Billet Technology Magnum Wing Group Buy (VERY Limited Production)
Results 1 to 4 of 4
    //CMOM | Secret Agent// concussion's Avatar
    Array
    Feb 2008
    Charlotte, NC
    3,243
    So I've been bugging the boss lady for a while, and we did a test on the Dodge Magnums World Wide Facebook group, and the response was very strong.
    Here's the skinny... we need at least 15 people, 30% deposit (non-refundable after we start manufacturing). Deposit is refundable until production starts. You can have any standard emblem you want for $125 shipped. (not including 3D or reverse cut)
    Here are the details, please read carefully.
    People Needed: 15 minimum
    Cost: $125 shipped
    Deposit: 30% non-refundable deposit required.
    - Deposit maybe refunded if requested BEFORE production starts.
    - Once production begins, no deposits will be issued.
    Engrave: Your choice on engrave.
    - 3D Engrave $125 up-charge (email or call the shop)
    - reverse cut (email or call the shop)
    - Custom Engrave (not already on hand with BT) will be additional cost
    Anodize: All standard Billet Technology anodize colors available.
    Lead Time: 6 weeks from CLOSE of Group Buy. This means that the 6 week lead time starts once we close the Group Buy and go into production. NOT 6 weeks from when you sign up and place your deposit.
    Please do not comment in THIS THREAD (or any other one) if you'd like to take advantage of this offer, please follow the link at the bottom of my post, read the article, then follow the link to the Group Buy on the store where you can put down your deposit. We only run these every couple of years, so if you miss out now, I wouldn't expect to see it again, until 2017... if ever.
    Once we have 15+ people, and others have had a reasonable amount of time to order (aprox May 30th) and place their deposit, we'll close the Group Buy and begin production.
    Magnum Wing Group Buy! | Billet Technology
    PickleFork & MMPG: Custom Cam | Indy: 6.1 Heads | Modern | Muscle: Stage 1+ SRT Intake Manifold, 85mm TB | Paramount: VB, Shift Kit, Flex Plate, 4000 Dominator TC | PickleFork: FrankenTake V, Ported SRT Headers | Getrag: LSD 3.06 gears | Maganaflow: 6.1 HF cats | SLP: LMII, UD Pulley | SRT: Modified Suspension, Injectors | AMG: Paddles, Clutches | PLCMAN: Harness | BT: Can, Emblems | Lead Foot
    11.861 @ 112.76 1.63 60'
    Array
    Feb 2008
    Charlotte, NC
    3,243
    we've got about 12 in the group buy so far. So if you want one, please go ahead and pull the trigger. these won't be offered again for quite some time.
    Newbie Array
    Jul 2016
    4
    Need one doing then again?
    Array
    U.S.A.
    18,841
    You're more likely to get a response over on their Facebook page.
    https://www.facebook.com/billettechnology/?fref=ts
