Installed drilled slotted rotors recently and every since then, there is a buzzing noise from the rear end. Sounds like a card in a bicycle wheel. Nothing loose or flapping underneath. Worried it could be serious. Or just stupid. Maybe air moving through the rotors? Help!
Sent from my Milestone X using Tapatalk
It's not air. What you need to do is get the rear wheels off the ground. Have the car chock blocked if you can't get all 4 wheels up. leave the car in neutral and spin the rears. You should be able to determine the cause this way.
PPP stage 3 big valve heads - Howards cam 219/227 .600/.575 112 LSA (108 ICL) - PAC 1518 springs - forged pushrods - 6.1 lifters - 6.1 oil pump - 6.1 timing set - Modern Muscle stage 1+ ported 6.1 manifold& 85mm throttle body - 6.1 fuel injectors - 6.1 fuel rails - 25% UDP - Jet 180 tstat - LMI 4" true CAI - MSD "Blaster" coils - 8.2mm Taylor wires - JBA headers - JBA high flow mids - Corsa catback
Diablosport Intune - CMR by Ditos - Paramount "Dominator" 3000 stall tc & stage II valve body - Tranzformer shift kit - 226mm Getrag 3.91 LSD - BC racing coilovers - Eibach front & rear swaysBWoody endlinks - Razors Edge strut bar - Wilwood big brake kit by TCE - W6A 6 piston front calipers on 14.25" 2 piece GT rotors - Dynapro 4 piston rear calipers on 13" 2 piece GT rotorsTrufiber Challenger A58 carbon fiber hood - Vossen VVSCV3 & Nitto 420s - 22" x 9" w/265/35/22 & 22" x 10.5" w/295/30/22 ----- Hemi Registry #943
Not to sound like a dumb ass or nothing. Did you put the right on the right and the left on the left? My understanding is there is a difference.
Eibach Pro Kit, R1 Concepts Premium Rotors, 2Crave Black Diamond No. 2 wrapped in Falken 265.35.22, Danko Mini Chin Spoiler, LamboDoors4U vertical Doors, Custom open mouth mod, MSRT Seats, Custom Bezel with Kenwood DDX-370 Double Din DVD HU, 2x 12's in custom tuned vented box, 1x 1800 rms Power Acoustik mono block, Hifonics doors, Pioneer rears, Blue LEDs, and like always...
MORE TO COME!
@DirtyPana-Rotors were installed correctly. No worries.
@Fireman-I'll try that this weekend. Anything I should be looking for?
a caliper dragging a lil maybe, causing the pads to not fully let go....
