar
hello call a parts house and check to make sure that the master cylinder and the abs ass. and the brake hoses are the same also if there is a proprotioning valve that is also the same
Old 10-10-2008, 12:48 PM   #6
bluemag
bluemag's Avatar
Do you have to change the Master Cylinder too?
Old 10-10-2008, 12:58 PM   #7
Bigal470
you can call me Bagnum
no you are good to go...
Old 10-10-2008, 01:04 PM   #8
bluemag
bluemag's Avatar
Ok, thanks everybody.
