Interest in discontinued items from billet tech post here
Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
  1. #31
    Member truckzilla46's Avatar Array
    Jan 2010
    Iowa
    909
    They have 2 wings that can be done in any color . So I actually already have one so I can pass so the 2 without can get these.
    Sent from my iPhone 4s using Tapatalk
    Api Forged 392 660rwhp/680rwtq comp 428 cam p/p heads titanium pushrods psi springs Api 85mm t/b Magnuson s/c 11.6 psi Shr Trans FTI 2800 t/q dss 1400hp driveshaft/axels Qaife diff 3:55 gears Api brace BT catchcan/caps and wing Carbon by design hood/pillars/int kit moroso overflow/ p/s reservoir canton s/c tank Custom c/f sub floor box with kicker L7skicker 1500rms mono amp Spohn rearend kit BC coilovers Billyboat cat back LTH PLX gauges 3g half covers abs cover fuse box cover
  3. #32
    Jan 2010
    Iowa
    909
    ]As far as nose badges they do have a few as follows.
    1 black
    2 flat black
    1 red
    So sounds to me like its a matter of picking out one of these and your design.
  4. #33
    Member dodirty's Avatar Array
    Mar 2010
    philly
    375
    i want a wing in black with a deceticon emblem fully etched.
    Procharger P1sc, Magnaflow catback, hhp stage2 head/cam, quaife lsd dss 1400hp axles, bb stage 2 valve body, 8000k Hid Head / Fog lights, aac 10000k led halos, color matched headlight housing and eyelids, aeroforce dual gauges, Bt Engine Dress kit Bt catch can Bt T-shifter 22" Dvinci Attivo rims(staggered 22x8.5 front 22x10 rear) red led's front/rear 180degree t-stat BMC braided hoses. Bt front and rear decepticon emblem killerglasss radiator hose 650rwhp/558rwtq 9psi
  6. #34
    Jan 2010
    Iowa
    909
    Steves05rt
    Dodirty
    Pm sent
