catch can
Results 1 to 13 of 13
Thread: catch can
    Member MagMedic's Avatar Array
    Jun 2010
    Augusta, KS
    146
    catch can
    I went to empty my catch can and noticed it was bone dry inside. Is this normal?
    Array
    U.S.A.
    18,841
    Don't know about the 2.7.....In my 5.7, I have about 1/2"-3/4" every 5000 miles
    How long have you had it installed?
    Is it installed correctly?
    I am a computer.
    Array
    Jun 2008
    Vancouver BC
    5,685
    Sounds like it may be installed incorrectly. . .
    It is common for people to install them between the crankcase vent and intake tube, this is not correct.
    It is to be installed in the line coming off the PCV valve.
    www.zygotecustoms.com Greg095's Avatar
    Array
    Nov 2006
    Utah
    11,940
    Agreed. Had mine installed wrong for about 6 months.
    Wheels // Accessories // Body kits // Suspension // Electronics
    Array
    Feb 2008
    Salisbury, North Carolina
    26,554
    I change my oil every 3000 miles and mine is usually about 1/4 - 1/3 full!
    MyHidden Content Cars:Hidden Content
    2006 Magnum SRT8 "SHADOW"
    2005 Red Magnum R/T "LUCKY"
    2005 Blue Magnum R/T "BLUE"
    2006 Chrysler 300SRT "CHEETA"
    Plus have SEVERAL OTHER RIDES
    "Old Geezers LOVE cars Too!!!
    Hemi Registry #864 2/15/08
    Jim
    where's my airbrush?? GreenKing's Avatar
    Array
    Dec 2007
    @ The Chop Shop
    14,795
    His cans only been on for 3-4 weeks. Not sure if he has it on the right line.
    FORUM RULES: Hidden Content
    ULTIMATE CM.COM HOW-TO:Hidden Content
    PLEASE SUPPORT OUR VENDORS:Hidden Content
    Member didyoma's Avatar Array
    Nov 2009
    Da 219
    866
    Okay guys, what is the catch can? Do I already have one? (06 R/T) If not, do I need one? I see people talkin' bout them and I know nothin' bout it.
    Senior Member D-LASH's Avatar
    Array
    Oct 2009
    NC from LI,NY
    4,408
    Both of us need 1 Did!! From what I understand its a crazy story,(to me) .... turns out we need to burn off some junk thats thrown back into the intake by design, ... but these little smarty pants thought, F that! Lets just catch and deposit it into a can instead of throwning back into the engine to burn off.... BRILLianT!! I want a black 1 with black braided steel and black fittings!!
    PS, some guys make em!
    MR 3 FIFTEEN FROST's Avatar
    Array
    Mar 2009
    ILLINOIS [815]
    12,414
    I agree with D-LASH. If you do want a catch can, hit up 3g or BT.
    Just slam it.
    Jun 2010
    Augusta, KS
    146
    Well I feel like a tard. It was installed incorrectly. Got it run to the right line and hopefully it works out better.
  13. #11
    Array
    Mar 2009
    ILLINOIS [815]
    12,414
    Better to realize it now than to continue runnin it incorrectly.
    Just slam it.
  14. #12
    I am a computer.
    Array
    Jun 2008
    Vancouver BC
    5,685
    Don't worry, there is no way you could be a bigger "tard' than Greg
  15. #13
    Member Array
    May 2009
    77
    Thanks for helping him guys.. I have been out of the office. Thanks again
