Front end vibration at 65mph
Results 1 to 11 of 11
    Newbie stocksj is an unknown quantity at this point
    Dec 2011
    Woodbridge VA
    14
    Hi,
    I'm getting some front end vibration when driving starting at about 62 mph increasing at 65mph and then dropping off after 70mph. I was thinking tire balancing since I see no balancing weights on the front wheels. This problem only happens at about 65mph.
    07 Magnum SXT w/83k miles
    Thanks,
    Jim
    Senior Member goodfellazmagnum's Avatar goodfellazmagnum is a Magnum Expert!goodfellazmagnum is a Magnum Expert!goodfellazmagnum is a Magnum Expert!goodfellazmagnum is a Magnum Expert!goodfellazmagnum is a Magnum Expert!
    Feb 2011
    ft.wayne, indiana
    1,788
    Get the tires and balancing checked if there ok could be some front end parts they are notorious for going bad...
    Sent from my HTC EVO on tapatalk
    26" Dcenti rims w/255/30/26 tires, extended spindles, rolled fenders, 2 15" kicker L7 subwoofers, 4,000 watt hifonics brutus amp, tinted tails, black painted headlight buckets, 8.3" power acoustik Flip out touch screen dvd player, cross drilled and slotted rotors,Cai, wiper delete with 300 srt8 wing, 8000k HID lights, white led interior lights, polished gauge rings, dual exhasust with glasspack
    Dec 2011
    Woodbridge VA
    14
    Ok Thanks,
    I went out to check which tire I have and they are different. When I bought the car used last December the Toyota dealership needed to replace the rear tires. Here's what I have:
    Front: Goodyear Integrity P215/65R17 80% tread
    Rear: Goodyear Wrangler SRA P215/65R17 100% new
    New brake shoes
    I've only driven the car 1100 miles in the last 6 months. The vibration is felt in the dashboard only. The car handles nice and no braking or steering issues.
    I hope that helps. I have an appointment at Firestone on base tomorrow. If they come up with anything more than just a tire balance I'll take it else where since they try to stick it to you with unneeded repairs.
    Jim
    U.S.A.
    18,841
    Have the wheels balanced and if that doesn't correct the problem, check the tie rods.
    Senior Member waldo's Avatar
    waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!waldo is the one everyone should be listening to!
    Jan 2008
    so cal, for now...
    3,160
    As others have suggested, check the suspension bits and pieces. Another possibility, though somewhat remote, is potential tread seperation.
    I had a very similar issue and no amount of balancing could get rid of it. Turned out all four tires, Goodyear RSAs were coming apart... they only had about 5,000 miles on them. Goodyear offered a pro-rated replacement, but after what I'd heard of others having issues with GY tires, I put Toyo Proxy 4s on the car and couldn't be happier.
    I'm certainly hoping your problem can be fixed for less money and a whole lot less hassle...
    W.W.E.D.? Hidden Content Admit nothing, deny everything... demand proof
    Member mcdizzle's Avatar mcdizzle is making a name for themself!mcdizzle is making a name for themself!
    Jun 2012
    54
    ive had that problem with other vehicles, and a rotation/balance solved it. so, i guess it could be anything.
    Warren, MI
    18,986
    Had the same problem, I had the tires re balanced FOUR times. Forth time was a different tire store...... Fixed....
    Happened again a few months later.... replaced both outer tie rod ends... took me longer to jack up car than it did to change the ends.... it is that easy.....
    Member Jefro2010's Avatar Jefro2010 is a Magnum Expert in Training!Jefro2010 is a Magnum Expert in Training!Jefro2010 is a Magnum Expert in Training!Jefro2010 is a Magnum Expert in Training!
    May 2012
    Knoxville, TN
    397
    i had the same thing, i had my wheels balanced and it kept throwing diff. weights each time, come to find out one of the tires had fix-a-flat in it causing it to vibrate at certain speeds
    2006 R/T AWD, K&N CAI, SLP LM1 exhaust, slotted rotors!!! B
    Mopar or No Car!!! Go big or go
    Home!!!Hidden Content Hidden Content
    Member TI 3VOM's Avatar TI 3VOM is making a name for themself!TI 3VOM is making a name for themself!
    Oct 2011
    Nebraska
    920
    Fix-a-flat or slime was my suggestion as well. I had to do that during my labor day weekend expedition to South Dakota and nobody would touch my tires or even have the sizes I needed because alot of places were closed obviously during the holiday. I didn't get a shake until right around 75/76mph
    Jun 2012
    54
    theres a style of weight called dyna beads that i will probably get. ive used them in motorcycle tires and they work great. they are ceramic beads you pour through the valve stem and they balance for the lifetime of the tire.
  13. #11
    Senior Member el guapo's Avatar el guapo is a Magnum Superstar!el guapo is a Magnum Superstar!el guapo is a Magnum Superstar!el guapo is a Magnum Superstar!el guapo is a Magnum Superstar!el guapo is a Magnum Superstar!el guapo is a Magnum Superstar!el guapo is a Magnum Superstar!el guapo is a Magnum Superstar!
    Oct 2009
    Toronto, Ontario, Canada
    1,593
    Went through this last year. No amount of balancing would fix it. Turned out that the belts and plys were starting to separate. These were the "new" pair of continentals that were on it when I bought it. Once they were swapped out all was fine.
    I've got a mind that can steer me to your house,
    And a heart that can bring you red flowers.
    My intentions are good and earnest and true,
    But under my hood is internal combustion power.
    Satan is my Motor - Cake
    “If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason.” - Jack Handy
    Evil will always triumph because good is dumb. - Dark Helmet
