Im in need of some new shocks/struts all around and was looking into getting a pair of Monroe Air Shocks for the rear after doing some research. Is purchasing these a good idea? This will be the first time I've replaced my struts since I had the car. I just hit 100k miles. I'm still looking for a pair for the front. Any suggestions?
Im in the same boat. 100k+. mechanic say they are good, but Im still looking.
Unless you pull a trailer, have a huge stereo or load up the rear, you wont use the air shocks. They are made to level the car only, not to provide a good ride.
Spend the money on a good quality Kyb for performance or Monroe for good ride. Bilstein are good but expensive. There are many suspension kits, but you will pay for them.
I decided tonight to do the job myself. Firestone wants $1000 for shocks and struts and alignment. I can do it for 300.
Why do you want to install air shocks? What is the goal you're trying to attain? Do you want an elevated ride height in the rear?
If you're just looking for a decent, better than oem shock, look at the KYB-GR2s
Fronts are $62.00 and the rears are $34.00 at tirerack.com
PPP stage 3 big valve heads - Howards cam 219/227 .600/.575 112 LSA (108 ICL) - PAC 1518 springs - forged pushrods - 6.1 lifters - 6.1 oil pump - 6.1 timing set - Modern Muscle stage 1+ ported 6.1 manifold& 85mm throttle body - 6.1 fuel injectors - 6.1 fuel rails - 25% UDP - Jet 180 tstat - LMI 4" true CAI - MSD "Blaster" coils - 8.2mm Taylor wires - JBA headers - JBA high flow mids - Corsa catback
Diablosport Intune - CMR by Ditos - Paramount "Dominator" 3000 stall tc & stage II valve body - Tranzformer shift kit - 226mm Getrag 3.91 LSD - BC racing coilovers - Eibach front & rear swaysBWoody endlinks - Razors Edge strut bar - Wilwood big brake kit by TCE - W6A 6 piston front calipers on 14.25" 2 piece GT rotors - Dynapro 4 piston rear calipers on 13" 2 piece GT rotorsTrufiber Challenger A58 carbon fiber hood - Vossen VVSCV3 & Nitto 420s - 22" x 9" w/265/35/22 & 22" x 10.5" w/295/30/22 ----- Hemi Registry #943
Check out Rock Auto, too.
